Question about Brother Office Equipment & Supplies
Toner light on, replaced toner cartridge, won't print, toner light still on, replaced with new cartridge, toner light still on and won't print.
  • 1 more comment
  • mamagina Oct 30, 2008
    It is a brother HL-2040 printer that will not print. The toner comes on and it stops, even though I have replaced two new toners.
    Rhis did not work. The drum light is not on. Did I buy defective toners? I've gone through 3 of them.
    I did that - it still does not print.
  • 6,487 Answers
Unplug the printer for about 5 minutes thne remove the cartridges then after five minutes put the cartriodges back ion and power on the printer and after that check if you still have the toner light on if not try to print ....
Posted on Oct 30, 2008
  • Mark Gil
    Mark Gil Oct 30, 2008
    there's a possibi;ity that you have purchased a defective toner can you try to put the old toner back just to see if we wioll have the same result, but the best thing to do now since this is a new toner is to have it replace so we can check if the replacement will still have the same result or not....
    Master:
  • 763 Answers
Sir try this procedure
  • uninstall the driver or software as of your device was installed
  • reinstall the driver again and see the steps and procedure with the wizard installation
  • check the your device if its all completly in place and looks functioning correctly as it looks
  • after the installation print some various types to print and see if it works
  • check also the connection from the printer to the computer
hope that helps
thank you for using fixya
CHARCOIS
  • 1,031 Answers
If the toner LED still lit even after replacing the drum unit then you know that the Drum counter may not be reset. you need to reset the drum
you can rReset the Drum counter as follows:
  • Open the front cover.
  • Locate the control panel button under the LED lights on the left side.
  • Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.hope this helps
    Guru:
  • 558 Answers
See if all the cover closed firmly, also check if the roller moves when you power on and give print command.
  • 2 more comments
  • Puneet Jain
    Puneet Jain Oct 30, 2008
    Any error message showing in PC? Check the printer properties, and cancell all document if there any.. Also check the Event viewer entries for Application:
    Please click >> Start >>Control Panel >> Administrator Tools >> click >> Event viewer in the event viewer click on application.
    You will see applications with the red cross click - on red cross applications, let me know that,
    Also send them to Microsoft for further investigation, just double click on it, More information Online.. it wil show the cause and its possible solution.
    Let me know if you face any difficulty
  • Puneet Jain
    Check out this page to get useful info: Brother HL2040
  • Puneet Jain
    If everything seems oK and printer is printing , then the LED indication just shows a fuser unit failure.
  • Puneet Jain
    Also check for the Reset the Drum counter: Open it and press the control panel button untill all light glow, then leave it to come up normal. then insert the toner in drum, and then check for print.
    View this page for mor helpful infor: Brother Hl 2040
  • Brother Master
  • 19,396 Answers
Try removing the toner, then unplug power cord for ten minutes, then put toner back, and restart it.
See if this work if not there may be a problem with the drum.
    Master:
  • 848 Answers
Provide details about make and model no ..............
  • gopinath pasupathy Oct 30, 2008
    1. Make sure the toner cartridge is properly seated.
    2. If the single sheet slot has a door make sure the door is fully closed. Check for a jam or trash in the single sheet slot.
    3. If you have a spray can of air try blowing out the interior of the printer. I wouldn't buy a can for just this as it probably wont help.
    4. Unplug the printer. Using a spray can of electronics cleaner clean the rollers. Also spray around all buttons and make sure they are not sticking,
4 Suggested Answers
  • 22 Answers
SOURCE: Toner light still on with new toner
Is the printer still asking for a new toner..?
If it is the there is a gear that can be reset on the toner cartridge2_bing.gif to tell the machine its a new toner cartridge. This is normally done by an engineer, but is quite easy to do if you know how. And I do :0
Posted on Mar 07, 2010
Printtech
  • 1087 Answers
SOURCE: TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Posted on Mar 19, 2010
  • 20 Answers
SOURCE: Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Posted on Mar 05, 2011
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
HP Color Laserjet Cp2025n Printer - driver says it's out of toner and won't print. No true. I put in new toner cartridge last week. How do I get it toreceognize the new toner?
Did you purchase a new OEM HP toner or a refilled or remanufactured toner. It is possible that the chip is bad on the cartridge in which case if it is a true HP cartridge have them replace it. If you purchased 3rd party go after the vendor to replace it.
Jun 28, 2011 | HP Laserjet Cp2025n Printer
I have cannon printer model L11121E, lately ,its not printing well, some of the matter comes up very light,unable to read, as if the catridge is running out, this is supposed to be laser printer, what...
The toner may be low or nearly run out. Remove the toner cartridge and give it a shake in a horizontal position, then replace the toner cartridge in the printer. This may give you a few more prints.
If not you need to replace the toner cartridge with a new Canon toner cartridge, or purchase a re-manufactured toner cartridge for your model laser printer. These re-manufactured laser cartridges are approx. half the cost of a new toner cartridge.
Feb 08, 2011 | Office Equipment & Supplies
Refill toner
hi
check this video it is very easy
i have try 3 times in the same cartridge
and works just like the original
Dec 03, 2010 | Canon LASER SHOT LBP-2900 Printer
Toner is not out of ink but it lights up, refusing to print
In most cases cartridges have a special chip that remembers the toner cartridge serial number an amount of pages printed from it. This means, that even though there still might be some toner left in the cartridge, the chip's counter reaches it's predefined limit and informs printer, that the toner has run out. Just like that, suddenly.
It may also be the case, that the chip loses contact with the printer's electrical terminals - try reseating the cartridge in the printer. If that doesn't help, it's time to replace it I'm afraid.
Usually the printer will inform "toner low" for some time before it becomes "toner out" and refuses to print. If you get "toner low", then it's time to purchase a new cartridge to have it ready.
Oct 27, 2009 | Fujitsu Office Equipment & Supplies
How do i change the print cartridge?
Replacing the print cartridge
  1. Open the print cartridge door, and remove the old print cartridge. CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light by covering it with a sheet of paper. Figure 1: Removing the print cartridge c01174123.jpg
  2. Remove the new print cartridge from the packaging. CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  3. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling. Figure 2: Removing the sealing tape c01211568.jpg
  4. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge. Figure 3: Shaking the print cartridge c01211569.jpg
  5. Insert the print cartridge in the device and close the print cartridge door. Figure 4: Inserting the print cartridge c01174125.jpg CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
NOTE: When toner is low, faded or light areas appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner. To redistribute the toner, remove the cartridge from the device and gently rock it from front to back.
Sep 13, 2009 | HP Office Equipment & Supplies
Feb 11, 2009 | Brother HL 5250DN Laser Printer
329 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
