Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
No Sound My laptop hasn't had any sound for a while. Though I don't know much about hardware and software, I do know it isn't muted. Can you help? Thanks.
  • jmmack Oct 30, 2008
    I got the following error msg when trying to install the driver:
    Driver Installation Failed: Could not find the MEDIA device for this driver.
    I have checked all the sound devices and, according to the device manager, they are all enables and functioning.
    Any ideas on how I can get the sound problem fixed?
  • 488 Answers
See if u have the audio driver installed..or download one from the hp website at http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-001&h_lang=en&h_client=s-s-r2515-1&h_cc=in&h_query=HP+Pavilion+dv2000+Entertainment+Notebook+PC+series
the exact model number you have will be at the bottom..hope it helps!
Posted on Oct 30, 2008
Sound card
Hi check if your sound isn't muted in the system. Go to properties of your sound card and see if the volume level is not down there and check also levels for waves and don't forgot check speakers it self. A there powered ? Are you using correct jack hole for signal out ? If you need more help let me know
Oct 11, 2012 | eMachines T3616 Desktop PC
Sound card for acertravel mate 530 series
Windows 7Check Control Panel > Hardware and Sound. In Sound > Playback make sure default device is your sound card.
How about the obvious. Volume controls, like mute. Even checking sound with headphones.
Oct 04, 2012 | Acer (54.AA806.001) Sound Card
I don't have sound on my computer yet i have installed sound drivers and they are working well?
check in your control panel and go to systems.
Then go to hardware and under that go to Device Manager
In there see if there are any exclamation marks in your sound hardware,
conflicts and such.
If there are none then go to Sound Controls in Audio Devices and make sure the audio isn't muted in the windows program
Use this to do an audio test of your speakers.
If that isn't working but it should be check your wires to see if there is a break or if it is plugged into the the green colored jack for external speakers.
Jul 31, 2012 | Creative Labs Sound Blaster Live! 5.1...
Sound drivre are note work in pc
Go to the device manager and check that the device is enabled: start>control panel>hardware and sound>device manager. Look for video and sound controllers and expand the menu. Find the sound adapter, right click and click properties. The general tab will tell you if the device is working properly. You can got to the driver tab and choose update driver and then search automatically for updated software.
Seems obvious, but check that the sound isn't muted, as well.
Mar 28, 2012 | Computers & Internet
Hdmi from laptop to tv small picture no sound
First the picture size is probably related to the screen resolution or aspect ratio. In Windows 7, you can adjust the resolution by right clicking on the desktop and choosing Screen Resolution. Make sure you do not exceed the limits of the video graphics output of the laptop or the refresh and resolution of the TV. (Without knowing your hardware, I can't tell you the actual settings you should use.) Usually HD TVs are either 720p or 1080i. Alternatively, check if you can change the zoom or aspect ratio (4:3, 16:9) on the TV. Those settings may fill your screen. (It could expand the image past the viewable edges of the TV or distort your image though.)
For the audio, you should check the Sound outputs. Again in Windows 7, click Start > Control Panel > Hardware and Sound > Manage Audio Devices. Under Playback, see if you have an option for HDMI sound. If you don't have this option, you will need to connect an audio cable between your computer and TV. (If the TV has a VGA input with a PC audio jack, use a 3.5 mm audio patch cable. Otherwise, you'll need a 3.5 mm to RCA audio adapter or cable.) Make sure that the audio isn't muted.
If you have a different OS, the specific commands will be slightly different but similar in Windows.
I hope this helps.
Oct 18, 2011 | Televison & Video
The external display stays muted and plays no sound but when I use the headphone port the sounds work. I cant get the laptop speakers to produce any sound though.
Go to control panel and go to sound and hardware (Just go to anything that says sound)!
Then go to sound and audio devices!
Go to Audio and change the default until sound comes out of tv!
Aug 28, 2010 | HP Pavilion dv7-1130us laptop
My laptop won't play sound. how do i fix this?
Thank you for using Fixya Forums.
I just want to verify the sound 'Mute' button is locked, is that a button on your laptop or are you referring to the sound icon in the system tray? Are you showing a 'Red X' on the sound icon in the system tray? I have attached some information on updating drivers and some other troubleshooting tips. Please let me know if you are still having any problems or if issue has been corrected.
Update a driver for hardware that isn’t working properly
You can use Device Manager and/or Windows Update to locate the necessary driver for your system. If you know the manufacture of the hardware in question you can visit their respective website and obtain the driver from there.
Also, feel free to visit this help article found on the Windows Help and How-to website about Tips for fixing common hardware problems.
How to update drivers using Windows Update
1. Click Start, click All programs, then click Windows Update.
2. If prompted press Continue or provide administrator credentials.
3. In the left pane, click Check for updates.
4. To see if updated drivers are available, click View available updates.
5. Windows Update will list any updated drivers that are available under Optional downloads.
6. If any updates are available, click the driver that you want to install, and the click Install.
Jan 28, 2010 | Computers & Internet
There is no sound coming out from my laptop though the sound device was installed
Go to Control Panel - System - Hardware - Device Manager and chck if the sound driver is OK, if you have a yellow ? against the audio driver, it mean the driver is not installed or the wrong one was installed.
If the sound driver is OK the check the MUTE switch in the audio settings, untick it if the mute has been selected.
Apr 30, 2009 | Dell Latitude C400 Notebook
Laptop LED Locked Mute
go to compaq.com and reinstall the hot-key software for your laptop. seems to be a bad driver, could also be bad hardware though, if it is bad hardware you may be looking for someone to take it apart to fix it. more than likely though it is a driver which can be fixed with just installing new software.
Nov 27, 2008 | HP Compaq nx6125 Notebook
New laptop
I had this problem too. My built in mic wasnt working, but i went to the list of programs (Classic view of the start menu) and under the program folder TOSHIBA > Speech System it'll have a choice "Configure Microphone." After I went through that, it worked fine. Make sure you restart your webcam software though after you've done that if you had it open like me. Hope this works!
Jun 07, 2007 | Toshiba (P000257700) Microphone
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
