Inspiron 530S Power Save Mode Loop
A friend's (not computer literate, I am, but am no Guru) Inspiron 530S is in what appears to be a power save mode loop. At power on, screen shows green power light, "auto detecting", and loud fan (compared to before problem). Then screen shows going to power save mode and solid yellow light. It appears to not try to boot, as no F2/F12 show and F8 does not work. When keyboard mouse icon is pressed screen shows green power light and advises to press any keyboard key or move mouse. When either are done nothing happens and screen shows going to power save mode and solid yellow light. Cannot access BIOS, Alternate Boot (to run diags), or Safe Modes.
  • 1 more comment
  • khpaladin Oct 30, 2008
    Sweetyanne,
    Sorry, did not include fact that there are no removable devices plugged on the system. Only equipment are as follows, WiFi (internal card) antenna, Flat screen monitor (cabled to video card), optical mouse, and main power cord. This is a stand alone desktop to access internet and check email.
  • khpaladin Nov 01, 2008
    Sweetyanne,
    Talked to Dell TS, what testing that was done changed nothing. The minute main power button is initiated no power transfer is seen by the equipment, including the monitor, which thinks there is no power. Therefore all the equipment goes into hibernation/shutdown mode. Bottom line, the internal power supply went the way of the dodo bird and will be replaced. I very much appreciate your interaction with the problem.
    Thank You
  • sfnvartist May 25, 2009
    when I try to turn on my computer it goes in and out of power save mode. The light on the power button is amber when this happens and the computer turns on and off on its own without reaching bios. When I finally called dell because I was stumped they told me it was a virus and that i need better virus protection.
  • 68 Answers
First you need to make sure that there are no other removable devices plug on the system, like usb, external hard drives, then if that will work try to go to the bios, press f2 when you see the dell logo, and go to the system setup, go to the boot device configuration and make sure that removable device is not the first boot device, if it is the first one choose hard disk and then second boot device ad cd rom/dvd rom and then disable the 3rd boot and the fourth boot device. Make sure to save the changes. And restart the system again. Once the computer is back and running try to go to support.dell.com and check the bios, download if there is a bios update for the system.
Posted on Oct 30, 2008
  • sweetyanne
    sweetyanne Oct 30, 2008
    I see, most on the power save mode loop appears on flat panel monitors, do you know what kind of monitor and video card does the system has?
Dell Inspiron 530s Desktop fan motor keeps running
It\'s NOT the fan. Check the power save settings on the computer ITSELF. Check your BIOS settings as well. Inspirons ALL do the same thing with waking up.
Nov 05, 2013 | Dell Inspiron 530s Desktop Computer
My dell Inspiron 530s goes to power save mode screen is black can't see anything fan is on what can I do
Do you get a screen if you boot from the CD/DVD drive using the Windows installation CD/DVD disc. If not, you probably dis-lodged
a cable or plug when installing the drive.
Sep 25, 2012 | Dell Inspiron 530s Desktop Computer
Dell Inspiron 545 wont come out of power save mode - when switch it on it tries to start up but then goes into power save mode this then continues switching between power save and starting up until i
Do a full reset. Press power button down until computer shuts down, this will take more than 5 seconds. After that you can perform clean boot.
Aug 18, 2012 | Dell Computers & Internet
Inspiron 530 auto goes into power save mode
Click Start/Control Panel/Power Options and change the length of time or set it to NEVER.
There might also be settings in the Bios or System Setup that you can tweak. When you reboot your machine, watch the screen for which key it says to hit to get into the Bios or System Setup and hit that key when you see the message.
May 13, 2012 | Dell Inspiron 530s Desktop Computer...
Dell Inspiron 530 S goes into power save mode and either fails to respond to pressing a key or powers off
test the PSU if the power supply units fan is not working the psu is faulty
check leads from motherboard to hard drive make sure connections are secure and dust free including electrical extensions
if its a 40pin ide this will be the first to fail
even something as small as a faulty fan lead can cause this ptoblem
computers need power and data to travel through every working device and to continue its cycle and have a finishing point
make sure your ram and cmos battery are dust free and securely seated
on some motherboards cmos batteries are soldered in
hope this helps
Nov 12, 2011 | Dell Inspiron 530s Desktop Computer
My dell inspiron 531 desktop enters auto detect power save mode
start your computer in safemode and then turn off all power saving features
Apr 10, 2010 | Dell Inspiron 531s Desktop Computer
My 5305 constantly goes into power save mode
Hi
Thank you for your query
This is a common fault on Dells please try the following
It seems it is a motherboard battery problem. try this.
It most likely is not the monitor which is in "power save mode", it is the computer itself.
When you cannot get a computer out of "power save mode" by any other means, typically the cause is that the button-cell-type battery of your computer, which is located on the motherboard, is empty.
Usually, this happens on a computer which is a few years old, since its batteries will have run out after such a long time. (The motherboard battery is used to store various settings when the computer power is off, such as date and time. When your computer detects this battery is empty, it goes into a low-power mode).
The solution is to replace the button-cell battery on the motherboard of your computer:
- open the case of your computer;
- visually locate the motherboard (the main electronic circuit board) of your computer;
- visually scan the motherboard for a button-cell battery (it looks like a digital watch battery, but a bit larger);
- remove this motherboard battery from your computer;
- restart your computer: it should now power up normally (you may get some warning messages during the start-up sequence, but ignore them);
- set the date and time of your computer using the "Date and Time" control panel;
- you can now use your computer normally, but you will lose date and time
If this has been useful please leave positive feedback/vote/testimonial - Thank you again
Feb 13, 2010 | Dell Inspiron 530s Desktop Computer
Cant seem to turn on
Gp to Bios Set-up and look for set-up default. Then save and exit.
Apr 07, 2009 | Dell Inspiron 530s Desktop Computer
Computers & Internet Logo
1,186 people viewed this question
David Payne
David Payne
