Question about Compaq Presario 700 470024-192 Notebook
Presario c700 my computer everything was ok but everytime i touch the board in left side of laptop suddenly everything turn it of including the power adaptor, so it is a big problem, thanks
  • 32 Answers
I think by doing that you interrupt the contact of the power connector or you touch something on the board which you shouldn't.
Posted on Oct 30, 2008
With Windows Vista installed on my Compaq Presario C700, when watching videos or keeping the laptop untouched for approximately 130 seconds, the screen always goes black but audio still plays, until I
first check the power option in control panel disable,increase or decrease time of your choice.if this solve your problem then ok but not so there is an problem with BGA CHIP.
Jun 12, 2012 | Compaq Presario C700 Series Laptop...
My c700 series laptop has a problem in the connection of the TFT to the motherboard. Screen, cable, inverter seem to be ok. (checked with second, known working, complete lid + screen, these give the same...
Hey guys I have all motherboard drivers solutions and computer/laptop hardware and software solution so if you have any problem so plzz contact our help line no.09371409266 you get the best solution
Mar 08, 2011 | Compaq Presario C700 Series Laptop...
Whats the best cooling system for my compaq presario c700 notebook pc product no 89578-oem7332157-00061 thank you
The on-board cooling system should work just fine. There are some aftermarket devices that the laptop sits on. They have fans in them and direct air up into the computer. You'll have to find one that suits your needs.
Jan 22, 2011 | Compaq Presario C700 Series Laptop...
Compaq presario c700 laptop- unable to turn on laptop
U may have a dead board. They average $285 plus labor. A shop should be able to test it on a volt meter see if the power grid is burnt for around $35. then u will know what ur in for. If its a bad board just replace the laptop I wouldnt repair that problem on an older laptop.
Jun 24, 2010 | Compaq Presario 700 470024-192 Notebook
C700 laptop's display problem
I have the same issue.
Problem appears only while working with power adapter.
When I turn off power adapter (so notebook is working with battary) everything is OK.
It is somehow connected with shutting down. If disconnect power adapter durring shutting down - next time you will have problems with grey screen.
Don't know how to fix it.
Usually solve by making several reboots and to turning on/off power adapter.
Apr 23, 2010 | Compaq Presario 700 470024-192 Notebook
Both the buttons of my Compaq Presario C700 touchpad stopped working all of a sudden.
You have perhaps a CD for your presario Compaq computer. Try to insert that in your CD rom and look for the touch pad to enable. Or just look for the touch pad in your device manager and enable it. To open the device manager, right click computer and go to properties and click hardware then click device manager. If touch pad is in the list enable it.
Thanks...
Dec 10, 2009 | HP Compaq Presario C700T
I can't turn on my presario C700 laptop, battery is 100%
Do power drain
step 1: remove battery and ac adapter from your laptop
step2: hold power button for 30second-1minute
step3: now put back battery and ac adapter
step4: now power on you sud be on
give a try hope it helps u
Feb 21, 2009 | Compaq Presario 700 470024-192 Notebook
I ve compaq c700 c772tu lap top...it does not have wifi software
You should be able to download drivers (the programs that make the hardware work) from Compaq from this site. You'll have to transfer them to the laptop via flash drive or other such device, and run each file needed individually, following any instructions. To be sure that you have drivers for everything installed, you can right-click on "My Computer" and select "Manage," then go to "device manager" on the left pane, which will show you all the hardware that windows sees attached. Anything with a yellow exclamation mark (probably) needs a driver - double click on it to see more information.
Jan 17, 2009 | Compaq Presario C700T Notebook
Compaq presario c700 all driver wanted
If you are purchasing the laptop from a retailer, there will most likely be a disk with the laptop (sometimes called a Restoration Disk) that contains everything that will wipe the hard drive and reinstall everything so it is back to how it left the manufacturer. If it didn't come with any disks, I have found:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=3466274
Just click the exact model, then OS and then they will give you a list of (I think) all the drivers you should need for a Compaq Presario c700.
Aug 10, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 470024-192 Notebook Logo
42 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
