Question about Kenmore 73932 Gas Dryer
My dryer runs but doesnt heat
I am trying to determine if i have enough yoltage to my dryer
  • beatlelina Oct 31, 2008
    where is this fuse located
  • 550 Answers
Most common cause of no heat to either electric or gas dryers is failure of the thermal fuse
followed (for gas, this is posted to gas dryers) by failure of the flame sensor or igniter
all of which are easily accessible
once the cover is opened as described in any of the 'changing belt' threads or in Jokso's excellent howto articles
Posted on Oct 30, 2008
  • AlmostBob
    AlmostBob Nov 02, 2008
    the thermal fuse, or is located on the fan housing or exhaust duct close to the fan housing, thermostats may have 3 wires, a thermal fuse only has two.
    the test of thermostats and thermal fuses is simple, when cold they conduct, when hot they dont. failed they dont conduct at all
    There is often another similar device a cool down thermostat, that conducts when hot and doesnt when cold, that device it the only one that is in the motor cirucuit instead of the heater circuit.
    with power disconnected, open the case as described in any of the 'change belt threads' for your model
    remove 1 wire from each device( to isolate from the circuit) and test for conductivity with a meter or battery and bulb.
    If one fails, trace the wires to ensure that device is not the cool down thermostat, then take the failed one to the local parts store. the parts 'guy' will have the part they are common to most dryers. it may be lablled whirlpool or roper but is the same.
    ~$14
    takes me 25-30 minutes but I do this three or four times a month.
    If a gas igniter or flame sensor, its not my experience, I call a gas guy, gas scares me.
Dryer does not heat up checked all thermostats and replaced heating element still no luck
hum... I ve seen where the motor was only getting 120 and not 240 and with most dryers they use 2 speeds or modes on the windings , 1 direction for drying with heat and the other to run minus heat thus if u only get 120 volts u have enough to run the dryer but not enough to run the heat to that dryer?
Aug 22, 2014 | Whirlpool EED4400WQ 29" Electric Dryer...
How to use a multimeter
Reset breaker at the electric panel
Apr 02, 2014 | Dryers
Runs fine Doesn't dry clothes, not enough heat?
You will first need to determine where the problem is, I would disconnect the dryer vent from the dryer. Now if the drying improves, problem is not the dryer, its the vent system. If no change, does the unit heat at first then slowly fail to heat? Does it produce any heat? I need more information to direct you in the correct direction.
Please get back to me
Sep 08, 2011 | KitchenAid KEYS700LQ Electric Dryer
My new lg condenser dryer counts down on cycle to 11 mins then stays there for alongtime, thought its faulty but leaving it to run it eventuall then cycles down and finishes- is this OK? (ive already...
This is normal. The computer is trying to determine if the clothes are dry enough. If not, it will stay at the 11 min mark and wait till the clothes dry a little bit more.
Jun 25, 2011 | LG Dryers
First it started squeaking when it was running. Now it squeaks and doesnt heat while running Model #GLER331AS1
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 13, 2011 | Frigidaire GLER341A Electric Dryer
My electric dryer heats up but doesnt dry the clothes
If your vent hose is more than about ten feet long, your dryer may not have enough pressure to keep the air moving sufficiently to dry the clothes. Is it possible you are simply over loading your dryer?
Jan 25, 2010 | Kenmore 63942 Dryer
Dryer runs but doesnt get hot
If the dryer runs, but does not heat, the following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
The heating circuitry is usually located under the "Bulkhead Parts" section.
If you have any questions, please post back with your complete model number (usually located on a nameplate around the door opening) so that I may be able to provide you with better assistance. I hope you find this helpful.
Nov 17, 2009 | Dryers
Dryer runs but doesnt heat up.
The following link explains how to troubleshoot a dryer no heat problem:
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. All dryers are not constructed the same. Regardles of location, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
If you have any questions, please let me know. Please inlcude your complete model number (located on a nameplate around the door opening) when asking questions. I hope you find this information helpful. NOTE: On some dryers, the TCO may be referred to as a "Thermistor".
Sep 08, 2009 | Dryers
Maytag Atlantis MDE6200AYW will run, but no heat
Check to make sure that you have the proper voltage running to the dryer first. Next you may have a problem with your heating element or with your thermal fuse. Get your dryer opened up so you can see your heating element. Run the dryer and if you see the heating element come on and then turn right back off again then you have a bad thermal fuse. If it doesn't come on at all though then the heating element is bad. Both parts can be picked up at your local appliance repair shop. Just make sure to unplug the dryer before replacing the part. If you have any other questions let me know and let me know if this was helpful for you. Good luck.
Nov 22, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore 73932 Gas Dryer Logo
193 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
