Question about Canon PIXMA MP530 All-In-One InkJet Printer
Printer wont print
The power buton is on n the paper will run threw but it wont print anything on the paper
All the colors print. When the nozzle check is performed the PGBK does not show. Any check that is ran this is what happens. If anyone knows what's going on HELP please.
Posted on Nov 16, 2008
Wont print. Cant detect paper.
There's a problem with the software in the unit. Brother does no longer offer software updates. You can try and power off the unit, unplug the USb cord from the back of the machine. Wait 1 minute, plug the USB back in and power the unit up. After unit cycles, should be ok. If not, uninstall/reinstall the software///
Jul 22, 2014 | Brother MFC-9840CDW Laser Printer
Why does my epson 1400 keep loading paper straight threw instead of printing?
I have had this problem several times. The culprit is the feed wheel which can get covered with paper dust and it loses it "bite". Epson sells cleaning sheets that are tacky and when run through the printer remove this "dust". I have also resorted to taking a piece of scotch tape and carefully sticking it to the rubber take-up wheel and then gently removing it to pull the paper dust off with the sticky tape. Another problem can be because of not setting the paper type correctly. Check to make sure that the paper type set for the printer is the same as the paper you are feeding.
Nov 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Printed 1 document of two, then check paper and print cartridge lights started blinking
You need to check for obstructioin of the paper way, for obstruction.
Press the paper advance feed buton.
Then reset the printer.
Jan 16, 2010 | HP Photosmart C3150 Printer
HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Jul 21, 2009 | HP DeskJet F380 All-In-One Printer
Paper light is on but not blinking, wont print
Sounds like a communication error somewhere between the printer and your hardware. You might need to update the driver. Go to the manufacture's website and put the model number of your printer in to get the latest driver. There might also be a driver specifically for your Mac there.
Feb 26, 2009 | HP Deskjet 6980 InkJet Photo Printer
Paper Feed is Jamming
unplug the power cable and the usb cable from the back..........press the power buton for 20 sec........its to release the static from the printer...replug all the cables......printer would work properly now
May 22, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Paper feeding problem
Try looking inside the printer and make sure there is nothing foreign in the paper path. I once threw away a printer that wouldn't feed. The next time it happened on my new printer, I was admonished to check the paper path. Lo and behold there was something down in there that prevented the paper from loading properly. You might have to remove the printer case (cover) to inspect thoroughly. Now I use a printer cover when not in use to keep dust or anything else from getting in there. I've spent too much time and money from printer problems and a cover is cheap insurance.
Apr 27, 2008 | Epson Stylus Photo R200 InkJet Printer
Blank printout
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
193 people viewed this question
old marine
old marine
