Question about Insignia IS-LCDTV32 32 in. Television
No picture My 32 inch Insignia tv will not turn on and I was told by the Insignia tech that it was either a blown Power Supply Signal Board, or the Power Supply Board.
  • 2 more comments
  • nickrich1 Oct 30, 2008
    The model number is IS-LCD32TV. I took the back of the tv off and I looking at the mother boad. Is there any way I can contact you?
    I also wanted to let you know that I have power to the tv becasue the red light is on when the tv is off. But when I turn the tv on it only stays on for about 2 seconds and then it shuts off.
  • sailhoward Nov 03, 2008
    I am on round two with this problem of the IS-LCDTV32 32 in. television. After about a year of use, it refused to turn on. It has power (red light is on) but will flash on (blue light flash) and off (red light blinks) when I attempt to turn it on. I tried heating with a hair dryer, holding the power switch while plugging it in, and standing on my left foot reciting limericks backwards- all to no effect. I went thru Best Buy and after several weeks and two visits from a rather evasive tech, I received a rather expensive new power supply. The thing worked for about 10 months and now will not turn on again. (To add to my frustration, an older Sylvannia TV in my house has caught the same malaise- clicks on and off in a second.)
    I don't want to do another expensive repair- I feel like I'm chasing a 6 high straight.
    Can I just replace the capacitors?
  • GEOHERB Dec 09, 2008
    I had the same problem with my 32 inch LCD Insignia TV. I opened up the back of the TV and pulled out the power supply and replaced three 680uF 35V capacitors. They were slightly swollen on top. It works great now. Very easy to do. I think the "hairdryer" theory was made up as a joke. If it did work it was just a coincidence. Good luck. George in Reno,NV
Had the same problem, Insignia 32 would click on then go off. About 6 months ago I found (somewhere on the net) a guy who explained that he changed blown capacitors. As I recall he even posted a picture. I found the blown capacitors and replaced them with larger capacitors (less than $20) problem solved...
But now my screen image is showing only half a picture and is pulsing on a off.
I think I'm going to make a Wii commercial......GL
Posted on Jun 03, 2009
  • 98 Answers
As Jamie said check the power supply (check fuses) also check the flex cable from the screen to the main PCB) these come loose and tend to show the no power symptoms as well
good luck
Posted on Nov 07, 2008
  • 2,307 Answers
In a majority of case is the LCD does not power up, is the power supply that failed.
I repair these power supplies or if you provide the model number I might have the power board available.
Let me know if you need further assistance.
Posted on Oct 30, 2008
I have a Insignia NS-L32Q-10A that will not power on. Now power on light or standby. I have replaced the power supply already. All caps look good and fuses check OK. What next???
ok, when you plug in the set, does the power light come on? Assuming you ordered a power supply in good working order, you may very well have a faulty main board. The power supply produces standby power that the main board uses to power the standby/power on light. Your main board also uses the standby power to provide the "ON" signal to turn on the rest of the power supply.
Feb 02, 2013 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
How does Insignia TV turn on
THE MAIN BOARD, usually is a 3vdc-3.3vdc signal to turn on the power supply
Feb 01, 2013 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
I have an insignia ns-lcd37-07 giving to me, i replaced power supply board and i still don't get anything. what should be my next step?
Now the tv is turn on,tv have power LED light indicaton but no picture?Still have a clicking sound but no picture on the tv LCD screen panel?Yes,than the tv Tuner signal board that the other board 70% also might have the problems too.That the board where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Apr 13, 2011 | Insignia NS-LCD37 37 in. LCD TV
Insignia LCD TV 32 inch will not come on
I received no replies to my request. I guest I stumped 2 million techs. I'll just buy a new TV with a 5 yr warranty. No thanks to joining your service, I can do bad all by myself.
Feb 08, 2010 | Insignia IS-LCDTV32 32 in. Television
Insignia 32 HELLP
You can find parts for your TV here. If the power supply is an internal component, it is strongly recommended that it be installed by a TV repair professional.
Sep 30, 2009 | Insignia IS-LCDTV32 32 in. Television
Will not turn on, red light as off, when I push power the red light goes off but
Look for 2 pico fuses in the secondary section of the power supply. I'm sure one of them is blown, that is why the 24 volts are missing.
I will let you know the locations later when I get home.
Good Luck.
Jan 10, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
Tv won't turn back on !
the tv has been shorted out. you will need to replace the power board easy to do just take off the back cover and its the only board right in the middle with the power wires on the bottom . there are 4 screws to remove and unplug and label the wires and replace put back together and should be good as new.
Please rate my answer its much apreceted
Jan 11, 2008 | Insignia IS-LCDTV32 32 in. Television
Dark screen, no sound
1. Check the Power Supply board to see any blown cap? Output voltages are normal?
2. If Power Supply board is ok, replace the Main Digital board.
Dec 18, 2007 | Insignia IS-LCDTV32 32 in. Television
Insignia 32 inch LCD TV: Can not change Channel or Volume !
I have one in my shop with the same problem. Power is the only function that works. I repaired the power supply six monts ago. Now it looks like a bad digital processor board which is non-repairable. I can't believe what's happened to the tv business. Absolutely disgusting!
Oct 12, 2007 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
728 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
