We have an aproximately 17-year old Hitachi multi-system video tape recorder (model VT-498EM). the VCR does not eject the tapes properly; one has to pop open the tape deck door and slightly lift the tape and then press the eject button. can you help?? thank you, eric ries..
  • badaussee Nov 18, 2008
    Benimur,
    thanks for your advice. you are correct; this involves more fine mechanics and electronics than i'm comfortable with. can any one recommend a reliable VCR repair shop in northern Virginia area??
    thanks, badaussee..
    this involved more fine mechanics and electronics than i am comfortable with. can you recommend a reliable VCR shop in northern Virginia?? thanks for your help.
    Sergeant:
    Champion:
  • 283 Answers
Need to open your video tape recorder. Check the roller,there might foreign object clog the roller. See also if mechanism of the roller is okey(no broken parts). Tight the screw of the roller..Thier might be lossen. POst for further informations..please dont rate me if not satisfied with my suggestions..
Thank you for using fixya....
Posted on Nov 16, 2008
    Scholar:
  • 132 Answers
Probably due to worn gears in the cradle that lifts the tape in and out remove the case use sewing machine oil on the white cogs use very little oil do not pour in like one drop per cog put back together see if any better hope this helps thanks glenn.....
  • 734 Answers
Follow the link----
http://www.fixer.com/no-eject.html
  • futureloginn
    futureloginn Nov 16, 2008
    First, there is a simple thing you can try that hardly takes any time at all. Pull the power plug on your VCR for about 30 seconds; and then plug it back in again. This se-------------------- follow the above link
    Brigadier General:
  • 6,966 Answers
Considering the age and length of service, a couple of ideas/possibilities that could be explored/checked:
  • belt - they ten to over stretch or developed bends or even altogether be cut;
  • worm gears/gears - the lubrication tends to gum up or be altogether missing. dried up;
  • loading plate/brackets/arms - some could be misaligned, dislodged or simply out of place;
  • loading motor - might be in need of lubrication;
  • power supply - specifically the capacitors might have leaked and therefore the voltage goes down a bit, not enough for the full need of the electronics especially the loading motor.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 18, 2008
    If you would pls go to FixYa's homepage, there would be a space on the right side where you could enter your zip code.
    Clicking on the Go button would display a page "Repair Service Providers". In the middle column, below TV and Video wold be the last entry VCRs, clicking on that would display another new page with potential "Repair Service Provider" that could attend to your VCR mechanical problem. Most would have a telephone number listed and you can then select one that is conveniently located near you.
    Cheers.
    Scholar:
  • 181 Answers
The gears which moves the doors to eject are worn out.
  • 1 more comment
  • fixyy Nov 16, 2008
    the internal gear assembly needs to be changed as the device is very much old.and this is a common problem in all the dvd/vcd players that the door stops ejecting properly.
    just get your gear assembly replaced.and every thing will be fine and perfect.
    thanks.
    How to Clean Tape Recorder Heads and Drive Wheel
    Though many people are using digital recorders, some still use tape recorders. A simple procedure will help clear up recordings and playbacks, as well as lessen the likelihood of a tape jam.
    Instructions
    1)Make sure your recorder has available power. Open the lid by pressing eject or the appropriate button or lever, and remove the cassette.
    2)You will want to clean both the recording and playback heads if the device is so equipped, so with the lid open look for a lever that is designed to be depressed when a tape to be recorded is inserted. On certain small recorders like a General Electric hand-held recorder this step will not be unnecessary.
    Step3If there is lever to detect a tape that can be recorded, gently push the lever in and hold it for step 4.
    4)Making sure your hands and fingers will be away from all moving parts, gently depress record and play until both heads (if the device is so equipped) are visible, locked into position and the motor is running so the rubber drive wheel is turning
    Step5The recorder should now be running, and you should be able to carefully remove your finger off of the lever that detects a tape can be recorded. Take a cotton swab an dip it into some rubbing alcohol so that it is mostly wet. You do not want the swab too wet.
