Question about Sharp AL 1631 Copier
Copies have black lines on them after i replaced the toner
I replaced the toner and now it's making black lines on the copies. You can't even read the copies. Please help me?? Is it a bad toner?
  • Anonymous Mar 29, 2014
    started occurring after replacing toner
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Does the lines come when doing copies in the doc feeder only? or on the glass also?
if only in the doc feeder lift up doc feeder and clean the small strip of glass
Posted on Oct 30, 2008
How to remove dark background on bizhub 350
Make multiple copies of Jet black print for example, open the platen cover and then make blank copies.Print out will be jet black.After about 60 to 70 copies background will be adjusted, if not then replace the toner.After replacing the toner if the background is still there then you must replace the developer.
Feb 11, 2015 | Konica Minolta bizhub Office Equipment &...
Leaves black marks on copies
It could be leaking toner from the recovery area that sis on top of the dum, it removes any toner that was not transfered to the paper. You would have to remove it and empty out the toner.
Dec 11, 2012 | Toshiba e-Studio 232 Black and White...
SEVERAL BLACK HORIZONTAL LINES ON COPIES
You need to locate the source of strikes.
1) remove toner crg., if it has black lines or dirts on drum replace drum.
2) check/clean copy glass
3) use flash light to check fixing section ( Left sideway of copier small doors ) if damadged replace fixing assy.
Jun 30, 2010 | Canon imageCLASS D320 Digital Copier
It will not print or copy without toner lines on
Check the drum ,blade or the fuser rollers and clean or replace.
Jun 26, 2009 | Office Equipment & Supplies
Black Vertical line on copies using MFC-8660DN
Vertical lines mean it is being caused by one of the rollers within the printer. This is usually either the toner cartridge or the fuser assembly. I would try changing out the toner cartridge first even if it is new as sometimes they are DOA and they are much cheaper than the fuser assemblies. If that doesn't work, probably the fuser assembly.
Jun 05, 2009 | Brother MFC-8860DN Printer
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
Copy problems
1-if you make a copy on the glass instead of the feeder is it still there?
If no, then clean small 1" glass on copier there is a spot on it. even a pencil or pen dot WILL make a line on all copies. easiest way to find it, line up the paper on the small strip of glass and follow there will be something there ( sometimes it's hard to see since the background is black)
2- the drum has a black toner ring around it replace the drum blade or drum unit
Aug 07, 2008 | Copystar CS-2030 Copier
White line and very, very dirty copies
the nealy black copies sounds like the drum is going, try adjusting the exposure to light, if it comes out with the whole page the same way but just lighter than change drum. White line sounds like there is something on the coronas.
Jul 22, 2008 | Canon PC-940 Black and White Copier
Sharp AL 1631 Copier Logo
209 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
