Question about Maytag MSD2432G Side by Side Refrigerator
Ice despensor mod.mzd 2666kew- need diagram to put back together ice auger. What order does the blandes go in?
    Problem Solver:
  • 3 Answers
Http://www.easyapplianceparts.com
Try this site for help. They have some good detailed diagrams that helped me with an issue. May do the same for you?
Posted on Nov 05, 2008
How do I replace a plastic auger with a metal auger in a Kenmore side by side?
Fridge Dispenser Auger Drum Replacement - Whirlpool ...
? 4:56
www.youtube.com/watch?v=-fUJlQ1BQcs
Apr 12, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the dispenser auger drum is when ... Whirlpool, Kenmore, KitchenAid, Roper, Estate, Maytag, Crosley, ...
Sep 23, 2015 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kkitchenaid side by side refrigerator. The ice maker stoped working, but the in door water despensor works perfectly
TRY PULLING OUT THE "ICE AUGER" AND RESETTING THE ICE MAKING UNIT ITSELF,MOTOR SHOULD RESTART AND FREEZE...UNLESS YOU RARELY USE IT,IN THAT CASE YOU MAY HAVE MOTOR ISSUE?? STAY IN TOUCH,LET ME KNOW
Jun 06, 2014 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Side by side Whirlpool refrigerator indoor ice make does not dispense ice. The freezer door stood ajar for several hours, allowing some of the ice in the storage chest to melt. The dispenser seems to be...
If you haven't already dumped all of the half-melted ice, go ahead and do that. Rinse out the ice bucket and dry it, so the ice doesn't stick together. When you put it back in the freezer, make sure it goes all the way back, so the auger engages with its drive at the back of the unit. If you hear the motor turning but no ice is moving, the auger blades may have sheared from the shaft. I had to replace the auger in my own Whirlpool for that reason. Good luck - I hope this is helpful to you.
Jul 17, 2011 | Whirlpool Refrigerators
Switch on ice maker not changing from crush ice to cube
on your ice bucket there is probably a bent thin metal bar that extends to the back of your refrigerator. if you remove the bin you will see a white plastic square hanging just behind the metal rear panel. Hold your light switch(s) closed while looking at the plastic square ahnger then give your refrigerator a "reach around" and cycle the ice dispenser in both the crushed and the cube settings. in one of the settings the square should move. if it does not.... try putting a blow dryer in front of the small square opening for about 10 minutes on high heat and repeat the process. if it still dosent move order a auger solenoid. 888-995-9956 is our number for parts (mod/ser. numbers required.) the blow dryer will probably solve the problem.
May 22, 2009 | Hotpoint Refrigerators
GE Side by Side only dispenses crushed ice
remove the ice cube tray assy, remove all the ice, save the cubes, wash the assy with warm water dry the assy, be sure the lever in the rear of this ice cube assy is moving and spring loaded, move the lever and it should snap back and return if so you know the unit is ok(the cube assy), now with the assy still out of the freezer close the freezer door and select crushed ice and push the pad where the glass normally hit to activate the ice cubes,if the operates and you here a thump and snap and hum most likely your ok,if not you could have a defective auger motor assy,but if you here all the sounds as decribed oped the freezer door and select cubed ice push actuator on despensor door with the freezer door closed, reopen and install the ice cube assy tray bucket assy,push it in firmley, and try it with some ice in the bucket you should be fine,if not replace auger motor assy..
nbcrca:)
Apr 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice despenser in side by side door, kenmore does not work
Pull the grill cover off near the floor and look to see if any of the wires have been cut. I found that the grill cover wore on the wires controlling the door functions. First the crushed ice function went, then the water dispenser went. I had splice the wires back together and am leaving the grill cover off. No problems since.
Jan 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Frigidare ice maker making slabs of ice, not cubes
Today, I removed ice maker and auger motor. Found out this morning that water was running down the back of frig. inside, everything in freezer was frozen together. Found this out after removing all food from freezer. When i looked into the ice maker where water enters, that was frozen solid. After thawing and checking everthing. I put it back together in freezer. It is nine oclock now, and I do have cubes. I really can't tell you what I did, except thaw it all out. It's been running for four hours now and it seems to be all right.
Nov 16, 2008 | Frigidaire Dryers
Icemaker auger
To see how the auger goes back together, go the the Sears parts web site and put in your model number. It will show the parts list and a diagram. You may be able to print it out, Don't remember if there is a print option or not but if you have a screen capture program you could also.
Apr 13, 2008 | Whirlpool EL7ATRR Refrigerator
Maytag MSD2432G Side by Side Refrigerator Logo
108 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
