Question about Mitsubishi WS-55807 TV
Convergent red does not align
While using the Converging buttons. The Blue shifts normally, however the Red will only move vertically. It will not move horizonally. When I go to advanced Convergence, the same occurs: I can align the horizontal, but not the vertical.
My guess it is internal, but what else can I say. Would you provide a solution or an explanation.
Thanks
  • rbigshow116 Nov 02, 2008
    I have the exact same prolem
  • 934 Answers
Convergence amp clearly need to be replaced, STK392-570 Sanyo originals. They are two large multi-pin Ic's at locations Ic801 and Ic802. Also check the small 5 amp pico fuses at F9a04 and F9a05 for open and replace them as well if they are.
Bill
Posted on Nov 03, 2008
I have sony tv kp-65wv600. It has problems. color and video is blurry, double vision, letters are curved
You have a convergence failure.
Convergence IC failure is very common. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless
Feb 24, 2011 | Televison & Video
The picture is warped red & blues distorted
Your Convergence ICs have failed. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
Note if one STK chip fails, you replace both regardless. They will be right next to each other.
Feb 20, 2011 | Toshiba 57H81 57" Rear Projection...
Tv is showing double images, not lining up
Your Convergence ICs have failed. Replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu.
Look for the converge option to align the red and blue colors
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I stumbled across a tutorial on fixing the convergence for my Sony KP-46WT510 a while ago, and now I can't find it again! Does anyone know where I can find that tutorial or one similar to it? We've been...
Here is a walk through on how to set your convergence.
A quick and easy way to try and let the TV realign the convergence try this...
1) Turn on the TV and tune to a channel and let it warm up for about a half an hour to let everything settle into its normal operating mode.
2) Press the Flash Focus button on the original TV remote. A cross pattern will show on the screen and the process is complete when the cross turns white and the TV returns to the program you were watching.
3) Do not press any other buttons until this process has completed.
If this does not adjust it enough you can adjust the convergence manually as follows:
1) Press the menu button on the original TV remote.
2) Use the arrow keys on the remote to highlight setup and press + button to select.
3) Use arrow keys to select convergence and press + button to select.
4) A pattern of white crosses appears, with a yellow [ ] around one of the
crosses. Aligned crosses (which do not need adjustment) look white and
have little or no red or blue showing. Crosses that are not aligned show
red or blue shades beyond their edges.
5) Use the arrow keys to move the [ ] to a cross that is not aligned. ***Note: start with crosses in the middle and work outward ****
*** TIP: Set the alignment while about 5 feet from TV for better results ****
6) Press the + button to select the cross and the [ ] will turn red indicating it is ready to adjust the Red convergence.
7) Use the arrow keys to move the red cross on top of the white one or at least as close as you can get it.
8) Once the Red is aligned press the + key again and the [ ] will turn blue. This indicates it is now ready to adjust the blue convergence.
9) Use the arrow keys to move the blue cross on top of the white one or at least as close as you can get it.
10) Once you have aligned the blue cross press the + button again and the [ ] should turn yellow.
11) Repeat steps 5 through 10 until all the crosses are aligned. To exit back to regular programming press the menu button on the remote.
Jan 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My tv needs to be converged but i can't
the left and right volume buttons are what move the convergence horizontally, so if they dont move you will need to replace the convergence ICs .if you need more info I will need the model number of your JVC
Mar 13, 2009 | JVC Televison & Video
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Convergence -manual
Replace the convergence amps and test and replace any or all of the 2.2ohm resistors in the yoke return path out in front of the amps. This unit takes two STK392-110 Sanyo originals, DO NOT GET CHINESE KNOCK-OFFS... Buy them from Acme sales out of Florida and you can be assured they're originals.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
Oct 11, 2008 | Toshiba 42H81 42" Rear Projection...
CRT Rear-Projection Red Vertical Alignment
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Oct 11, 2008 | Philips 51PP9200D Television
Toshiba 65H81 convergence issue
Does the blue and red crosses move at all ... eather vertically or horizontally. if they move at all then it may not be the chips.. could be a resistor. if the crosses dont move then it probally the ic. these chips run about 7 to 45 dollars apeace depending on type. at our shop we charge around 125 to put in.
Jan 15, 2008 | Toshiba 65H81 65" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Mitsubishi WS-55807 TV Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
