Question about Masterbuilt ESQ30B Smoker
My electric smokers heating element does not get hot-after only about 20 uses-Any suggestions-The manufacturer said they would need to send me a new box for $199-Seems rediculus this cant be fixed?
  • 2 more comments
  • sterey Jan 10, 2009
    My smoker is having the same issue. I called them and they said I probably need a new element, but they are on backorder for at least 4 months.
  • jerylcollins Feb 01, 2009
    after 14 mos. of good use.....the smoker no longer will heat up. Can the heating element be replaced or the temperature controls?
  • Anonymous Mar 29, 2009
    Same same
  • flyer718 Mar 30, 2009
    Wow that is crazy Sterey, I was told the element was NOT replaceable and that they wanted me to pay $180 plus shipping for a new box (with burner)
I just had the same issue and almost had a Thanksgiving disaster! Try unplugging the connection between the smoker and control pad. mine looked like it was on, i could set the temp, time and get a reading of temp, but it must not have been sending the 'heat' command. also, bass pro has thios on sale tomorrow for 129
Posted on Nov 27, 2008
Why after five minutes or so of becoming hot does the grill trip my power
When you say power I am guessing you mean the ground fault switch. Struggled with that myself until recently. There are a lot of posts out there of people with this problem with a variety of smokers. Try plugging into an outlet not protected by a ground fault outlet. If the smoker works that way (mine did) I would suggest you replace the electric heating element. For $30 bucks or so this fixed my smoker. Found my part on appliancefactoryparts.com. My smoke is a Masterbuilt brand. Putting the new element in was pretty easy but a bit messy. Look for a video on YouTube for your smoker.
Good luck and happy smoking.
May 07, 2016 | Grilling
I need a new electric heating element for my Little Chief smoker
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dsporting&field-keywords=Little+chief+replacement+element&rh=n%3A3375251%2Ck%3ALittle+chief+replacement+element Here is one source....
Jan 15, 2013 | Grilling
My electric digital smoker wont heat. The timer works fine and the temp sets fine, but the element will not heat up . LAst use was the same problem then it eventually came on after some jostling of the...
Hi tee1134400...
Check all your connections going to the heating element...sometimes they will get corrosion on them and cause them not to function properly.
Please take time to rate me
Sep 22, 2011 | Masterbuilt 20070106 Electric Smoker
While using my Masterbuilt smoker (Model 20070106) the temperature began to gradually decrease and now it will not heat at all. I'm sure the heating element needs to be replaced but I am having...
SgtDave - Don't feel like the Lone Ranger. There have been a bunch of people seeking either the burner element and/or the electronic controls. The burner element is available form Appliance Factory Parts, but only with the smoker box. At one time is was sold separately, but now, the element by itself is no longer available. Even Masterbuilt no longer sells just the heating element. In part, if you check your Owner's Manual or the Manufacturer's Data Plate on the smoker, take note of the Country of Origin, you'll understand why.
Wish I could have been of more help to you.
Jul 11, 2011 | Masterbuilt 20070106 Electric Smoker
Bought little chief model 20 smoker don't know how to use it...
The Little Chief smoker, manufactured by Smokehouse, is available in front-loading and top-loading styles. Both models are electric, depending on a 250 W electric heating element to supply the heat. The smokers can accommodate a maximum of 25 lb. of meat or fish. These smokers are for outdoor use only, and plug into a 120 V AC electrical outlet.
  1. Brining
    • For extra flavor, treat your meat, poultry or fish to a brine bath before smoking. Use 1 cup of kosher salt for each gallon of water. Consider adding molasses, spices or even a pureed jalapeno pepper or two into the brine solution. Leave thicker pieces of meat in the brine solution overnight. Fish only need to be soaked in brine for around four hours.
    Wood Chips
    • Mesquite and hickory are probably the two most widely used woods for smoking, but apple and pecan wood can give your smoked foods another tasty dimension. As with anything else, experiment to create your own favorites.
      Smoker wood is sold either as chips or chunks. Use large chunks to smoke thicker pieces of meat; the chips will be spent before they have thoroughly smoked the meat. You can continually replenish the chips, perhaps every half hour, for as long as you wish to smoke the food, but the job can be tedious with a large roast that takes hours to smoke.
