Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag electric dryer INTERIOR ehaust vents have come apart and are obviously not exhausting hor air through the side opening.
I noticed the house steaming up. The hot exhaust was not coming out through the side. I could get my hand insidee the little opening in the back and found that ALL the sections of ehaust metal duct have separated. If it were only where the vent attatched to the exterior piece I could have fixed ir. The dryer is 11 years old. How can I get access to the bottom inside of the dryer?
    Sergeant:
    Champion:
  • 324 Answers
Take of screws holding door on, and screws opposite door hinges. the front will know be able to take off. just unplug first.
Posted on Nov 07, 2008
The maytag dryer mde6700azw gets too hot and keeps on blowing the thermal fuse.....it works ok for about a week and it repeats itself?
Make sure all air flow passages are clear. On both sides of the fan, the incoming air vent and the exhaust air vent, all the way to out side of the home.
Jan 21, 2013 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag electric dryer will not dry clothes. In reading solutions, it said to check to see if the exhaust vent is clogged. I'm afraid if I take it apart and not put it back together correctly, it...
If the heat turns on and the drum is turning them you need to make sure that it has a good air flow. You will probably have to buy a new dryer vent hose. Just follow the directions.
Sep 23, 2011 | Dryers
It takes the dryer too long time to dry the laundry even on 80 degrees.
I took my dryer apart and found the vent shoot and exhaust needed cleaning. Also the exhaust vent pipe going out side should be cleande.
Dec 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do i clean the lint trap in side the dryer. I can't figure out how to take it apart.
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it, or if the vent itself has finger holes or something that you can grab and pull or slide it open.
In some front loading models the two vents are at the back and both look like nonremovable vents. If that's the case, one actually pulls right out easily. It might then have two parts (the grate on the dryer side and the screen on the exhaust side) that snap or slide apart, with a space between for collecting lint. If that's the case, and you haven't cleared it in a long time, it will be packed full of lint. The two parts snap or slide apart, then you can get at the lint and remove it. Then snap or slide it back together and just push it back securely in place in the dryer.
Jun 13, 2010 | Maytag Atlantis MDE7657BY Electric Dryer
Dryer seem to take to long drying
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 01, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lint is collecting inside the housing not exiting via vent.
you would need to remove screws holding on the door as well as the opposing screws , after remove th edoor the front "u shaped" panel will pull foward and off, yo may be able to acess the venting from this point
Jan 13, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Water in vent
your vent out the house is broke or fell off,,suspose to a flap or lilltle blind type,,the cold air is coming in whule the hot air is trying to get out and it condensates in the vent hose ,,replace out side vent..with new vent kit..the best by is window ehaust kit...onthejob
Jan 10, 2009 | Kenmore 82822 Electric Dryer
Heating unit
First thing to check is your air flow, check the vent on the outside of the house where the exhaust enters. Should be blowing pretty hard. Any restriction will cause the heat to turn off after a couple of seconds. Hope this helps. Dave www.washermd.com
Dec 17, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryer lint all over the house
Generally this would be caused by an open or tear in the flexable exhaust vent pipe to the outside. Look behind the dryer and determine if the flexible exhaust pipe is connected at both ends. With the dryer running you might feel a lot of warm/hot air in the area around the vent pipe if there is a tear in the foil. The fix is either to reconnect the pipe or replace it if the pipe has a tear in it. You should be aware that if the lint is exhausting into your home, it is likely the exhaust gas (carbon monoxide or other exhaust gases) are being injected into your home. If you are unable to repair this, you should call an appliance repair company and have a professional technician check out your unit.
Dec 12, 2008 | Whirlpool LER5636P Electric Dryer
Maytag neptune front load dryer
Your exhaust vent is probably plugged. Remove venting from the dryer and check for lint build-up, and also check the vent flap on the outside of your house for clogs. If venting appears to be clear, you might have a bad blower (although you should notice an abnormal noise with that).
Jun 20, 2008 | Maytag MDE9700AYM Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
75 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
