Question about JVC HR-XVC33U DVD Player/VCR
DVD won't read discs
My dvd sounds a little "cliky" when I put in a dvd. It says "reading disc" on the blue screen. After about ten seconds, it says "no disc" on the blue screen. I tried a cleaning disc and the problem remained the same. Sher
  • 12 more comments
  • Handy1 Nov 03, 2007
    I have the same problem and have tried a cleaning disc. I get audio from the cleaning disc but still getting "No Disc" when I try to play.
  • karinah Nov 06, 2007
    I have the same problem with this product. It always says "no disc" even though there is one. (I also returned the first one I bought due to the same problem....so it sounds like it is a problem with the construction of the product.) This time it didn't start doing this until I'd had it for awhile. How can you clean the lens? I don't see it anywhere that is accessible.
  • Anonymous Jan 04, 2008
    mine makes a noise like it's trying to read the dvd but it can't. i have tried to clean it and i have unplugged it to let it reset, but nothing. it just up and quit working one day. please help.
  • Anonymous Feb 08, 2008
    Begins to read disc then comes up with H02
  • g-man4894 Feb 25, 2008
    mine will play music cds fine but videos it says "no discs"
  • dre1988 Feb 28, 2008
    i'm working on a similar problem right now. i was copying a game from the dvr hard drive to a dvd monday night. the disc was dirty and the copy failed. since then the damn machine is not reading DVDs at all. i receive error code U88 at times.
    i left it plug off today to see if it go reset.
    has anyone been able to fix this problem?
  • Anonymous Mar 04, 2008
    MY DVD ALSO WON'T READ DISC
  • akupa Apr 05, 2008
    My dvd sounds a little "cliky" when I put in a dvd. It says "reading disc" on the blue screen. After about ten seconds, it says "no disc" on the blue screen. I tried a cleaning disc and the problem remained the same. Amartei
  • packs3 Apr 16, 2008
    dvd has blue screen says loading but then goes to no disc and then will sometimes make a clicking noise. please help
  • natelaker Jun 26, 2008
    DVD will not read all of my dvds. I get disc error or reading disc message
  • Anonymous Jul 03, 2008
    I have the same problem RV27 can't read disk
  • Anonymous Jul 19, 2008
    mi dvd si lee cd de mp3, pero dvd de peliculas no los lee
  • hmanusa Aug 24, 2008
    Tried playing a Memorex DVD-R copied movie with ifo vob files, same results, first: loading CD, second: no disc
  • Anonymous Jan 29, 2009
    My dvd player just stopped working 2 days ago. Now it makes a scrapey clicking noise for about 15 seconds and then says "no disc." I really don't want to buy a new DVD player. Any ideas?
When i put dvd inside my dvd player after 10 second my tv screen show no dics
Posted on Sep 29, 2008
Also this happen to me, the lens is getting stuck at the point, what you need to do is move the lens mount without touching the lens back and forward about 50 times. or you can apply a small amount of oil on the track. and when i say small i mean very small
Posted on Jul 07, 2007
    Genius:
  • 1,074 Answers
If the problem is a problem that develop after you buy the set your lens needs to be adjust or buy a dvd lens cleaner and clean the lens of your dvd.if that does not work change the flat strip that leads from the lens body it might be broken.
Posted on Mar 15, 2007
  • Henry  Thomas
    Henry Thomas Apr 01, 2007
    it is time that you take your dvd to a tech for repairs good luck
    Genius:
  • 1,074 Answers
You may need to buy Panasonic brand DVDs. I have this machine and had the same problem. Then I bought Panasonic DVDs and it works okay. Frustrating. This is a known issue with this model.
I have the same problem with mine. Did you manage to resolve your problem, if so please help me as well.
Posted on Oct 11, 2006
  • 49 Answers
Try cleaning thelens inside the unit.use a clean cotton ball to wipe the surface of the lens.DONOT USE ANY LIQUID!! extra care..
Posted on Sep 12, 2006
4 Suggested Answers
SOURCE:
SOURCE: jvc xv-s332 dvd player won't play
on the back is a seitch labelled ntsc/pal. flick it the other way might fix it
Posted on Mar 09, 2008
scottyfixit
  • 186 Answers
SOURCE: incorrect disc message
You might try using rubbing alcohol and a q-tip on the lens to clean it.
Posted on Apr 24, 2008
SOURCE: jvc dvd player no disc error
Hello!
I did have a similar problem. It was solved by cleaning the laser lenses/prisma. You have to dismantle the whole pick-up the to see the laser lenses.
There is one lens which is held by couple wires and below there is prisma/mirror.
I did use ear-cleaner-stick and desinfection liquid (with alcohol) for cleaning. Now it works!
Posted on Nov 27, 2009
Problem reading dvd disc
hi there
that only means that it has difficulty reading the disc that you inserted.
have your disc cleaned and try to check if it will do the same thing with other discs.
hope this helps
Jan 29, 2008 | Panasonic CT-30WX54 30" TV
The dvd player will not read the disc
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
Jul 28, 2011 | Cyberhome CH-LDV1010A Portable DVD Player
Ps3 wont read blue ray discs but will read dvd
sounds like the blue ray lens fried, u should be able to find one on ebay or craigs list not hard to put in
May 29, 2009 | Sony Playstation 3 (PS3) Console
Screen freezes playing Blue Ray discs only.
I answer this question like ten times a day so don't feel bad.
The blu-ray laser in your PS3 is a three part laser (cd / dvd / blu-ray). They last only 1-3 years with average use. It's a Sony defect.
Check out my common PS3 problem and repair guide for tips and suggestions for your problem.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 24, 2009 | Sony Playstation 3 (PS3) Console
Can not read disc
I mainly use my DVR to record TV shows on DVD-RAM discs (Panasonic brand or Maxell). I've had no problems with the DVD-RAM discs. However, today when I put a DVD-R disc in the recorder, I got an "Incompatible Disc" error message. I tried a second disc from the same set, and got the same message. I tried out some of the DVD-Rs that I recorded last year and I could read them. Tried a DVD-RAM. That was OK. So, I tried another DVD-R disc. That one is OK. I don't know if the problem is that these DVD-Rs are getting a little old (2 years??) or if the recorder is developing its own problems reading discs.
Dec 03, 2008 | Panasonic Diga DMR-EH75V DVD...
Hi Definition
I believe the craig CVD329 is a progressive DVD player, not a HD DVD player. It can not read HD DVD discs, it can only read regular DVD discs.
Feb 15, 2008 | Craig 731398403288
Play station 2 won't read silver disc only reads blue disc
Hi Elvis,
The Blue back disc is CD format. The DVD laser circuit is giving you trouble. You can adjust the DVD pot some on the back of the Laser. Turn it about 3 degrees clockwise. Then put it the laser back in. Test the PS2 with no cover on, and use the white round disc from the laser drive cover to clamp a disc onto the spindle. Test DVD and PS2 Games that do not have Blue back.
Nov 28, 2007 | Sony PlayStation 2 (PS2) Console
Durabrad DUR-1700 - No Disc
turn on the power and open the dvd axcess door, inside where the dvd goes is a small little push down switch, push this down, it is in the upper right side. this will let you see if the laser is powering up,if you see no red light ,your laser is bad. hope this helps
Aug 06, 2007 | Durabrand DUR-1700 Portable DVD Player
JVC HR-XVC33U DVD Player/VCR Logo
460 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
