Question about Sony KP-57WV700 57" Rear Projection HDTV
Sony projection tv 5 years old
I have a 5 year old Sony projection tv. When I turn it on it has great color then after a few seconds, maybe minutes, it turns to blue. I can see the images barely. The sound is good. After I turn it off several times (10-20) the color will stay, but today it goes to blue.
  • 2 more comments
  • Anonymous Nov 09, 2008
    same problem but in red...
  • mggall Dec 14, 2008
    kp-57wv700 5yrs old
    same problem but screen is all green
  • vmarolia Apr 15, 2009
    I have a 5 year old Sony projection tv. When I turn it on it has great color then after a few seconds, maybe minutes, it turns to blue. I can see the images barely. Now its turn blank. The sound is good. After I turn it off several times (10-20), but goes to blue and then blank.
    I have a 5 year old Sony projection tv. When I turn it on it has great color then after a few seconds, maybe minutes, it turns to blue. I can see the images barely and then turn blank. The sound is good. After I turn it off several times (10-20) but it goes to blue and blank again.
    Novelist:
  • 132 Answers
Maybe as simple as:
1. Convergence Problem - look at CONVERGENCE GALLERY . Maybe Intermittent IC causing blue shading. If not then ...
2. Corroded Green or Red CRT socket pins, or CRT board defective, causes intermittent R or G, then Blue dominates.
3. Blue CRT with internal short, blue dominates intermittently.
Most likely convergence.
Easyab
Posted on Nov 04, 2008
  • 4,234 Answers
Please confirm that your model is KP-57WV700. Also, have you noticed any pattern with when the problem occurs? Is it worse when "warmed up" or cold?
Thanks,
Dan
Posted on Oct 31, 2008
  • 905 Answers
You will need to call an electronic repair shop to get this problem resolved
Posted on Oct 30, 2008
My 10 year old tv goes off after about 5 minutes and the blue
Any colors mis alignments R,G,B.The tv have a problems known as convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced in the tv convergence board to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
My Sony 54" Grand Wega rear projection TV is 4 years old in Sep. It has started losing picture and sound for a few seconds then comes back on. It is getting more and more frequent. . . like six times in 5...
A spent bulb will cause the whole set to go off. If you have not changed the bulb in all of these years, first you are lucky, and second that is probably the cause of your problem.
Aug 23, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
60 grand wega 5 years old picture getting darker
souns like an over heating isue
try cleaning out the unit
take it to the local mechanic have him give your tv a ******* (with compressed air )
heck hes been screwing you so his kids can go to coledge for years whynot get a freebe?
Aug 04, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Clearer HDTV picture?
quite possible that the coolant is getting contaminated as thats a normal occurance with phillips after a few years. If the color seems dim and not focusing properly its almost certain that the CRT coolant will need changing
Dec 28, 2008 | Philips 55PW9363 55" Rear Projection...
Samsung rear projection tv
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
TV turns off then on again
Have you replaced its Lamp?
If not yet, its time to replace it.
Sep 27, 2008 | Sony KDS-R50XBR1 50" HDTV
Picture warped and colors not lining up
Good Day petepath7;
With separation of colors it sounds like the convergence IC's have failed., but first try unplugging TV from a/c power for 4-5 minutes then plug back in, if no fix see previous.l
Jun 21, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony Wega Rear Projection TV, Red light flasing
I had the same problem, it because of heat buildup, and the inside is fried, you need repair
Jan 02, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Yellow brush marking on Screen
Your problem is with the blue color,maybe some dirt is sitting on the face of the blue crt and is being projected bigger to the screen,you should try cleaning the face of all 3 tubes,if you familiar with tv service this should help,be careful when removing the back and make sure the set is unplug when you do the cleaning.Let us know how it goes.
Oct 06, 2006 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony KP-57WV700 57" Rear Projection HDTV Logo
285 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
