Question about Frigidaire GLER642A Electric Dryer
Cant get dryer4 to heat
M.kbjg 'Pi
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
What is pi eqaul to
The circumference (perimeter) of a circle is given by the formula
C = 2 (pi) (r), where r is the radius. Since radius is half of the diameter, d = 2 (r), so C = (pi) d.
Dividing both sides by d to get pi by itself, pi is the circumference of a circle divided by the diameter.
Pi is irrational, meaning that it goes on forever, without repeating numbers and cannot be represented as a fraction.
In everyday life, we often use 22/7 as an approximation of pi. Other people use 3.14.
I have memorized what my calculator gave me plus one more decimal, 3.1415926536.
Others have memorized it to thousands of digits and people have spent their lifetimes calculating pi to more and more decimals. Books have been written about pi.
Some schools celebrate Pi Day, since Pi begins with 3.14, it is celebrated on March 14th.
Good luck,
Paul
https://en.wikipedia.org/wiki/Pi
Jan 04, 2017 | Office Equipment & Supplies
Area of circle
(pi)R squared (Fixya won't let me use the sign for Pi)
Area of a circle=pi*radius^2 or pi times radius times radius
example: suppose the radius of a circle is 10 inches, then the Area of the circle would be pi times 10 times 10 or 100*pi
pi represents the circumference (distance around) of a circle / diameter and for any circle is constantly the same number which is approximately 3.14
so in my example 100*pi=100*3.14 or 314 square inches
Jul 03, 2014 | Computers & Internet
Formula for circumference
Circumference of a Circle: 2 x pi x radius - OR - pi x diameter,
or if you need some sphere calculations?
Sphere Surface Area: 4 X pi X radius squared OR
pi X diameter squared Sphere Volume: 4/3 X pi X radius cubed OR
( pi X diameter cubed ) / 6
By the way.......... "pi" = 3.1415926536
Apr 29, 2014 | Office Equipment & Supplies
Find the trig function given its period cos 5 pi
cos(5PI)=cos(4PI+PI)=cos(PI)=-1
sin(19PI/6)=sin(18PI/6+ PI/6)=sin(3PI +Pi/6)=sin(2PI+PI+PI/6)=sin(PI+PI/6)=sin(-PI/6)=-sin(PI/6)=-1/2
Dec 12, 2011 | Super Tutor Trigonometry (ESDTRIG) for PC
Cant turn a fraction into decimals
The calculator has two input modes: MathIO and LineIO. In mathIO results can be fractions or radicals (if you are calculating roots), and PI appears as PI. The final result may not be a decimal number. To convert such a result into its decimal approximation you press the key marked [S<>D]
Sep 12, 2011 | Casio fx-300ES Calculator
Hello. My name is henry my problme is: yesterday
Hello Henry. Let's begin by resetting it. Carefully lift off the thin, delicate frame around the screen with your fingernail. under there you will find the reset button. With the garmin on, push the reset. This act may solve your problem. If it does not you will have to send the unit into Garmin for a repair. Go to Garmin.com to do that. J.
Jun 15, 2010 | GPS
Network problem
did you take it to your cellular provider for repair? If not then try that, If so then you may want to take it to the next level and send the phone to Nokia. But in the mean time, See about getting a different phone either from Ebay or from the carrier, If it is AT&T then you can get a prepaid phone and just put your sim card in it and use it, Sorry for your trouble, Hope this helped.
Nov 25, 2008 | Nokia 6300 Cellular Phone
Math problem
This sounds like someones homework. I'm risking my reputation here but here goes.
Previous Area was Pi x R x R. = Pi X 10 X 10 = 100 X Pi
Previous Perimeter is 2 X Pi X R = 2 X Pi X 10 = 20 X Pi
New shape is a rectangle with a semicircle at each end and width of 10 cm.
New Perimeter is circular bits + straight edges between them.
We know the circular bits but not how long the straight bits are so ...
Perimeter = 20 X Pi = (2 X Pi X 5) + L X 2 = 10 X Pi + (L X 2)
So L = (20 - 10) X Pi / 2 = 5 X Pi.
So the new Area is ... (Pi X 5 X 5) + (10 X 5 X Pi)
= 75 X Pi.
= 75 X 3.14 = 235.5
Nov 07, 2007 | Adobe Photoshop 7.0 (321115627)
Frigidaire GLER642A Electric Dryer Logo
44 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
