Question about SanDisk Sansa e260 MP3 Player
Black screen My sansa e260 mp3 player was on MTP mode i pulled the USB out of the computer and the mp3 still was writing i tryed turning it off but it froze so i took the battery out and put it back in. I turned the player back on but the screen turned black
  • Sassy Jassy Dec 28, 2008
    my mp3 froze on the please wait screen...so I just put it in my purse. when I got it out the next day it was shutting down. so I put it on the charger, but the screen didn't appear but the lights were on and its still doing it right now... How do I fix it???
  • 758 Answers
It sounds like the device is defective..Please call sandisk so they can setup a RMA return for you..
1-866-SANDISK (726-3475)
7 days a week:
4am. - 10pm. Pacific Standard Time
7am - 1am Eastern Standard Time
Posted on Nov 03, 2008
Trying to add 4 GB microSDHC card to sandisk sansa e260. connect e260 to computer via USB. insert micro card. computer does not recognize microcard. why?
The player automatically connects to the computer in Media Transfer Protocol mode (MTP mode).
For accessing the microSD card in the player, the USB connection in the player has to be set to MSC mode, see:
http://kb.sandisk.com/app/answers/detail/a_id/167
How to change USB mode for the e200 series, proceed as next:
1. From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC.
Manuals for the e200 series:
version 1:
http://mp3support.sandisk.com/downloads/um/e200v1_userguide_en.pdf
version 2:
http://mp3support.sandisk.com/downloads/um/e200v2_userguide_en.pdf
version R, Rhapsody:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Nov 21, 2009 | SanDisk Sansa e260 MP3 Player
My sansa e260 v2 is not dettedcted by my pc
If its working fine then goto settings and change the USB mode to MSC rather than MTP otherwise you can also try updating your windows media player to 10 or above to support MTP devices.
Sep 01, 2009 | SanDisk Sansa e260 MP3 Player
No USB mode on my sansa e260
I think this is what you are asking. Forgive me if I didn't understand the question correctly.
Switch on the mp3 player. Select "Settings", scroll to "USB Mode" and make sure that "MSC", not "MTP" is selected.
When you next plug in the USB connector, your PC should recognize the Sansa as a standard USB device.
Apr 07, 2009 | SanDisk Sansa e260 MP3 Player
My screen is black
Download the Sansa Recovery Tool for the Sansa e200 series and run the official Sansa Recovery Mode
or
Run Windows Recovery Mode
Try this: disconnect the player from the computer, turn it off, hold in the REC button, and reconnect the player to the computer while holding the REC button in. Keep holding the REC button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Mar 16, 2009 | SanDisk Sansa e260 MP3 Player
Computer(s) wont recognize sansa e260
i have the same SANSA e260.....and the same problem....its easy just turn on your sansa then push the menu botton, slide the wheel in the center and at the end of the options say USB enter there and change usb mode from MTP to MSC mode.....and ready
Jan 02, 2009 | SanDisk Sansa e260 MP3 Player
MTP Mode Doesnt Work
Try uninstalling MTP Mode in the Windows Device Manager, and replugging the player - set the menu setting in the Sansa itself to "auto" for USB Mode before replugging. Let me know how it works.
Jun 13, 2008 | SanDisk Sansa e260 MP3 Player
MY sansa e260 MP3 player
Try to add the device manually.
Plug the player in while it’s set to "MTP" mode. (This selection is in the Settings area)
On your computer, open Device Manager, and select: Add Hardware.
Choose the "already connected the hardware" option.
From list, choose "Add a new hardware device".
Select: "Install the hardware that I manually select from a list."
Select: Portable Devices, then MTP device.
Hope it works for you.
Dec 31, 2007 | SanDisk Sansa e250 MP3 Player
Computer doesn't detect device in MTP mode
If you are using a front USB port on your computer, try using One in the rear that is connected directly to the motherboard. It worked on mine!
Jan 03, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e260 says connected but device not recognized
I agree with the above suggestion. Try setting the USB Mode under "Settings" on "MSC" on the Sansa. My computer would not recognize the e260 when the mode was set to "MTP"; works fine on "MSC".
Dec 27, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
50 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
