Question about D-Link DP 301U (DP-301U) Print Server
Setting up IP address on server
Cannot access default IP address 192.168.0.10 on internet to set up address on my new DP 301U. Tried it on two computers.
  • bleo24 Feb 05, 2009
    our network doesn't have the ip 192.168.0.xxx. we changed the network yesterday, and the print server doesn't work. how can I fix this. I instaled the network manager to find out what is printer ip....but no success...it doesn't see it. can anyone help me??!!
  • Jannette Amandy May 11, 2010
    How is your printserver connected to the network?
    What are the IP addresses of the two computers that you have?
    Do you have a router?
  • 22 Answers
Download and install <a rel='nofollow' href="http://www.wireshark.org/download.html">Wireshark</a>.
After installing, click the first button on the toolbar to list available capture devices. Select the interface you use to connect to your network (wired or wireless card) by clicking the "Start" button next to it.
Power off and back on the print server. Watch the log on Wireshark, and look for the D-Link identifier under the "Source" tab. In the same row, it will tell you the IP address the print server has assigned to it. You can then change your computer's IP to be in the same subnet (match the xxx's in the address xxx.xxx.xxx.yyy), allowing you to connect to it.
Posted on Feb 08, 2009
  • 3 Answers
Your computer has to be on the same subnet while setting up the DP-301U. If you haven't changed anything on the print server yet, then you are correct that it has an IP address of 192.168.0.10, and the subnet mask is 255.255.255.0. So your computer must have an IP address of 192.168.0.xxx (not 0, not 255, and definitely not 10). Also not any other value that is already taken elsewhere in your network.
You don't have to keep the DP-301U in the 192.168.0 subnet, by the way. You can change it to whatever you want; but you have to start there to configure it initially.
Posted on Dec 31, 2008
2 Suggested Answers
  • 3 Answers
SOURCE: Browser Setup Access address for DLink DP-301U Print Server
It's in the quick installation guide, which is freely downloadable from their web site. Top of page #3...
"The factory default IP address of the DP-301U is 192.168.0.10."
Ip address di default del dp-301u
This is a wrong problem solver, because 90% of this site contains SPAM instead solution, confusing user totally. Please remove the SPAM from site or remove this site from the Internet. Thank you.
Mar 22, 2011 | D-Link DP 301U (DP-301U) Print Server
I have print server DP-301U Pls let me know the default IP address for configuration
Hi
As far as I can remember the default IP is 192.168.0 .10, subnet 255.255.255.0
If this isn't the correct IP address, you'll need to reset the d-link print server Hope this helps
Regards, c0d3
Feb 09, 2011 | D-Link DP 301P (DP-301P) Print Server
I can't get the default ip address
Dear May,
You can download the softwares which can show you the exact ip of your device
http://www.hide-windows.com/Download/ipscan.exe
or you can download the PSADMIN software from this link ftp://ftp.dlink.com/Printserver/dp301u/Apps/PSAdmin/DP301U_PSAdmin_100.zip
it will automatically show you all the connected Print Servers,
Click on IP icon and it will prompt you for the password, Enter the password (default= admin) if you haven't set your own and it will show you the IP
Regards, Bilal Kindly Vote for this solution too :)
Jan 11, 2011 | D-Link DP 301U (DP-301U) Print Server
I have installed the DP-301U print server on my home network to print to an HP Laserjet 4050. When setting up the print server per instruction, I set my computer IP address to a static IP address. The...
Your print server has to have its own IP address. If you have your computer as 198.168.1.1 then your print server would be 198.168.1.2.
You cant have the same IP address on any 2 items on your network.
Oct 20, 2009 | D-Link DP 301U (DP-301U) Print Server
What is the ip?
default IP address of DP-301U is 192.168.0.10
Jul 14, 2009 | D-Link DP 301U (DP-301U) Print Server
Dec 18, 2008 | D-Link DP 301U (DP-301U) Print Server
D-Link DP-301U Problem
It should be fine as long as it is in the range that the router can recognize and that it doesn't conflict with another IP address used on another device. Usually on the networks I design I keep the printers on higher IP address so that they can be managed on a certain range.
Is this the wireless print server?
What specifically do you mean by PJL printer block?
Aug 04, 2008 | D-Link DP 301U (DP-301U) Print Server
DP 301U and Lexmark 2550 (all-in-one)
1. Set up your print server with an IP address.
2. Ping your printer IP address.
3. If successful, Add printer wizard. Create a new port, Make it TCP/IP port. Put the IP address in the IP address field. Click next and Use Generic 9XXX Raw.
4. Install the driver provided by the manufacturer for your printer and assign it to the Network port.
5. Print.
Hope this helps.
Jun 03, 2008 | D-Link DP 301U (DP-301U) Print Server
Unknown address
Install Network Manager in your and install . When you install this software then you go to networkingmap there you will get ipaddress of your print server
Apr 18, 2008 | D-Link DP 301U (DP-301U) Print Server
Can't set up DP 301U and still keep internet connection
I was able to solve this but it won't let me post here. sttmh01 --- hotmail.com if you still need the answer.
Dec 15, 2007 | D-Link DP-301U (790069251979) Print Server
D-Link DP 301U (DP-301U) Print Server Logo
1,560 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
