Question about Panasonic NN-T990SA Microwave Oven
Panasonic GD576M microwave oven
Hi Gurus,
My microwave oven keep on blowing fthe main fuse when I press the "Start" button. Please help me to diagnose the problem. TQ in advance
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp R-510AK Microwave Oven Fuse Blows
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or a friend can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from Sears or from Tritronics at http://www.wehaveparts.com
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
WhIzAtIt
  • 136 Answers
SOURCE: Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Posted on Sep 24, 2008
Daniel S
  • 4323 Answers
SOURCE: My microwave oven has failed. Model: Panasonic
Hi
If there is no noise coming from inside the unit and everything else seems to be working fine then first test the door switch with a voltmeter, if the door switch tests fine then please post back for further assistance.
Daniel
Posted on May 03, 2011
NN 8501V Panasonic Dimension 4 Convection/Microwave oven keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
Apr 16, 2013 | Microwave Ovens
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
Microwave keeps blowing fuse
There are three possibilities, a bad magnetron, high voltage capacitor, and diode. In rare cases the high voltage transformer will be an issue but unlikely, if the microwave oven is more than 5 years old consideration should be given in replacement.
Nov 06, 2011 | Microwave Ovens
THE MICROWAVE KEEPS BLOWING FUSES, AS SOON AS I HIT THE START BUTTON THE FUSE BLOWS.iT WILL KEEP THE TIME AND THE LIGHT WILL COME ON BUT AS SOON AS i HIT START IT BLOWS
Sorry to read about your problem, I hope this helps you out.
you have a defective control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Kenmore 63792 Microwave Oven
Fuse keeps blowing Found out we shouldn't have it
A 20 will work but I would change it to the correct on as soon as possible...
heatman101
Sep 07, 2010 | Panasonic NN-S953 Microwave Oven
Main fuse blows when I press start on panasonic nn-255 microwave opened up microwave and see 25 ohms on cn702 of invertor circuit board, what's normal? This would appear to be a short to the 120v supply,...
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Apr 17, 2010 | Panasonic NN-S255 Microwave Oven
Fuse in microwave oven keeps blowing
does the fuse in the plug blow or the internal fuse if it blows the internal fuse it could be one of the door switches two of the switches have a red button on them and one has an orange button its normally the orange one thats at fault
Dec 28, 2009 | Panasonic NN-P295SF Microwave Oven
My Panasonic NN-T785SF Keeps blowing the Fuse?
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
The best place to order parts is Tritronics. You can also call them at 866-779-5835.
Nov 25, 2008 | Panasonic NN-T774SF Microwave Oven
Keeps blowing fuses
Here is a link you or someone you know can use to test it, but please read the safety info:
You can order Panasonic parts from Tritronics here or by calling 866-779-5835, but if you don't find what you're looking for there, try here.
Nov 07, 2008 | Panasonic NN-H275 Microwave Oven
Dec 12, 2007 | Microwave Ovens
Panasonic NN-T990SA Microwave Oven Logo
55 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
