Question about Cooktops
The printed readout lights read set 8888 set 8888 but no touch buttens work
It' a G.E. ser# fv39816q mod# jds2680w2wh the oven don't work at all. the control panel has all the lights on BUT the control pad dose not respond to anything
Wolf electric cooktop... several seconds after turning a burner on the unit goes to lock mode
Posted on Nov 01, 2008
Propane oven won't light
Can you post more details like: Does the oven ignitor come on (glow orange)? Can you hear the oven gas valve click open and/or smell gas? Do all the stovetop burners work fine? Have you checked your propane tank to be sure you are not out of gas?
Mar 13, 2014 | Amana AGR4433XD 30" Freestanding Gas Range...
Maytag precision touch control 500 electric smoothtop
The heating coils in the oven need to be inspected very carefully where they plug in to the oven wall. You will need to remove the back covers and check the insulators and wiring harnesses. Over time the insulation can break down and oxidize the metal connections. You can use a voltmeter or test light to verify that the coils are getting voltage from the thermostat/switch. replacing parts is cheaper than buying new if you can find the parts.
Oct 04, 2017 | Cooktops
I can not start the oven. The gas is on and the cooktop is fine.
The oven either has a pilot light to be lit before the oven will work or you need to light the burner each time you use it. Check your owner's manual or find the owner's manual on line and read it!
Dec 26, 2012 | Cooktops
Error :8888 in bajaj induction cooktop
Error code: 8888 on my new induction stove please what is the solution.
Nov 18, 2012 | Cooktops
I had new countertops put in and they took they drop in stove out. When complete tegy put the stove back in and everything worked fine. Within 5 minutes the control panel went off. Oven light works and...
The control panel must be on and in manual mode for the oven to work. Turn the power off for a moment and then back on. If the panel starts to flash, set the time and set it to manual and the oven should work. If the panel does not light up it is faulty and requires replacement.
Feb 26, 2011 | Frigidaire Cooktops
The left top element is not working, the control knob lights up but doesn't heat. Is it the element or the switch? Mod#JED8430BDB Ser#1414040011A Schott Ceran
It could be either. The only way to properly check is by dismantling the cooktop and checking the circuit with a volt meter or test lamps.
Feb 11, 2011 | Jenn-Air JED8430 Electric Cooktop
The power went out and then the elements and oven would not work but there was power to the clock?
This solution only really applies to oven elements only. I haven't experienced it with hotplate elements as they are not normally controlled by the timer. When you have an electronic timer and there is a blackout the timer normally reverts to auto. function when the power comes back on. You have to set it back to manual before the oven will work. Turn the oven element to ON and the set it to manual. The oven element indicator light will light and the oven will work.
Feb 06, 2011 | Stoves 23 in. Premier TC600I Electric...
-F1-
F1 for Magic Chef means there is a problem with the control board or the touch pad to the board.  I would need the entire model # on sticker on the oven to see what parts are on this one.  If the touch pad is separate it will have a ribbon that goes from it to the board.  Unplug that ribbon, if the code goes away then the touchpad is the problem.  If the code stays with the ribbon unplugged then the control board is bad.  Make sure power is off to unit when touching anything!
Oct 12, 2007 | Cooktops
Cooktops Logo
244 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
