Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Help installing friend gave it to me without instruction and no power cord. how do i install it? i looked it up and i am a little inexperienced and dont totally get what to do. i just need it set up to my pc/internet connection so my kids can use it for psp, wii, nin ds, laptops etc.. help!
    Scholar:
  • 87 Answers
The thing you don't say, is that you already have a high speed network connection by either DSL or cable. You already have a modem/router that you plug into for your internet. This one is an extra one you would like to use as an access point for your home wireless network.
You will need to set it up as a router not a gateway in the configuration. You should turn off the DHCP for the wireless router and just let it perform pass thru to the primary router to assign IP addresses. Set up the wireless router to have an IP address in the same subnet as the primary. If primary is 192.168.1.1 set the wireless routers IP to be 192.168.1.2 or 192.168.1.3, etc. Then set up the configuration for the wireless settings and test the wireless connections with a laptop or PC. Plug the Wan connector on the wireless router to one of the ports on the primary router and you should be good to go.
Posted on Oct 31, 2008
My home has a central vacuum system hook-up but no vacuum installed. My friend upgraded his central system and gave me his Eureka Mega Boss central vacuum system and the accessories, including the pow
The power head requires 120 Volts. Some hoses have a receptacle in the handle for the power head plug, and the hose has a cord at the wall inlet end that plugs into a receptacle. Some hoses have a plug at the wall inlet end that plugs into a 120Volt receptacle built into the inlet. The hose plugs into this receptacle when you push the hose into the inlet. The power for this built-in receptacle is wired with line voltage when the system is installed.
Apr 15, 2012 | Eureka 1810 Central System Vacuum
I keep getting a pop up windows alert that a file called tray/app. msi is misssing, tries to load and asks for a source disc. What source disce am I looking for? It s a Dell Inspiron laptop with Windows...
It may have to do with an HP Printer. If that's what you're using or previously had installed, go here...
http://www.ehow.com/how_5269744_remove-trayappmsi.html
Follow the instructions and you should be good to go. Otherwise, if you gave away an older HP Printer and installed a new one without removing/uninstalling the old HP Printer from the Control Panel, you could get the same error.
If that's the case, uninstall the older printer. Then hold down the Windows Logo button on the keyboard and press the R key once. A Run Command window will appear. Type in "%TEMP%" without the quote marks and hit enter. You will be looking at your Temp Files. Delete as many as the System will allow and then restart.
It can get a little complicated after that if the error message is still there and you might consider having an "advanced user" friend give you a hand.
Regards
Jul 13, 2010 | Dell Inspiron 1501 Notebook
ViewSonic VG2021m monitor without installation software
try using the FN "function key" and you should have a button at the top that looks like and LCD press it while holding the FN button
Dec 16, 2009 | ViewSonic VG2021m LCD Monitor
Need help with installation
Your Spacemaker 1400 should be model number JVM1640SJ (or something close to that). If so, go to managemyhome.com and register. This is a FREE service. Once registered, log in and click on the "Home Manager" section at the top of the page. Look for the "Owner's Manuals" link on the drop down menu. Both, your Owner's and Installation Manuals are available in a downloadable .pdf format. All you need is Adobe Acrobat installed on your computer to be able to view it. I hope this helps you.
Apr 23, 2009 | Microwave Ovens
How do i install rio cai without the installation cd?
Go to the following site:
http://www.digitalnetworksna.com/support/rio/product.asp?prodID=108
This is where you can download the Rio Software 2.90 to manager your music.
Nov 29, 2008 | Rio Cali Sport MP3 Player
Power supply cord
Any power supply providing 19V DC at 3 Amp with a positive tip connector will do.
Hope that helps.
Jun 13, 2008 | Balance CM2017 17" Monitor
Acer L5100 install problem
I think it would get power through the Moniter so I don't think you need a power cord for the CPU. Hope this helped =)
Feb 25, 2008 | Computers & Internet
Installation
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=11642
Is where you can download your drivers to install it (after entering your operating system IE Windows XP or Vista). In addition to this you will require an A to B USB Cable (can be found in any computer store). You will also need a standard 2 pin power cord. These are common and are used on many things from stereos to printers. Any printer or computer shop should have some laying around (we have thousands here). Finally you will need to see if there are any ink cartridges in the printer (and if there are whether or not they work). If not then you will need to purchase a Canon PG-40 Black Cartridge and a Canon CL-41 Colour cartridge. This will be your last step though as you won't be able to test your cartridges until it is hooked to your computer.
Good Luck.
Please rate my advice, good or bad.
Feb 10, 2008 | Canon PIXMA iP1600 Printer
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
70 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
