Question about ViewSonic Computers & Internet
Viewsonic Monitor black screen but when turned off and then on-the screen will come up for a couple seconds and then go away
  • henderson442 Nov 10, 2008
    I have exactly the same problem.
  • 4 Answers
This problem have 2 posiibilities
1)solder lose on the vedio socket and around horizental circuit
2) the line
and mostly in viewsonic and compaq its the line wich you need to replace it if you can find it in the market
Posted on Oct 31, 2008
My viewsonic vs11661 will only come on for a second then goes off.
This indicates a high voltage problem, since smoke was seen, the cost to repair will exceed the value of a new one.
Apr 18, 2012 | Computers & Internet
Black screen
The problem could be in the Monitor, Computer or Cable. Did you try to connect another monitor or can you try to connect another computer (maybe a laptop) to that monitor?
It's important to understand where to start.
Nov 09, 2007 | ViewSonic E70fb (Black) 17 in.CRT...
The Screen comes on for 1 second then goes black but you can still faintly see the image on the screen
It can be as simple as bad DC filter caps (leaking/bulging tops), that will be the first thing to look for, it can be more serious problem in the inverter circuits or bad CCFL assemblies.
Failed TV and Monitors:
Capacitors kit: he can make you a set of caps for you.
Sep 06, 2010 | ViewSonic Graphic VG2021m LCD Monitor
Black screen
Don't let the computer turn the monitor off. Go into control panel and click on power option. don't let the computer turn anything off and disable hibernation if on. go to screen saver and have it come on in about 30 mins.
May 27, 2009 | ViewSonic VX2235wm LCD Monitor
Viewsonic monitor goes black one second after startup screen boots up. Fix for this? thanks
plz log in safe mode and then disable the display adapter from the device monitor then log back normally and check whether problem is solved or not
Apr 29, 2009 | Computers & Internet
Viewsonic VG 900 displays briefly, then goes blank
What Usually causes these to go on and off quickly is one af a couple things.
Usually it is the powerboard not putting out enough power to run the video board and the inverter.
Sometimes it is the actual inverter board. I have seen a plain small fuse stop these cold.
Rarely, but it could be a bad bulb in the screen. Bad bulbs usually start dark in the middle, or they start off pink. They can also flicker while they are on.
If you can take it apart and have a dc tester, the problem may be able to be found.
I repair some viewsonics , mostly VXs series, but I have done a couple of these.
Oct 11, 2008 | ViewSonic VG900b (Black) (10 Pack) Monitor
Repair manual
Problem solved! The main power thingy (the thing with the big red wire coming out of it) was all black and dusty. There was 'soot' all over the whole insides of the monitor. I concluded that this monitor should be laid to rest, and a new flat-screen monitor erected in its place.
Nov 18, 2007 | ViewSonic G220f (Beige) 21" CRT Monitor
Computers & Internet Logo
746 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
