Question about Sony KV-27V42 27" TV
Noise when turned on
My sony which i've had 7-8 years has been making a noise for the last year or so when turned on...I would describe it as like a loud electrical thud or buzz for about a second ... picture comes on and is fine...have noticed on the wall behind the tv where back of tube is close, a black burn-like spray...nothing smells like burned wires,etc while in operation....what might be the problem?...thanks for any insight
    Sergeant:
  • 337 Answers
For the age of the set I would guess you have many loose conections in power supply and horizontal driver circuit,you need to call someone who can locate all of the overheated areas and resoldered them.Do not try to use it anymore or it will fail completely.Do not do it yourself unless you know how to safely work on a tv set.
Posted on Sep 13, 2006
Loud noise when power steering is on full lock Kia Sedona 2004
There may be 2 possible causes for this problem. THe first may be cv koints failing or excessive turn angle of the wheel which would be binding up the cv joint. This can be checked by a wheel aligner testing the maximum turn allowed at the wheels.. The second is that power steering pumps should never be operated at tight full turn. To umnderstand this consider this. Power steering pumps are only under load when you move the steering wheel ans if you turn a bit the pump moves the wheels and then the pressure is let off until you move the wheel again. You have to move the wheel to shut off a valve in the box that allows the pump to build up pressure. When you hold the wheel hard against the stops at full turn you are making the pump work at maximum pressure and if you continue to do this you can expect premature pump failure. Jusat turn until you hit the stops then ease off a fraction. The noise I expect is the pressure relief valve in the pump is releasing rapidly and it probably sounds like a hammer hitting something metalic. Try the alignment and try not holding the turn hard at hard full turn. Haveing the pump pressure checked might also point to a fault
Feb 07, 2013 | Kia Sedona Cars & Trucks
Hi. Have had Sony KDF-55WF665 for last 5-6 years - has worked well but picture started to fade slightly and then last night made "pop" and screen went dark. turned all off. When turn back on...
Hey,, TV's pictures do have a "shelf life"... he said usually around 150,000 hours..I did not know this until the "guy" at best buy let me in on the secret...now, i always turn the TV off no matter when or how long I am going to be gone..
Sep 14, 2017 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have a 25,000BTU Enerco IR garage heater that is about 12 years old pilot light does not stay completely lite it makes noise and smells like gas
When was the last time you cleaned and serviced the heater? From what you described, it sounds like the pilot is clogged, as well as the burner. That's why it's making noise and smells like gas. Not all the gas is being consumed.
Mar 29, 2011 | Mr. Heater MH40LP / MH40NG Infra-Red
Loud noise during spin cycle
My formula: Purchase price divided by # years before service = Cost per year. If the cost of the repair divided by the expected # years it should last is equal to or less that the first then I go for it(usually figure the replacement parts to last at least half as long as the original)
Eric
Jan 19, 2010 | Washing Machines
2 separate colors on screen
sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2008 | Sony KP-53V75 53" Rear Projection...
BMW 325 Touring, Knocking noise when turning full lock
Hi these cars are known for the wishbone bushes failing and will cause the same symptoms as what you describe, there are 3 different bushes on the wishbone have them all checked for any play, Hope this helps
Dec 09, 2008 | 2001 BMW 325
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Sony KV-27V42 27" TV Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
