Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Xe80 copies coming out almost black on auto or light
Xe80 copier when copying the copies are coming out very dark almost black. Took out both the drum and toner no help Tried the clear-auto-clear-auto 14 clear-clear start. did not help. still black copies.
  • wilbyandco Jan 08, 2009
    That fixed it. Thanks
    President:
  • Xerox Master
  • 990 Answers
Hello sir; Just replace drum cartridge it will take care your problem, GOOD LUCK!
Posted on Jan 07, 2009
I have a Canon PC 940. The copies are coming out with black lines ( 1/2 inch wide ) on the sides of the paper. Do I need to get the copier cleaned? Thank you.
Could be optics needing to be cleaned. First I would rule out the toner cartridge. If you have a spare swap it out or remove your current cartridge, turn it over and slide open the "gate" that covers the drum cyclinder. The drum should be clean all the way across it's surface. If you see toner on each end then that is where your dark sides are coming from. If the drum is clean then most likely you have dust building up on the optics mirrors. One test for this is to manually lighten the exposure control on the operation panel and then recheck your copy quality. This may cause the rest of the copy to be light but if the dark sides goes away then your optics are dirty.
Good Luck and Thank You for using Fixya.
Aug 11, 2010 | Canon PC-940 Black and White Copier
I HAVE DEGITAL COPIER IR 1600 THE PROPLEM COMING IS BLACK COPY IN REAR SIDE PLEASE HELP ME
it is very possible the dark line on your copies are being caused by the drum. it will all depend on how many copies are on it but without seeing one of the copies the best guess i can make is the drum.
Jun 10, 2010 | Canon ImageRunner 1600 Copier
Our copies and starting to come out dirty and
Dark copies in that machine means the drum it's getting old. If adjusting the exposure to light makes the copies better, then the drum is the culprit.
Apr 28, 2010 | Kyocera KM-1510 Copier
Black streaks in copy. i have cleaned the drum and replaced the toner cartridge. anything else to try for this older xe80/xe82
You cleaning blade for the drum may be needing replacement, mite have some harden toner on the cleaning blade alowing toner to run around the bad/hard toner leaving streaks
Jul 23, 2009 | Xerox Office Equipment & Supplies
Kyocera Mita 1635 Copier Printing Very Light Copies
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
Apr 15, 2009 | Kyocera KM-1505 Copier
Minolta Copier EP1083, copies are coming out mostly black
What you mostly need to do is to clean the optics under the copyboard glass the mirrors are mostly dusty... I would use a soft dry cloth to wipe the mirrors off. There is a mirror under the "Black Box" I would also, use a lightly damp rag with rubbing alcoh. to wipe OFF the scanning lamp & reflector. Cleaning the optics should get read of the dark back ground, but the drums are only good for 80k... You may need a new OPC drum & blade. Good Luck
Mar 02, 2009 | Minolta EP1083 CS/PRO Copier
I have a dark line across copies
Whats the make and model of the copier?
One culprit might be the drum.  If you can take a look at the drum from your copier and you see black lines on it.  It could be scratches on the drum or it may need a new cleaning blade to clean the toner off the drum.
Nov 11, 2008 | Office Equipment & Supplies
Xerox xe80 workcentre prints almost black copies
Hello sir; Just replace drum cartridge, it will take care your problem. GOOD LUCK!
Oct 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
AR 5316 VERY DARK BLACK COPIES
You need to check the drum unit for wear or the main charge assembly. If you are not mechanically inclined, just replace the drum unit and clean the transfer charge on the right side door.
Don't forget to rate your answers please.
Jan 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
90 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
