Question about Pioneer DEH-P2500 CD Player
DEH-P2500 Not Working At All
I hade this radio in my old car and decided to put it into my altima. i end up having to tak it back out cuz i forgot to put something in it and when i was taking it out i accidently pulled the blue remote to antenna unbinding and it came lose.......n e ways after i fixed it back up and hooked the cables back together i tried to turn it back on and nothing happen; it seems like no power is going to it cuz not one button is working including the eject cd one.
    Problem Solver:
  • 5 Answers
I have the same unit i put it in my jeep wrangler had problems as far as which 2 hot wires need to be hooked up. finnally figured it out. take it out hook up the hot wire and ground straight to the battery, it should come on if it does come on then you have a problem in the wiring from the dash, to make sure the wiring in the dash is good you should check your fuses first, then do a continuity test with a volt meter to check for a break in the wire wether it being ground or hot. weed out the simple problems first. if your head unit does not come on from direct hook up to the battery then the problem exist in your head unit
Posted on Sep 24, 2008
Can I play a burned mp3 disc on my pioneer deh-p2500?
The specs don't mention MP3 anywhere, so the answer most probably is "No".
Apr 19, 2012 | Pioneer DEH-P2500 CD Player
Where is the reset button on the pioneer deh-p2500
there is no reset button on most pioneer cd players only pioneers that carry reset buttons are the in dash or double din players that play dvd's
Apr 15, 2012 | Pioneer DEH-P2500 CD Player
Lost wiring diagram deh-p2500 pioneer
If you going to install it, I recommend getting a wiring harness for the vehicle you are putting it in. The harness package will have the color code on it. All aftermarket radios have standardized wire color coding.
Aug 26, 2011 | Car Audio & Video
I have a p2500 and its great. Can I connect my red and white audio cord attached to my ipod to the red/white jacks on back of radio? then listen thru aux?
Those cables are for audio out only you need an IP Bus adapter to connect the AUX input. the CDRB20 or CDRB10 is what you need. the CDRB20 allows for more inputs as well such as CD changers, and XM radio tuners.
Mar 13, 2011 | Pioneer DEH-P2500 CD Player
I just bought this truck with a pioneer DEH-P2500 radio and I don't know how to set the clock
According to the user's manual the following procedure is used to set the clock.
Manual is at this link http://www.retrevo.com/support/Pioneer-DEH-P2500-Car-Receivers-manual/id/23227dj392/t/2/
Here's the procedure indicated in the manual
1 Press SOURCE and hold until the unit turns off.
2. Press FUNCTION and hold until the clock appears in the display.
3. Press FUNCTION to select clock.
4. Press the Left Triangle or Right Triangle to select the segment of the clock display you wish to set.
5. Press the Up or Down Triangle button to change the digit up or down.
Jan 12, 2011 | Pioneer DEH-P2500 CD Player
Cant set the clock on deh p2500
Hold down the green button till its shuts off then press it again till you see the clock come on you will see (( )) on both sides of the clock then you move the tuner buttons up or down to change the time !
Jan 04, 2011 | Pioneer DEH-P2500 CD Player
I need a wiring diagram for deh-p400, the old one...
No diagram available for 10yr old head...sorry:o(
Other than that, it should be easy to hook it up, I'm sure there's no sub-outs etc. Should have 4 sets of speaker wires bundled together coming out of the back of the radio chassis. Yellow, is switched power...all the speaker wires have a stripe on one of each of the two wires, thats the "common" wire. White is ground for the chassis.
Good Luck
Jun 14, 2009 | Pioneer DEH-P4000UB CD Player
No power to my player
A Pioneer DEH-P2500 power wiring would include:
* Black - chassis/body ground (GND)
* Yellow - always on B+12 such as the + terminal of the battery;
* Red - switched on B+12 such as the ACC terminal of the IGN switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 21, 2008 | Pioneer DEH-P2500 CD Player
Wiring 6 X 9 Speakers
hi,
i m Ritesh Upadhyay , there is no sound driver in my computer.
so i want to download it.
Feb 18, 2008 | Pioneer DEH-P2500 CD Player
Pioneer DEH-P2500 CD Player Logo
122 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
