Question about OKI C3200n Led Printer
Blank line in the middle of the copy
Prints everything except a half inch in the center of the page vertically.
    Master:
  • 409 Answers
Either the light source is failing or you have a piece of paper stuck in the way of the LED's and the drum.  Check the paper path very carfully to make sure there is no dirt or debris in the paper path.
Posted on Oct 30, 2008
A blank vertical line appears on every page printed
if it is a white void check laser shield glass. toner might be on it causing this problem. There should be a wand in front door use to clean laser area make sure you do each color. hope this helps.
Feb 09, 2014 | Ricoh Aficio CL3000 Laser Printer
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Copy split in half; half blank/half print
It is a scanner problem. You need to take in in for a service tech to repair. It could be the scanner bulb, or laser.
Jan 08, 2010 | Sharp Office Equipment & Supplies
My brother hl 4040cn is printing fine, except there is a blank vertical line in the middle of the page. what is this?
Usually just toner dust on the laser lens, you remove the toner and drum and look on top inside for a window about 1/2 inch wide. You wipe that window with a dry cloth, and also check for paper scraps inside or on the drum assembly.
Nov 18, 2009 | Brother HL-4040CN Laser Printer
5610 printing just a line in the middle of the page, else blank!
wow..I could be the FIRST..I am impressed..NOT!
check to see if there is ink, by blotting the print head on damp paper towel.
otherwise..delete and reinstall the printer. could be a software problem.
Apr 11, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Printout blank
this is problem with cartigdes only just installed new one and see.
Oct 17, 2008 | HP PSC 1210 All-In-One InkJet Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
OKI C3200n Led Printer Logo
131 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
