Question about Panasonic VDR-D100 DVD Camcorder
Message says door open when it is closed
My camcorder won't read or record DVD due to a message that says that the CD door is open, but the door is clearly closed all the way. I pressed the reset button and removed the battery a couple of times already, but that did not fix it. I have to remove the battery in order to shut down the unit, otherwise the light stays on when the switch is off. Please help.
  • 905 Answers
If there is a sensor that detects the door then it probably needs to be replaced
if it is a switch that detects the door the switch will need to be inspected
it will need to be tested to determine the exact cause of the malfunction
there is an electronic circut not detecting the door
electech
Posted on Oct 30, 2008
How do I play cds on my Philips portable stereo with the message 'door open'?
It could be caused by a small contact switch inside that has either broken or is stuck in the door open mode.
Oct 18, 2017 | Audio Players & Recorders
Panasonic DMRES15 DVD Recorder disc not spinning
Troubleshooting Solution
1.Display Message " Please wait" Not
booted
2.DVD-Rom Two-Three times make noise but doesnt spinning
3. Doesn't
open tray, No video OUT
1.Bad Main Board VEP79117
2. Bad DVDROM
3. Bad Prosessor
PCB
Mar 16, 2013 | Panasonic DMRES15 DVD Recorder
Have a panosonic dmr-ez485v dvd recorder that cycles 5/6x when tray is closed with/without a dvd, and get "no read' message.
1.The DVD Drive makes two-three times noise than stop spin the media CD
or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray,
close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Check: avsystemparts.com
Feb 01, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
Have panasonic dmr-ez485v error message -NO READ- changed disks used prerecorded movie same as my recorded disks, hit reset - still no change
I just saw the date on this message and realize that it was awhile ago. I assume that you have dealt with it by now... So for others who are trying to fix their DVD player:
I have a DMR-EZ485V DVD player and just started getting the error message "No Read." I couldn't find an answer on the internet and finally called Panasonic's customer service, (there is no charge 1.800.211.7262). Since it says "No Read" to everything--store-bought DVDs, burned DVDs, CDs; AND when there is nothing in there (it acts like it is trying to read when the tray is empty), the customer service rep thinks that I am having a lens issue. It either needs to be cleaned (can pick-up a product at Best Buy or Radio Shack) or, if that doesn't work, the lens needs to be replaced.
Aug 09, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
The player only intermittently recognizes CDs inserted; it does not seem to make any difference whether they are commercial, recorded at home, etc. Sometimes it says "insert disk," sometimes "no disk." ...
A CD tray is usually powered by a rubber strap, the belt can slip through, causing the electronics to miss the input timing, including a microswitch or copper contact which is activated at the closed disc tray so that the laser is focussed to read the table of contents Due to the fact that the spindle motor is activated. And in some players (interchanges there is also a selects witch that can be contaminated. a suggestion to help in the link
How to Fix DVD or CD Player That Won Open
Jun 30, 2017 | Philips CDR950 CD Recorder
"CHECK DISC" message
The DVD which you have formatted might have got corrupted. In most of the cases, some camcorders or other devices will not accept the formatted DVD's. Try using a new DVD CD.
Feb 08, 2009 | Hitachi DZ-MV550E DVD Camcorder
E04 Error
i had the same problem with my cam JVC GR-DVL309 and i solve it.
HOW!
Eject the tape, reinsert it BUT while the tape is going down to read, push the door with your hand just a little bit to right side just a few seconds while is reading the tape and close the door, (i had done this 2 or 3 times) this way i have solve the E04 Error, now i can record and play with my cam.
Apr 10, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Hitachi-DZ-MV550A
eject the disk and if it it empty just open the cd door. with the lense to the left and the door on the top. look into the device. You will see to the left side a metal platform that houses the dvd laser. take and push the platform all the way to the left. The platform fails to retract once you do this you should be able to use a disk like normal provide you have a dvd-r disk.
Nov 26, 2006 | Hitachi DZ-MV580A DVD Camcorder
Panasonic VDR-D100 DVD Camcorder Logo
80 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
