Ei systems 4411 wont power on/mains or battery power
Hi joe ei systems 4411 my brothers laptop wont power on from mains or battery he gets 3 green lights as if to boot then goes off again does same from mains or battery its a p4 cpu the fan does not spin either would it be the processor thanks jake
  • 4,338 Answers
If the fan does not spin, the unit is shutting down to protect the processor. I would have the fan replaced . Do not attempt to use the laptop, it may cause extensive damage if it overheats.
Joe
Posted on Oct 31, 2008
My chair is on fiashes 6 times wont do anything
Hi Randy,
I have a jet 3 ultra which looks similar to your jazzy and the indication of six flashes says;
'the power chair is being inhibited by the battery charger.Unplug the battery charger.'
I can find no more detail relating to this so whether you wait a while before reconnecting I do not know.
A link to the manual for your chair is here for downloading;
http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CCUQFjAB&url=http%3A%2F%2Fwww.pridemobility.com%2Fpdf%2FOwners_Manuals%2FUS_Jazzy%2FUS_Jazzy_1113_ATS_om.pdf&ei=yHk8VKCABIGD8gX044GYCA&usg=AFQjCNFgl8AbsrG2Kx-HWpnpR_WL35f_kw&sig2=31yJQkWKKHPa4zlWAJtRLg&bvm=bv.77161500,d.dGc
Best of luck.
Joe
Sep 27, 2014 | Pride Jazzy 1113 Power Chair
Ei systems 4411 wont power on mains or battery
Try pulling out and putting back in place the ram modules, the motherboard can be faulty.
Oct 30, 2008 | Computers & Internet
Ei System 4411
Here's one link for your solution:
http://www.crucial.com/upgrade/Ei+System-memory/Ei+System+-+All+Models/4411-upgrades.html
Mar 31, 2014 | Computers & Internet
How do i restore factory settings on ei system 4411
It does not look like there is a restore partition, you would need the restore CD that came with it...
go HERE
The URL is a little wierd, If it doesnt work, I will repost with the correct one.
Aug 04, 2009 | Computers & Internet
Ei systems laptop memory upgrade?????!!!
1gb ram will speed up your access memory you will notice it a little faster when going from web site to web site but to really speed it up you need a faster prossesor or / and better broadband
Apr 01, 2009 | Computers & Internet
The most likely cause of your ills is a failed motherboard Jake. Processors are pretty tough but unfortunately HP did a lousy job with the motherboards on the DV series and many, many of them fail and usually after the warranty is over.
Oct 30, 2008 | HP Pavilion dv6000z Notebook
EI System 4411 Laptop
go to the control panel, internet options, connections tab, then check mark "never dial a connection".
then try to connect.
Sep 27, 2008 | Computers & Internet
Ei systems 4411 Battery driver/not charging
first of all check this battary with another same configured laptop of your's.. i guess this problem should be with your battary...
thanks
Mar 31, 2008 | HP Pavilion dv6000z Notebook
Laptop battery
It does charge until the battery reaches full charge, then charger stops and laptop use adapter's power. The whole system is thought to not damage or wear the battery while in charge. Leave battery safely inside your Dell while using it with power adaptor, it should not make any difference in your battery life.
regards
Mar 21, 2008 | Dell Inspiron 6400 Notebook
Im after a user manual for ei systems 4411 laptop i need to locate the battery
Hi, as far as a manual, I googled all over the place with no luck. I did find this, not what you wanted to hear. I don't know that particular model so I can't tell you where your battery is, sorry. Mechanic
http://support.thetechguys.com/layout.aspx?ID={0575f203-9450-4588-b670-618e5c6cc804}&CatID={47986c22-40fc-4c5b-ae38-a68874fdb04f}
Jan 15, 2008 | Computers & Internet
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
