Question about HP PSC 1315 All-In-One InkJet Printer
DISK WON'T LOAD, TURN ON AND ALL THE LIGHTS CONSTANTLY BLINK
TRIED REINSTALLING THE DISK, WHEN IT GETS TO TURN ON PRINTER LIGHTS CONSTANTLY BLINK.
tommylkns@gmail.com
  • telkins Oct 31, 2008
    This time it says it loaded the disk successfully, but when you go to view installed printers it is not there. The thing that gets me the most is when I turn the printer on all the lights constantly blink.
    Genius:
  • 1,124 Answers
Clear any paper or carriage path obstructions Right-click the link below to open a new browser window with specific instructions about how to clear paper jams. When you have completed paper jam removal instructions, return to this point in these instructions to continue resolving a carriage stall. Click here for information on resolving paper jams (c00095617).
  1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
  2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
  3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
  4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You may have to reach through the output paper tray to access the print carriage.
  5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
  6. Press the On button to turn on the product.
Plug the product directly into a wall outlet Follow these steps to make sure that the product is correctly connected to a suitable power source.
  1. Make sure that the computer and the HP All-in-One both have a three-prong power plug.
  2. Remove the power cord from any power strips or surge suppressors, and plug it directly into a grounded wall outlet.
Perform a partial reset A partial reset will return user settings to factory defaults. On some models, language and country/region settings are also reset. Perform a partial reset of the product by following the instructions below.
  1. Unplug the power cord from the unit.
  2. Reconnect the power cord into the unit.
  3. When the lights begin to flash, press and hold the On/Resume and Paper Size buttons.
  4. When only the On/Resume light is flashing, release the buttons. When the On/Resume light is steady, the reset is complete.
  5. Try the print job again to see if this step resolved the issue.
    • If the issue is resolved , you do not need to continue with the rest of the instructions on this page.
    • If the issue is not resolved , continue to the next step.
Remove and re-install the print cartridges Improper placement or installation of the product's print cartridges can cause the product to indicate a carriage stall error condition. Ensure correct installation of the print cartridges by following the instructions below.
  1. With the printer plugged in and turned on, open the cartridge access door (see the illustration). After a moment, the print carriage should come to the center. The print cartridge carriage is the plastic part that holds the print cartridges. When the carriage is at the center of the access area, unplug the printer.
  2. Remove the cartridges from the carriage and check them for damage. Check for obstructions under and around the carriage. Replace any damaged cartridges.
  3. Reinstall the print cartridges.
    • The black or photo cartridge goes on the right.
    • The tri-color cartridge goes on the left.
  4. Close the cartridge access door, plug the printer back in and turn it on.
Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Oct 30, 2008
  • Pablo Csaky
    Pablo Csaky Oct 31, 2008
    If you don't see the printer is related to some software problem.
    Do this
    1) Uninstall the printer,
    2) Delete all the printer folders created during the last installation. (Usually in folder "Program Files")
    3) In the computer registry (start >> run >> regedit.exe) Delete all printer paths
    4) Reboot your computer
    5) Re-install the printer again.
My MacBook Pro was acting a bit strange; some websites wouldn't load such as Google, yet Facebook would. So I updated it then coming to the automatic turn on after the update my laptop gets stuck on...
This sounds like a possible filesystem corruption, possibly due to a bad update from Apple. What is the error that "Disk Utility Repair" gives you?
You may be able to take it to an Apple store to get your data restored, as they (sometimes) have special tools that scrape the existing data from the filesystem even if the metadata is corrupt.
Jun 18, 2013 | Computers & Internet
Just finished driving car, tried to start it back up and nothing happens. Radio works fine, lights come up but car won't start.
if starter is not engaging or clicks then have battery load tested. if battery checks good then test the voltage draw on the starter,may be dragging when it gets hot.
Jun 03, 2012 | 2002 Kia Spectra
Lights blink on settings around the knob won't run from there
Your door switch is not working, the machine thinks that the door is still open.
Mar 11, 2012 | Kenmore HE2 Plus Front Load Washer
83 Chevy S10 - the right blinker just stays lit, won't blink and no lights come on the right side at all.
put the hazard lights on and see if they all blink, if not, check the bulbs that dont blink. if all blink, (front and rear), the turn signal switch could be bad. putting the hazard lights on, checks the bulbs and wiring.
Sep 16, 2011 | 1983 Chevrolet S-10
2 red lights are blinking!!!!!
is both the light blink the same time or blink alternate ? if blink the same time, it's probably a fatal error..
if blink alternately then the waste ink counter need to be reset and the waste ink pad need to be replaced.
Jul 18, 2010 | Epson RX620 All-In-One InkJet Photo...
Lights flash on HP deskjet 6127
from what I read on line at HP forums unplugging the network cable may fix it. Others sat they had to buy a new printer
HP DJ 6127 after change of the cartridge blink lights nothing else happens
Jan 29, 2009 | HP DeskJet 6127 InkJet Printer
All lights keep blinking!tried unplugging and reinstalling.Dead?
If the Resume c00121686.jpg light continues to blink and the print cartridge cradle does not move to the right side of the printer, try these solutions:
  • Remove and reinstall the print cartridges. Verify that the print cartridges are in the print cartridge cradle before pushing them forward into position.
  • Verify that no obstruction prevents the print cartridge cradle from moving freely on the rod.
  • Verify that the vinyl tape has been removed from each of the print cartridges.
If the problem persists, contact HP Customer Care.
Jan 14, 2009 | HP Photosmart C3180 All-In-One InkJet...
Power & Yellow Resume Button flashing constantly & will not print
Ok please try
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jun 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
HP PSC 1315 All-In-One InkJet Printer Logo
118 people viewed this question
Seeker5211
Seeker5211