    Step6With gentle pressure, wipe the heads with the swab. Check the swab, and if it is too dirty or frayed, anoint another swab and continue. Keep checking the swabs you use, and do the heads first before you get to the rubber drive wheel.
    Observe the rubber drive wheel as to whether it is rotating clockwise or counterclockwise. Place a freshly anointed swab either at the 10 o'clock position on the wheel if it is rotating counterclockwise, or the 2 o'clock position if it is rotating clockwise. The proper position will prevent the fibers of the swab from being caught between the rubber wheel and the rotating shaft of the motor. Apply gentle pressure upon the wheel moving the swab up and down the circumference of the wheel as it makes a number of rotations. Check the swab to see if you have to use a fresh one.
    Step8While the recorder is still running, take a new swab but do not dip it into the rubbing alcohol. Instead, dry the heads and drive wheel with it. Inspect the heads and drive wheel for any stray fibers, and remove the fibers with a tweezer. When the heads and wheel are dry, stop the recorder, and reinsert the cassette if so desired.
    Things You’ll Need:
Eject the tape on Hitachi VT-FX695. It stays on for about 45 seconds and will not eject and then powers off.
hi,
the door mechanism is may be gripped because of a small kick...
did you try to open the door with a full charged battery and with the wall plug connected too ? help it with a toothpick or the corner of a credit card...
if this doesn't work, it may be the motor that is dead, do you ear any little noise when asking the ejection ? if yes, it is the mechanic, if not, it is the motor or the motor driver that is dead.
cheers,
mich
Nov 06, 2014 | Hitachi DZ-MV550 DVD Camcorder
I have a Magnavox zv427mg9 a, and when I insert a vhs after like 17 seconds it turns off. What could be?
I am thinking hard... So any tape (different tape?) it will not play or record for but 17 seconds?
Jan 31, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
VCR won't record, just ejects tape
You have not mentioned the make and model number of the vcr. Any way the problem is due to end sensor or related circuit. End sensors are photo diods which you can check the shorting with a multy meter.
Jan 13, 2013 | Emerson Televison & Video
Model is Sylvania DVC 840G, DVD/CD player with VCR. Have limited space. VCR on seperate shelf in cabinet, had to put two TV converters on top of VCR (top each side) so we could watch TV and tape a...
The tape mechanism belts have stretched and the unit is not running properly. When this happens, microprocessor is programmed to eject tape and shut down unit.
Apr 11, 2017 | Sylvania Televison & Video
When I try to tape a program to the vcr, the tape ejects when I press record. I unplugged it as suggested in the manual and tried again. The dvd works fine.
Check the record switch in the video recorder. The thing that pushes on the tab on the video tape! If bent or broken, your VCR will assume that the blank tape has no tab and thus eject it, as though it was a protected tape!
Mar 04, 2010 | Televison & Video
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
HITACHI vcr DOES NOT LOAD TAPE
It's more than likely a slipping belt in the tape mechanism
If you are technically inclined it can be fixed for around $3.00
If you are not then it would be advisable to buy a new VCR because the repair cost would be more than the cost of a new one .
Mar 27, 2009 | Hitachi Televison & Video
External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Sep 09, 2008 | Philips Televison & Video
JVC HR S5700AM S-VHS video recorder - won't accept tapes
Hey Lindsay
Yes the ejector is probably damaged inside maybe a bent arm or something mine is like that 2 and I didnt even bother fixing it I will be finding one very soon and I suggest you should 2 so just throw out the old and come in the new with your new vcr or dvd vcr combo..
Jul 23, 2008 | Televison & Video
Video tape ejects itself
not to overlook the obvious but check to make sure the record safe tab is still on the tape. (little black tab on lower left corner on back of tape)if tab is gone the machine will not go into record mode.
Mar 11, 2007 | Sony SLV-ED85 VCR
Televison & Video Logo
Top Televison & Video Experts
