51 and 1168 are O2 sensors. Check for vacuum leaks and make sure the hoses are hooked and tight from the air filter box to the throttle body. P0725 is engine speed sensor/ input shaft speed sensor on the transmission.
Hi, The hesitation of the wipers in delay cycle is normal. You can twist the nob on the end of the arm to speed up or slow down the hesitation. If you are driving in a light mist and the wipers ran at normal speed most of the time the would be wiping a dry windshield. Chattering and bouncing. With the delay set at the right speed the wipers only go on every so often, No dry chattering. In a full rain just twist the knob past the delay cycle to get low or high speed from the wipers. Hope this helped you. Wayne
AWD is computer controlled in your 05 Murano. AWD lock is for low speeds under 10 MPH or something like that. I've had my 05 Murano since 05 and never used AWD lock. Between VDC and AWD I've never had any problem getting around. My salesmen told me it was for low speed/towing...I never tow so I've never used it.
use an engine flush when changing oil/filter use only 10/40 semi synthetic oil(change every 10k)top end chatter occurs when engine is cold/oil not up to followers,but should stop about 30 secs after starting engine.there ARE NO adjustments AT ALL.if chattering persists,then top end rebuild req.
the person who told you about "rockers"should learn about self adjusting valve followers....
these 3.3l engines are equipped with timing chains. if vehicle has prolonged down time, typically more than 4 hours, vehicle makes a chatter until the timing chain tensioners put tension on the chain. you will need them replaced.
Bulb can be replaced. You can buy at Walmart or your local parts store. I recommend replacing both. They are rated for the same amount of run hours and will usually fail within the same month.
