Question about Sharp Office Equipment & Supplies
My Sharp AL-1642cs copier is leaving a white strip vertically when copying. The drum and tones have been replaced
  • rugbychamber Oct 31, 2008
    cleaning the transfer charger did not fix the problem. Could the transfer charger be bad?
  • 2,120 Answers
Wipe the spongy black transfer roller inside with a dry cloth.
Posted on Oct 30, 2008
I have a sharp AL 1642cs and every time I make copies from the top of the printer my copy comes out with line/strips. What can I do not to get those lines anymore.
The machine that you have is digital the scanglass has somethind on it clean it with windex or alchohol that should take care of it
Jan 27, 2011 | Sharp AL-1642CS Copier
Vertical lines on copied page
Run a copy on the glass if there are no lines then something is on the scan glass of the document feeder. Use some window cleaner and scrub the document feeder glass and test. Sometimes white out or ink will stick to the glass and the scanner reads the dot as a line.
Sep 08, 2010 | Sharp AL-1642CS Copier
I have a Sharp AL- 1642CS - broken transfer wire
so does that mean that you were getting blank copies and the transfer wire is broken?
Jun 25, 2009 | Sharp AL-1642CS Copier
My Sharp Al-1642cs is leaving a black stripe on the paper when coping.
Does the line appear when you copy from the glass? Or is it Just the document feeder. If it is just throught the doc feeder then you have to clean the **** glass next to the main glass. It only takes a small dot to make a line. Hope this helps. Have a nice day.
Apr 29, 2009 | Sharp AL-1642CS Copier
Getting double images on copies, how can I fix?
It's one of two of these solutions. The fixing rollers more so the upper fixing roller which is the hot rollers at the exit end of the copier is dirty or need replacing. Or the drum has a cleaning blade on it that needs replacing. If you look at the drum and see if toner is still on the drum if so then your cleaning blade needs replacing. Also if that copier uses a blanking lamp then it might not be turning on so you can get double images.
Mar 04, 2009 | Sharp AL-1642CS Copier
Sharp AL-1642CS Copier, the scanner is jammed
Not familiar with that model but what I would try is to turn off the copier remove the glass and try moving it by hand, then turn it on and see what happens it may have a bad motor
Oct 29, 2008 | Sharp AL-1642CS Copier
Sharp AL-1642CS making blank copies
You have a door on the right side of the machine. in that door is a thin piece of wire mounted inside a bracket. The bracket is white and is at an angle in the door. Do you see that now?
Jul 17, 2008 | Sharp AL-1641CS Laser Digital Copier
Vertical lines on multiple page copying
Did you check to see if the lines are before or after the fixing unit? Stop a copy before it gets to the fixing unit. If there is no lines in the same spot, then the problem is in the fixing unit, if not check the and clean the optics and dust proof glass. Good Luck...
Apr 16, 2008 | Sharp AL-1642CS Copier
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of the glass specialy the right side.ok
60 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
