Question about Philips 55P8241 55" Rear Projection Television
High pitch noise when tv warms up
The television has a high pitch noise when it warms up that is loud and extremely annoying. The pitch is high and very consistent.
    Sergeant:
  • 337 Answers
High pitch noise is created mostly by a Coil or a transformer,is not easy finding the source if you are not familiar with this type of coil since there many sizes and shapes,the set needs to be on while trying to find wich part is doing it SO if you dont know where and how better call a Technician and you will be safe.
Posted on Sep 12, 2006
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
High pitch frequency noise coming from rear of TV and is very annoying to listen too. It is a constant noise and is more apparent when there is more black color on screen.
High pitch sound on LC-42D62 is reproduced by switching transformers on power supply board. To correct this problem, you will need to remove power supply unit from the TV, spray all transformers with SILICONE CONFORMAL COATING. Let it dry for 12Hrs. Then install power supply unit back.
Dec 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
When i turn the tv on ,sometimes i hear a high pitched fan noise.
Hi, bearings in color wheel are about to fail, get it fixed now before the wheel shatters the prisms all over the inside of the tv which of course will then cost you more to fix, video-tek
Jul 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
High pitched noise coming from set.
hi there high pitched noise form the set indicates that one of the coils inside the set are lose this happens with age and heat the coils are made of copper and are tightly glued or soldered together and can be as small as a bit of hair of as big as a pen tip the problem is that the coil is now vibrating which is causing the high pitch sound and sound be quite easy to identify with a good ear!
sometimes these can be sorted with a quick bit of solder to hold it in place on the main bord of where the coil is, but some times there is no cure due to very small braiding of the copper wire any attempt to solder may cause damage and breakage,
You may be able to replace the coil with another one from a good components store with the same value best thing is to take out the noisy coil and take it down to be replaced
the reason it appears worse when first turn one is that the coil is cold and vibrates alot more just like when the set is warm the coil expands like most metals do which stops it vibrating so much
i hope this helps a little good luck
Feb 05, 2009 | GE Televison & Video
An Annoying High Pitch Sound
Can be either noisey yoke or noisey flyback transformer........T.
Dec 12, 2007 | RCA F32450 32" TV
High Pitch Noise
there has been a few cases of a coil in the cuircit whinning. and there is a simple fix...applying some silicone onto the coil to dampen it. the coil is ll037 on deflectin board. location m2 a black compnent with coil of copper wire wrap around it. thats my initale thought. it may be more. since you still have a picture.. any questions email me at willie@fordtv.com
Dec 10, 2007 | RCA D52W19 52" Rear Projection Television
Philips 55P8241 55" Rear Projection Television Logo
455 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