      Smoke the wood well before it is introduced to the heat. Chips will be completely soaked in a half hour, but chunks of wood will require an overnight soaking before use.
    Smoking
    • When your meat is thoroughly brined, and the wood soaked, carefully lay out the meat on the smoking racks. Make sure that there is some space between each piece. Place fish on the rack with the skin-side down. Drain your wood and place it into the smoker on top of the heating element. Use the small pot that is provided to keep moisture or collect juices. Place the racks into the smoker and close up the box. Plug in the electrical cord and within about 10 minutes, you should see smoke gently trickling out from the smoker's vents. The thicker the food inside the smoker, the longer the process will take.
    Mar 18, 2011 | Luhr Jensen Little Chief 9800
    I'm getting power to my smoker but the heating element is not getting hot. What can I do?
    Get a voltmeter or multi-tester, test power to the element. If there is power, then heating element is bad. If not power to the element, then temp sensor or control board may be bad.
    Sep 06, 2010 | Masterbuilt 20070106 Electric Smoker
    My heating element is not working. How can I get a replacement.
    I experienced the same problem. My heating element was not working. After a Continuity Test, the Heating Coil was dead and needs replacement. I asked Masterbuilt if any heating coil replacement parts were available. They said "no", but they could offer a discounted sale on a new Smoker for about $175.00. I am still looking. A local appliance dealer said the internet was the most likely place to find one. After looking on the internet, I can't seem to find one yet. If you know of any, please let me know. Call (616) 772-1332 and ask for Bob. Thanks
    Jul 10, 2010 | Masterbuilt 20070106 Electric Smoker
    My electric smoker keeps tripping breakers
    My Brinkmann 810-7080-4 Gourmet Electric Smoker was tripping my GFI after it sat for the winter. Would heat for about 3 minutes then trip the GFI. would keep tripping GFI until it cooled down and once again would trip after about 3 minutes.
    --SOLVED: took 00 steel wool and olive oil to the heating element and removed what looked like a green fungus. Element is working fine now, not tripping the GFI and will run a full four hours for smoking!
    Hope this helps save someone some money in purchasing a new heating element ($40).
    Nov 26, 2009 | Brinkmann Smoke' n Grill Electric Double...
    Tripping the electrical Breaker
    I have used the charbroil bullet electric H2O smokers for years (wore 2 out - currently on my 3rd). I won't use anything else (having used many, many others - HOWEVER - as with every product made there are things to watch or overcome. Learn to use it properly and look forward to many years of great BBQ.
    Ambient (outside) air temp below 70 (depending on wind also) will affect these smokers drastically - highly recomend getting or making a "smoker blanket" (got mine at cabelas years back - if you can't find one welding blankets from an industrial supply store can be made into one) to insulate the sides - this drastically reduces heat loss and reduces the electrical load.
    Another MAJOR mistake many people make is extension cords - avoid the use of them at all if possible - if not possible then purchase the heaviest gauge you can find.
    Always pre-heat your smoker - Always use boiling water (or other liquid) in the H2O pan added after smoker is pre-heated - Always minimize opening the smoker once cooking has begun.
    The heater element can be cleaned when cold with a very mild detergent and room temp water.
    If you have the large 2 rack but are only smoking enough to use a small amount of rack space on only one rack remember that you are heating a whole lot of air - i have a couple (different size) wood boxes wrapped in foil to take up excess air space - this means less air volume to be heated and better heat control - DO NOT use cardboard boxes or other low temp combustable items in the box construction!
    Make sure the house outlet you are plugging into is a 3-prong GROUNDED outlet on a 20 amp breaker.
    Finally, make sure your smoker is level and remember there can be up to a 20 degree cooking temp swing in temp between the bottom rack and top rack (top rack 5-20 degrees hotter than bottom).
    The heater element will cycle on and off during normal use.
    Good smoking and enjoy.
    Apr 28, 2008 | Char-Broil Electric H2O Smoker
    Electric water smoker low heat
    Make sure the house outlet you are plugging into is a 3-prong GROUNDED outlet.
    Dec 04, 2006 | Char-Broil Electric H2O Smoker
    Masterbuilt ESQ30B Smoker Logo
    1,035 people viewed this question
    Top Masterbuilt Grilling Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
