Question about Casio SI-460 Corded Phone
Casio SI 460
I have two problems. We have four lines and we have 6 phones--Master and 5 extensions. One of the extensions suddenly lost its ability to lreceive voice mai messages. Also recorded message was gone. When I tried to re-record it said memory full. There are no messages--they were all erased and the caller id was erased also. Still said memory full. I ordered a new instrument and was just going to replace that one.
That created second problem. New instrument works as a telephone but is not integrated within the 4 line network. How do I get it to integrate.
    Problem Solver:
  • 7 Answers
You need to perform a system update on the new phone.
joequevedo@charter.net
Posted on May 07, 2009
Person on other end of phone can' hear me
The problem could be coming from the Mouth piece of the Handset. Try to use the Speaker function to check this
- You can also change the Handset
Oct 26, 2010 | Casio SI-460 Corded Phone
Lost four digit code it;'s a Toshiba TV I have a One for all remote I just need the code
Ok here are the master codes for Toshiba, One of these will work for you.
Toshiba 0 1 5 4 ,0 1 5 6 ,0 0 6 0 ,1 2 5 6
Kindly rate my help++++Thankis for using FIXYA
Feb 07, 2010 | Toshiba 50H82 50" Rear Projection...
Any info on changing a brake booster on a 1996 Sierra and also help trouble shooting a master cy. Thanxlinder
a defective master has just one common symptom, a soft sinking pedal.
Instructions Things You'll Need:
  • Nose pliers
  • Ratchet and socket
  • Ratchet extension
  • Slip joint pliers
  • Wrench
  • New cotter pin
    Removing the Old Brake Booster
  1. Step 1 Park your car in a safe place with enough room to work around the front and driver side of the vehicle.
  2. Step 2 Locate the booster push rod connected to the brake pedal.
  3. Step 3 Remove the cotter pin securing the booster push rod pin to the brake pedal using a pair of nose pliers.
  4. Step 4 Release the push rod pin from the brake pedal and slide the push rod off the brake pedal.
  5. Step 5 Unscrew the four mounting nuts off the brake booster studs using a ratchet, ratchet extension and socket. You should be able to see the four booster studs extending through the firewall, in front of the brake pedal.
  6. Step 6 Disconnect the vacuum hose from the brake booster, working from the engine compartment. Use a pair of slip joint pliers.
  7. Step 7 Remove the two nuts holding the brake master cylinder to the brake booster. Use a wrench or ratchet and socket.
  8. Step 8 Separate the brake master cylinder from the booster just enough to make room for booster removal.
  9. Step 9 Pull the brake booster off the firewall and remove it from the vehicle.
    Installing the New Brake Booster
  10. Step 1 Set the new booster in place by sliding the push rod and four mounting studs through the mounting holes on the firewall.
  11. Step 2 Slide the brake master cylinder flange over the two mounting studs on the brake booster.
  12. Step 3 Start the two brake master cylinder mounting nuts by hand to avoid damage to the threads.
  13. Step 4 Tighten the two brake master cylinder mounting nuts using a wrench or ratchet and socket.
  14. Step 5 Connect the vacuum hose to the brake booster.
  15. Step 6 Screw the four mounting nuts to the brake booster working from inside the vehicle. Start the nuts by hand to avoid damaging the threads.
  16. Step 7 Tighten the four mounting nuts using the ratchet, ratchet extension and socket.
  17. Step 8 Position the brake booster push rod over the brake pedal and slide the push rod pin.
  18. Step 9 Install a new cotter pin to secure the booster push rod to the brake pedal
Nov 20, 2009 | 1996 GMC Sierra
AVAYA PARTNER ACS PHONE SYSTEM - Voicemail/Greeting capability
Yes you can have the 2 lines answered by a particular mailbox instead of the AA greeting.
Would need to know the model of the voicemail system that is installed to see if there are more than 1 AA menus.
Oct 06, 2009 | Avaya Lands Phones
Lucent Partner 34D phone system with 18D extensions
That doesn't sound good at all. I would first try powering down the system and waiting about 15 seconds or so before powering back up. If the problem remains, the processor was some how damagedand would be best if it was looked at by your vendor.
Sep 25, 2009 | Avaya Lucent Partner 616 Phone
Is there a way to disallow all outside calls and
You could just remove the lines off of that extension:
1.Go to extension 10 or 11
2.Press (feature) (0) (0) (left intercom) (left intercom)
3.Press #301
4.Enter the extension # you want programmed.
5.Enter the line you want removed (line 1 =01 line 2 =02)
6.Press 2 to remove that line
7. Repeat steps 3-6 for all lines you have on that extensions.
Hope this helps!
Sep 01, 2009 | Lucent PARTNER18 Corded Phone
Auto attendant
I was poking around on the web and found your question. I designed the SI-460 a few years back. Casio, sadly, shut down their phone division.
I can e-mail you the owners manual (PDF) if you need it.Anyway, in case you haven't figured it out:
To turn off the auto attendant:
Press the PROGRAM key.
the display will indicate:
PLEASE SELECT
PNON ANSW OTHER
Press the key under ANSW
The display will indicate:
AUTO ATTND: ON
BACK CHANGE NEXT
Press the key under CHANGE
AUTO ATTND:OFF
BACK CHANGE NEXT
Press the program key to end the process.
Good Luck.
Joseph Quevedo
Jan 17, 2008 | Casio SI-460 Corded Phone
Casio SI-460 phonemate executive series corded phone
I have 4 Casio SI-460 and I am having problems turning my auto attendant off. When I put someone on hold, then physically walk to the person to inform them of the call, the person in the other room can't answere the phone. When he picks up the phone the phone just beeps as if the battery is low, but it's not. The person has to come to my room and get the caller off hold in order for him to speak to them. Why is this happening? I have a manual and it saids to do steps 1-3. When I get to step 3, it doesn't allow me to use the soft key on/off button.
Jul 21, 2007 | Casio SI-460 Corded Phone
Programming tree options are different from what's on the manual
All phones need to be individually programmed to ring on lines one and two, all phones need to have a "system update".
Scott
Apr 24, 2007 | Casio SI-460 Corded Phone
Open Questions:
Casio SI-460 Corded Phone Logo
128 people viewed this question
Top Casio Lands Phones Experts
Patrick Tinashe...
JonSnell Electronic
JonSnell Electronic
Tom Chichester
Are you a Casio Lands Phone Expert? Answer questions, earn points and help others
