Question about Garden
Your grass trimmer
Hi, I was glad to help with your trimmer.
If you have any further need of help on this. Use the Ask Me button to inquire. I'll be glad to help with no charge to you.
Regards,
Worldvet
  • Harry699 Jan 25, 2009
    toro gas weed trimmer has spark, won't start
4 Suggested Answers
  • 36 Answers
SOURCE: grass hog 18v nst2018 trimmer
After reading all of the reviews on Sears.com, it seems these batteries require charging and discharging 3-5 times before they hold a full charge.
All of the reviews mentioned this; they said it lasted 5-10 mins the first few times, but then they suddenly got 30-50 mins per charge after the 3rd to 5th charging.
Posted on Sep 19, 2009
rycgl
  • 1545 Answers
SOURCE: how to put together a black n decker grass
No, it is not heavy duty enough to drive a blade. It should have cuttting line in it and it only can use up to .065" string (factory recommended).
Posted on Oct 12, 2010
How do I find a detailed diagram of a Murray string grass trimmer CARBURETOR/
Hi Patrick,
If you hit the link below and scroll toward the bottom of page you will find videos that should be very helpful.
http://www.ereplacementparts.com/mtd-m2500-41adz01c758-gas-trimmer-parts-c-20039_20040_299701.html
Good Luck!
Mar 22, 2016 | Garden
I used it yesterday and today it will not start. Battery is full charge. Button key is in place.
I would first take a meter and test that the battery actually charged. If that tests out fine ( should read at about 12.8 to 13.5 Vdc), I would then check all the wired connections to make sure they did not come loose.
Jul 19, 2015 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
How to rethread spool on black and decker grass hog cordless trimer
with fine file , refurbish male threads.
determine the female threads with magnifying glass to determine damage to female threads. female threads can be repaired with a die from OSH or H/D. ask for help to find the right thread pattern or take them both to the hardware store to get the right die
May 29, 2014 | Black & Decker 14" Grass Hog Xp...
When my flymo lite 250 engine is running the end does not turn to cut the grass
Could be anything from a stripped drive shaft to a loose or stripped trimmer head. You'll probably need to take it to a repair shop to have them diagnose the problem and locate the replacement parts if it's anything other than a stripped trimmer head bolt.
Nov 01, 2011 | Homelite Mighty Lite Lawn Trimmer
The head of the trimmer will not turn. What could be common issues as a result?
Sometimes, strands of long grass wrapped around the shaft above the string head impede movement. On a more serious note, the driveshaft could be broken, or the clutch assembly could have malfunctioned. Disassembly will be required if tangled up grass above the head is NOT the problem.You can get help here to do the disassembly and repairs here, just ask!
Jul 01, 2011 | Echo Rapid Loader, Trimmer Head
Worx WG150 Cordless Grass Trimmer spool nut keeps falling off
Thanks for update. Glad you got some resolution.
Would you mind rating my response?
thanks...
Charlie
May 29, 2009 | Worx GT WG150 10 in. 18 Volt Cordless...
Garden Logo
315 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
