Hello i have 2 pcs and i have my rounter wired up to my modem andand to the 2nd pc downstairs but when i try to go on online gaming there not resonding but when i take the router out i get everything. i was told i would need to disable the firwall on the router.
  • 550 Answers
BELLS RED FLAGS ALARMS WHISTLES WARNINGS
a site that requires you shut down protection,
has some intent of using that lack of protection.
usually its something nasty
online gaming should not require more than the opening of the NAT in the router to the address of the game host.
check the settings of the router many have prewritten rules for the major game hosts, that just need to have the checkbox marked.
I have 3 sons with different online gaming and have not had to disable the firewall
using the routers built in menu, cant tell you the address beyound 192.168.0.* because no details on router model, you can enable gaming mode, and leave the firewall intact.
goto the manufacturer(router) webpage and check the FAQ for your router
Posted on Oct 30, 2008
Tip
Using Zyxel P-600 from two PCs
to use Zyxel router/modem from two pcs for internet usage : it has two ports 1 is USB 2nd is Rj-45 connector LAN port
connect it with one pc via USB cable and connect 2nd via LAN port using Cross cable then its one DSL connection from two PCs.
i am using it and it working good.
on Apr 20, 2010 | Computers & Internet
Just got wireless and my first system update for ps3 wont work,it keeps showing 80710723.kind regards jack
1st When you test your connection when it shows you NAT Type, make sure its Type 2 any other will have certain conflicts with PSN and online gaming. If its not Type 2 I recommend doing a factory reset on your modem/router.
2nd If you have the recources try hooking it up wired and see if you have the same problem.
3rd Try downloading the update via your PC to usb flash drive and then plugging the flash drive into one of the usb ports on your PS3.
Good Luck!
Feb 19, 2011 | Sony Playstation 3 (PS3) Console
Hi my name is tam. I am using the Net gear WGR614 v5 and my laptop is using window 7. But i can't connect to internet via the wireless rounter netgear. The internet light was on but the wifi light is keep...
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 23, 2010 | NetGear WGR614 Wireless Router
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
My internet keeps disconnecting
It sounds like the wire from your house to the isp switch is faulty you should probably call them down to fix. Or it could just be the modem are you using the same modem for both computers? If so then that's probably the problem.
Mar 14, 2009 | Belkin (F5D7050) 802.11a/g/b Wireless...
Router problem
try to disable any firewall you have, disable windows firewall if its enable and try to lower your Internet Security or use default if set to custom.
Nov 24, 2008 | 3Com OfficeConnect ISDN Lan Modem Router
WIRELESS PCI 54M G NETWORK LAN ADAPTER CARD 802.11 b/g INSTALLATION
try to unplug it all modem roughter then modem roughter computer on see if its working do repair also thx nick
Feb 05, 2008 | Computers & Internet
Help
http://www.askdavetaylor.com/connect_to_the_internet_with_my_sony_psp.html
Jan 17, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
