Question about Toshiba 50H72 50" Rear Projection Television
Tv screen problem
Then screen on my tv suddenly disappeared half screen. The part of the screen that we can see has a good image, so I don't thing it is a problem with the lamp, so can you give an idea how can I repair it? thank you
agumotta@gmail.com
  • agumotta12 Oct 30, 2008
    I will open back the TV in order to check mirrors and to see what more can I discover but I need assistance from you. Sound is good, but the image is only in about half of the screen. Which part I need to replace? advice me.
    Sergeant:
    Champion:
  • 298 Answers
I believe it is the mirror i have had a similar issue , you do not have to replace anything , just reatatch the mirror.
it is attached to the back panel of the T.V.
Posted on Oct 30, 2008
    Master:
  • 848 Answers
You have to replace convergence ICs .......
it will be available in ebay or ciao .............
  • Toshiba Master
  • 19,396 Answers
It can be a problem with the light tunnel, if the upper mirror detached you get half screen.
It can also be a convergence problem, if one of the ICs is defective.
Kv-32fd1e vertical scan instability
Post this query in a forum dealing with televisions, please - this one is for camcorders and allied equipment.
Jun 27, 2017 | Panasonic Video Cameras
As you can see, the screen isn't full, its kinda half, mom pressed something and i don't know how to fix it, please help.
The issue here is the "Format" or "Ratio" of the screen. Currently, it is set to Standard Format or a 4:3 ratio. It may also be set to 480i or 480P scan rate.
You should change it to Wide Screen or 16:9 ratio. Additionally, you will want to display High Definition images by selecting a scan rate of either 720P, 1080i or 1080P - depending on which choices are offered by the TV. Typically the remote will offer a choice of Format. It is possible that the source device (cable TV, DirecTV, Tivo, etc. has a command to cause this too. In any case, the TV, and other source appliances must be set to Wide Screen / 16:9 and 720P or higher to veiw full screen, HD images.
I hope this helps & good luck!
Mar 05, 2013 | Televison & Video
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
PLASMA TV PROBLEM
The problem with this set, is defective YSUS board, to avoid future same problem, you must change the following boards: YSUS, ZSUS & Control.
Verify with LG if your serial Number is included within
lots production that were recalled by this design defect
May 28, 2010 | LG 42PJ350 42 in. TV
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
The image disappears on my tv screen. A horizontal line appears.
You need to check the horizontal IC for deffects, possibly and most likely there are dry joints on the legs of the Horizontal IC. Have all the legs on the IC soldered nicely, this shud sort out your problems as you say you hit the TV then works. Try this before replacing the IC
Apr 16, 2009 | Televison & Video
Cable stations interrupt while watching DVD
Remove power from your cable set while watching DVD and see if the problem magically goes away. If that's the case, the cable box is to blame...accordianman
Feb 03, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Nov 04, 2007 | RCA F27442 27" TV
Black box on screen
On your remote should be a button called TV caption or text. Turn off the closed caption as someone hit it and turned it on by accident. If its not on your remote, then it is in the menu. Good Luck Ps Please dont forget to rate this thread.
Oct 25, 2006 | Zenith C27A24T 27" TV
Toshiba 50H72 50" Rear Projection Television Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
