Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Compressor makes a loud grumble an vibrates when it shuts off
When the compressor turns off it vibrates more than normal and makes a loud sound.
I have checked the hold down nuts and the compressor is secure but it still vibrates haeavily.
Phil
  • 59 Answers
There are springs inside the compressor that suspend the motor. When one or more of those springs break then the motor will knock against the casing when it shuts down and loses centrifuge motion. The compressor will continue to run up until the point the it beats itself to death, which could be next week of next year. There's no way to tell. The only solution is to replace the compressor.
Posted on Nov 02, 2008
  • jafishing22 Apr 08, 2012
    You can loosen three of the compressor bolts and let the compressor rock more freely. It does hush it up some/ Joseph A
Mini fridge compressor makes noise when shutting off
Hello, This is normal. The compressor inside the shell is mounted on spring standoffs. It will move around when shutting off and can hit the inside of the compressor shell or will do the same if the unit is moved around. Nothing to worry about.
Apr 09, 2014 | Refrigerators
Dometic roof top AC unit compressor turns on even if T-stat is off. Only way to get the compressor from turning on is to turn the breaker off. Unhooked T-stat wires to see if issue was there but the...
Sounds like you may have a couple of problems there. First, have you checked incoming voltage to make sure you are getting 100-120 VAC at the AC control board in ceiling? If that's ok, try removing/disconnecting Ac compressor wire at ceiling control box and see if compressor shuts off then. May be a capacitor for compressor going or shot, and possibly relay in control box sticking, or bad wiring to thermostat. Have you had any lightning in the area prior to all this happening?
Jan 23, 2013 | Dometic Rooftop RV Air Conditioner
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
Compressor makes brief but loud rattling noise when it shuts off. Other than that the refrigerator is operating properly.
There are rubber shock mounts between the bottom of the compressor and the fridge frame, if any of these are worn it can cause that sound. Sometimes the condensate tray is what is actually making the noise; when the compressor powers down it vibrates and causes the metal tray to shake, maybe bumping the side and creating the noice. Pull the fridge off the wall and take the cover off the back of the fridge. Be careful, there's some voltage going through there. Locate the condenstae tray, shake it gently and see if it's loose. Give the compressor a gentle push and see if that makes the sound. Usually it's one of those two things and not an actual problem with the unit. When you touch the compressor, be careful, they can get pretty hot.
Jan 03, 2011 | Kenmore Refrigerators
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
A loud vibrating sound
Bad compressor, if the compressor is going bad or the bolts that hold the compressor in place are loose. Check to make sure the bolts are tight. If not check the compressor with your hand and see how much it vibrates.
Jan 02, 2010 | Kenmore 53642 / 53644 Side by Side...
Refrigerator Compressor has loud vibration
Clean the coils. what you are hearing is the valves as the pressure equqlizes. Also make sure that the fan by compressor is on while compressor is running.
Mar 28, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Whirlpool top freezer refrigerator- compressor makes a loud noise
The compressor is that black casing you see at the bottom of your refrigerator - inside this sealed case is the motor assembly which stits on 3 or 4 springs that act like a cushion - you have a little gap at the bottom where the lubricating oil is present. Your springs have likely worn out and when the compressor shuts off the assembly is banging against the rigid casing make that loud "klonk" or bang noise. It IS normal for compressor to make some faint "tick-tick-tick...tick.....tick" when shutting off, but loud banging, bell sounds, etc, means the assembly is banging on the case from the inside - you can indeed live with the noise, your compressor will function normally, probably for months, or even years - it can also keep wearing out and one day the noise might get very loud (like a very high humming noise) - There is NOTHING that can be fixed, you either pay $400+ to change the compressor or buy a new refrigerator - If you DO replace a compressor usually the replacement will be noisier - Keep a thermostat inside your refrigerator at all time to make sure your compressor is still keeping your refrigerator and freezer cool.
Mar 20, 2009 | Refrigerators
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
174 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
