Question about HP Pavilion MX70 17" CRT Monitor
Blank monitior I have HP Pavilion Mx70. When I turn the computer on the light on the monitior turns green, the screen remains blank/black and after a few seconds the little green light turns yellow as if it is in sleep mode. I have all the reovery disc, but can not do anything until I can fix the problem with the monitior. Can you help me? Thanks, Traci66
  • praul_alonso Aug 26, 2008
    the monitor not power on the light is off
  • jdpbfg Oct 23, 2008
    I had exactly the same problem which was solved by disconnecting the cable to the computer and then reconnecting. There was, however, a six week period between the two events when I was using a spare monitor.
    It was only as I was ready to try a repair shop that I decided to look on the internet. A search for "HP MX70 fault finding" led me to FixYa as being appropriate on the first page of search results. On reconnecting the MX70 I pressed the power button and it is now working OK.
I have the same problem. Do This: When you Switch-Off the Monitor, there should be a small Click/Zip sound a second after the screen goes blank. Lets Call this as "A". Solution 1: Switch "Off" the Monitor & then Turn it "On" after 'A'. Repeat this till you get correct picture. Solution 2: Switch "Off" the Monitor & then Turn it "On" (after 'A' ofcourse) while holding the (+) button on the Monitor. This also Resets the Monitor to Factory-Settings. Solution 3: Try rapidly switching between various combinations of the Desktop Resolution, Adapter Refresh Rate & Color Depth Settings. Solution 4: Give Sharp but Careful taps with Soft part of your palm on the sides & top of the monitor when it is "On" & Do Solution 1. Believe it or not, It Works. Nikhil David, Mumbai-India.
Posted on Apr 18, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 125 Answers
This is a easy one. It happened to me once. If this ever happens again, push and hold the power button until the light on it turns off then turn it on again. It should work.
Posted on Sep 11, 2007
  • Cory5468
    Cory5468 Mar 20, 2008
    sry, actually, you hold the computer power button, not the monitor power button.
    Problem Solver:
  • 12 Answers
There is probably some electronic malfunctions inside your monitor. Since I will not be able to actually check your monitor, the best solution for this is bring your monitor to a qualified TV/CRT technician in your area for proper diagnosis. He's the right expert and the second opinion to that kind of problem. Problems regarding inside the monitor are usually not fix-it-yourself kind of thing for non-expert like you compared to software problem, which can be mostly fix by yourself guided by an expert.
Posted on Apr 04, 2007
Hi! I have HP pavilion dv1000 that works fine until just this Thanksgiving (Nov.2th) when i turned the computer the screen is just blank or black but it is still working. I am able to use the computer now...
Unfortuntly sounds like your screen went bad.
Sorry I can't give you any better help with this one, it can be fixed, just going to cost you around $100.. for new screen.
Sorry
Nov 27, 2010 | HP Pavilion dv1000 Notebook
BLANK SCREEN
? try removing the battery and then connect the adapter to turn on the computer
? if it is turning on then disconnect the cable and hold down the power button for 2 mins and try turning on the compute
Mar 13, 2010 | HP Pavilion TX2000Z Notebook
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
Hi, I have an HP Pavilion DV7 laptop. When I turn on the computer everything seems to be working but the screen is blank. Blank meaning black and/or colorless without light. Thanks!
Borrow a monitor and plug it into the side of the notebook to verify that the computer still works. If it does then the screen has gone out.
Jan 28, 2010 | HP Pavilion dv6000z Notebook
Computer on, screen blank and wireless unresponsive
YUP... sound like a motherboard problem. Could be a short somewhere. Try taking the Battery out and also the hard drive and put them back again. I have fixed such problems before by doing just that. GOOD LUCK !!
Jul 06, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion laptop screen has gone black/blank
No it suggests you have a bad screen and it needs replaced
Jun 22, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor won't come on right away
Sounds like the CRT is starting to go bad cause its taking longer and longer for it to boot up. CRT's aren't available now so a new monitor would be the only option.
Apr 09, 2009 | HP Pavilion MX70 17" CRT Monitor
SVA Color TFT LCD is white on start up but goes blank.
when i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Jan 16, 2009 | Computers & Internet
Blank screen. Remains blank
Power down, remove the battery, remove the power plug. Hold down the power button for at least 30 seconds. Remove and reinstall the memory module(s). Re install the power plug and try to power back up and see if it works. If it does, reinstall the battery ad you're done. If not, get back to me for some more ideas and further diagnosis.
Thanks and have a good day!
Ron
Dec 15, 2008 | HP Hewlett Packard Pavilion dv6355US PC...
Hp pavilion dv6000 screen goes blank 5 minutes after startup
i cannot install win xp on my hp pavalion it is already contain win vista and hard disc is SATA type give me a solution
Sep 08, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion MX70 17" CRT Monitor Logo
257 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
