Question about RCA P52926 52" Rear Projection Television
Volume distortion only on tv setting
Hi I have a RCA 52" rear projection tv. When watching tv the volume is distorted,crackels (sounds like blown speakers. I running it through a AV Receiver which is fine on radio,cd,tape. I switch back to the RCA internal speakers same thing. If I switch to DVD the sound is crystal clear whether internal or through AV Reciever. Has anyone run across this before? I would appreciate any input or suggestions on this problem. I am having problems posting with model # mine is P52810LV
  • rbanks75150 Oct 30, 2008
    I have the same problem. A repairmen told me that the dvd system uses different inputs for sound, than the tv and vcr do. Therefore, one can be affected, and not the other.
    In this case, there is probably a capacitor that needs to be replaced. He told me he would do it fro $250, and I'm trying to decide if this old tv is worth fixing.
    Temporary fix, uplug the entire unit (including cable box) for a few hours, then try it. That always fixes the sound on mine.
    Once again, the repairmen said that the capacitors get to hot when they are worn out, and unplugging the unit allows them to cool.
  • 50 Answers
RCA HAD A CERTAIN MODEL SERIES THAT HAD A REALLY BAD DESIGN,,IT SEEMS THAT SOLDER CONNECTIONS STARTED BREAKING LOOSE AND DEPENDING WHERE THEY CAME LOOSE,,YOU WOULD HAVE PROBLEMS IN THAT CERTAIN CIRCUIT..TO DETERMINE IF YOU HAS THAT SERIES,,WE WOULD NEED THE CHASSIS # ON THE BACK...
IF THE CONNECTIONS CAME LOOSE IN THE VERTICAL CIRCUIT--THE PICTURE WOULD CLOSE UP ,,IF IN THE TUNER SECTION--YOU WOULD LOOSE CHANNELS ,,IF IT WAS IN THE AUDIO SECTION--YOU WOULD GET CRACKLYN SOUND OR NO SOUND
ONE THING YOU CAN TRY--PUT IT BACK IN THE TV MODE,,GENTLY TAP ON THE CABLE CONNECTOR IN THE BACK OF THE SET AND SEE IF IT CLEARS UP,,IF SO YOU HAVE THE CONNECTION ISSUE--WILL NEED A TECH..GOOD LUCK ..TUNICA
Posted on Nov 01, 2008
My rca tv has a distorted picture and a really high pitched buzzing sound
Problem is in High voltage circuit and likely either the high voltage transformer or a connection right under or around it.
Jun 16, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Rear projection tv turned off and turned back on automatically then the picture was distorted on all inputs
Try resoldering the flyback terminals. Often they develope a crack on the pins and that will cause the convergence yo drop out as well as the set to shut down and come back on.
Jun 02, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca tv 52
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 21, 2010 | RCA P46924 46" Rear Projection Television
My tv all the sudden had all the colors distorted. It looks like I'm watching tv in 3D. Is this a major problem? Or can I fix it on my own?
No, replace STK IC, STK730-010? Located above chassis is a small board it should be on it.
Mats Electronics Has them for $5.95
1-800-628-1118
Mar 30, 2010 | RCA P52926 52" Rear Projection Television
Picture/color distorted
If the picture appears as 3D thats a simple and inexspensive repair. You can get the repair kit for your RCA Called "The ITC222 and ITC222A convergence option missing repair Kit" from www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions.
Dec 25, 2009 | RCA D52W19 52" Rear Projection Television
50 in rca tv
Either color wheel or ballast is faulty.
Oct 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA projection TV - the picture only shows red green and yellow and the picture is distorted almost concaved. It overlaps and nothing is clear. All 3 bulbs seem to be working. No idea what is wrong.
Sounds like convergence problems. This TV may not have the standard "STK.." modules. These sets are bad to lose voltage feeding the convergence amplifiers.
Mar 31, 2009 | RCA P52926 52" Rear Projection Television
Distorted image
It's possible it could be the problem cause thats the power supply ic to the convergence circuits and it only has 1 where most has 2 stk's you can get a replacement ic at the sight i posted for you with free tec support
http://servicemanuals.vstore.ca/
Apr 12, 2008 | RCA P52960 52" Rear Projection Television
Distorted picture on RCA LCD TV
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Mar 07, 2008 | RCA P52937 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
65 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
