LCD monitor wont work "input not supported " comes up
The monitor comes on and all the computer details come up and after about 5 seconds it goes off and " input not supported" comes on. Please can anyone help. Gillian
  • 3 more comments
  • gillyroo Nov 03, 2008
    Thanks very much , it worked ! much obliged. Gillian
  • perrH Dec 11, 2008
    I youst move the iiyama to my sons computer and now it comes up with this massage INPUT NOT SUPPORTED
  • tinahorsley Dec 31, 2008
    i have the same problem.. but when hit F8 nothing happens...no menu comes up...
  • MrRadeo245 Jan 30, 2009
    i tried F8 NOTHING HAPPENED........
  • Anonymous May 10, 2009
    i can't display the menu :( ahhh i need to remove this message that says attention input not supported plz i press F8 and nothing happens
    Problem Solver:
  • 5 Answers
Assuming you are running Windows 95, 98, 2000, ME, or XP...
During boot, after "all the computer details come up", press F8 repeatedly until a menu appears. One of the options will be "Enable VGA Mode". Choose that option. Once into Windows, right-click the desktop and hit "Properties". Go to the "Settings" tab, and change the "Screen Resolution" to the lowest possible setting (800x600 is safe). Click OK, and reboot.
Your problem should now be gone. You will want to go back into that screen after you have rebooted and set the resolution higher. At some certain resolution, you'll have the problem again. Don't go that high.
If you are using Windows Vista, then right-click the desktop, hit "Customize", and choose "Display Settings".
Posted on Oct 31, 2008
What do i do when it comes on and shows analog then goes blank ?
Are you using the analog input or another? If using another input instead, then press the 2 key. It will switch to another input as the source signal. If you still experience trouble, please contact ViewSonic technical support for assistance.
May 03, 2014 | ViewSonic VG1930WM LCD Monitor
Monitor switches on then goes into stanby
No input from Video card, try to connect second video cards head to your monitor.
Apr 19, 2010 | Dell E173FP 17" LCD Monitor
Monitor goes blank coming out of power save mode
I found this on the Internet...
"Press the "Input" button on your LCD monitor's front panel repeatedly at three- or four-second intervals until your monitor wakes up. If your monitor is set to an incorrect input mode, it won't receive a video signal. After you reset the monitor to the proper input mode, it will receive the signal and wake up automatically."
I have provided a Link with more info for you!
A
How to Get Your LCD Monitor Out of Sleep Mode
Dec 24, 2017 | ViewSonic 19'' 1280x1024 TFT LCD BLACK: 's...
Monitor comes on for seconds and then goes black
This may be because the resolution that is set in your user profile when you log on has been changed to a resolution not supported by the monitor. The best way to fix this is by going into Safe Mode (press F8 as the computer starts to load Windows) and change it to a lower resolution once you get logged in. 1024X768 is a pretty safe resolution to start with. Then restart and see if that fixes the issue.
Sep 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
Acer Second monitor
input is either digital or anolog can't be both
Jul 30, 2008 | Acer AL1715 17" LCD Monitor
Lcd monitor goes black after 5 seconds
I have read it may be an inverter. Anyone know what that is or where I can get one for the mag lcd moniter lt1919wdb?
Mar 29, 2008 | Relisys RLT1720 17" LCD Monitor
LCD Monitor Goes Black during Use
I had the problem sometimes, but then I connected a second computer to the analog input and found out, that the screen didnt turn black but switches between the inputs on an on.
I found out that the "input" button seems to be short or damaged, as the behaviour was invertable by pressing the button. I blew into the button some times (a very naive solution, yeah) but it worked, the switching stoppped.
Oct 17, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
Computers & Internet Logo
1,959 people viewed this question
David Payne
David Payne
