Question about Baby Lock Eclipse Serger
I have a baby lock imagine machine. I'm sewing with streatch velvet, and the stitches are off the fabric, or the loopers are too loose. I tried tighting the looper thread fine tuning screw, adjusting the stitch length and width. I'm getting frustrated. Is there a good setting for the fabric? It doesn't really say in the manual. Could I need a new cutting blade? It doesn't seem to be not cutting. I got it serviced a year ago, and they replaced the lower looper.
  • 4 Answers
Stretch fabric is made for using the differential feed on your machine, sergers love stretchy things. Try widening the stitch you are using and turn your differential feed down one notch to allow the machine to get a good grip on the fabric, you may need to bump the differential feed up more if it still doesn't stitch nice, keep trying on a piece of scrap fabric of the same as you are using until you are happy with the stitch.Another solution is to put some lightweight tissue paper under the seams and then tear it off after you have sewn the seams, this works but will dull your blades over time.
Posted on Dec 07, 2008
What is an error 5 on baby lock Grace
try adjusting the top thread tension
also try changing the needle-one that is for the fabric and thread
if that doesn't help, then a repair shop would be a good idea
Apr 05, 2014 | Baby Lock Sewing Machines
Machine Lock Button Release Lever Issues
If you are trying to release the looper back for threading, the loopers have to be in a certain position, otherwise they will not release.Usually, the looper must be in the farthest position to the right, then they should be able to release.
Jan 26, 2014 | Baby Lock Imagine
Baby lock quest
The top thread is looping right? This particular machine loves a well oiled hook system, and it needs to be vacuumed out regularly. Compressed air is not good on this machine, actually it is not good on any machine if the covers are on. So check for thread trapped inside the hook system by flooding with oil and oscillating the machine back and forth for a few minutes.
Two other possibles: something is snagging the top thread like thread trapped inside the hook system or a little burr on the stitch plate. Moving faster means the fabric tractors harder, so any burrs will be mre noticeable.
Dec 03, 2013 | Baby Lock Imagine
Left needle on baby lock serger "imagine" skips
Change needles if they have done a few hours. Ales use ballpoint if seaming stretch fabrics. Also you can get EL 705 needles, which have a longer scarf (groove at back) which helps with the loopers catching the needle thread. Or SUK is the stretch type with this longer scarf Also if you are using cheaper thread cones, try a better quality with smoother finish and consistent weight, this will help too. However if this doesn't resolve issue, your looper timing might need adjustment.
Oct 28, 2011 | Baby Lock Imagine
I am not getting an even rolled hem on a heavier fabric. I am only using 3 cones of Maxi Lock.
You can not do a rolled hem on heavier material. It is only for thin cloth. You have to do a 3 thread narrow edge on heavier cloth.
Aug 02, 2011 | Baby Lock Imagine
I cannot get the tension right? Also, trying rolled hem with 3 needles...tension too loose.
Rolled hem would be one needle and two loopers, is this what you meant?
Make sure you move the blade to right so that you are cutting wider than the stitch being formed, you want the fabric to roll to the underside inside the stitch.
I would set top looper tension to 3 and bottom looper tension to 6 first off (needle at five, normal tension) first off and test serge with the stitch length at normal 2 or so, so you can see if the fabric is rolling under for you. There is proabably a stitch finger in the throat that you need to change too, sometimes its on the foot, (change with a screwdriver) and sometimes just a finger down on the needle plate.
Then adjust the two looper tensions making lower thread nestle up against the needle on the bottom of the stitch, and the top looper thread wrapping right over to bottom as well. Once this is happening, then turn stitch length down to close up the stitches.
It does depend on the weight of fabric too, and if you want to seam curves.
I find its best done with wooly overlock thread on top looper to "fill" in the overlocking appearance and fully cover the fabric.
I hope this is of help, if the tensions just wont behave then one of them might be faulty and machine need a service, I get mine done at least every 2 years to keep timing and tensions right.
May 26, 2011 | New Home 104D Mechanical Sewing Machine
I have a babylock imagine overlocker and what looks like the lower looper is puckering. I have some pictures available to best understand what I am refering to if this would help.
I have the same problem with my Imagine and am trying to find someone with some real knowledge. I think the problem is that the forks holding the thread are not opening up as wide as the stitch width and this causes puckering. if you serge just off the material your stitch will probably be perfect but your blades will not touch the fabric. My sewing repair shop thinks I used my machine too much and that I should send it to babylock which would cost 500 to 600 . How silly is that. I am trying to find out how to adjust the forks or someone who can do it for me. If you find something please post answer.
Dec 28, 2010 | Baby Lock Imagine
Baby lock Imagine Serger - Can anyone tell me how to fix this problem. The force air threader (looper) will not push the thread all the way through
I "THINK" I have my machine threaded properly but it will not make a chain stitch. I followed the thread guide for the narrow three spool set up with the right needle setting.
why would the machine not catch the chain ????
Dec 12, 2010 | Baby Lock Imagine
I cannot find instructions on how to gather/ruffle with my imagine wave babylock overlocker, please help.I need to know what settings and how many threads to use etc.
I do not have the Wave, but in the manual for my Imagine, on page 17, it states:
"at the maximum setting of 2.0 the differential feed can gather lightweight fabric to nearly double fullness.
To maximize the gathering effects, use the longest stitch length setting."
There is no indication as to the number of threads to use, but in the picture, it appears to be four.
I would use scraps of the same fabric to be ruffled and test this technique until I achieved the preferred look.
Feb 25, 2010 | Baby Lock Imagine
Does not stitch lower thread
Make sure when you thread the machine you have the thread seated into the tension assembly on top, then make sure you have the threading ports locked and the switch in the proper place for each looper threading, the machine will only partially thread if you do not have the port locked and it will even still sew although not properly.
May 25, 2008 | Baby Lock Imagine
Sewing Machines Logo
212 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
