Question about HP Inkjet 1200dn Printer
How do you clean the printheads?
The printhead light and the yellow color lite are blinking. I need to know the proper method of cleaning the printheads, I cannot find it in the Getting Started Guide.
3 drops of water to each print head and then gently wipe them dry with a paper towel.
Posted on Nov 18, 2008
Yellow printhead on my Designjet 3500CP isn't releasing ink
If you can access the printhead, try taking a rag with a small area heavily wet with Denatured Alcohol (this is a cleaning solution that can be purchased at Walmart or most stores with cleaning supplies. Rub the printhead thoroughly with the alcohol for a minute or two, it should help loosen any dried ink. Then try to print or run a print head clean cycle on the printer.
Nov 03, 2017 | HP Designjet CP UV Yellow Ink System...
My HP Officejet Pro K8600 won't print black. I have changed the printhead, the cartridge. I have soaked the printhead, I have shaken head. I am getting yellow ink out but no black. I have run every...
Materials needed: New empty syringe (big one) Gloves (to protect your hands fromink) Alcohol Paper tissue (to clean the excessink) Empty Plastic bottle (Here you putthe ink from the syringe) Important: Ensure that you have put new blackink cartridge to K8600. Ensure that the printhead arerecognized by the printer or no light alarms. Instruction: Press the Power button to turn onthe printer. Test print in microsoft excel with4 color black/yellow and cyan/magenta. If black only is missing means youhave clogged problem from the host. Wear your globes, prepare thematerials needed. Open the top cover. Press and hold the Resume buttonuntil the carriage moves to the left. CAUTION: Be careful not to proceed until the carriage is on the left sideof the printer. If the carriage does not move to the left automatically, turnthe printer off and back on and then try holding down the Resume button again.The printhead can be damaged if the carriage is not all the way to the left forinstallation. Lift the printhead latch. Lift the handle of a printhead anduse it to pull the printhead black/yellow out of its slot. Put printhead in thepaper tissue upward. Your printer are still ON becarefull not to touch the flex copper circuit. Get your syringe, use this to pullthe ink from the nozzle cap ( see link picture) After the done the syringe method,Insert the printhead black/yellow into its color-coded slot. Press down firmly on the printheaduntil it snaps into place. Pull the printhead latch all theway forward, and then press down until the latch engages. Close the cover. The printer should align theprintheads automatically in a few minutes, printing an alignment page. Print a test with black color only,If it does not print, try to change the Printhead. This is the only solution I foundin my HP k8600 black ink problem._579.jpg
Jan 24, 2011 | HP OfficeJet Pro K8600 Printer
Light yellow horizontal lines on C522
Remove the supplies and clean the yellow printhead. For instructions on how to clean the printheads, click on this link: Just follow the instructions. If that doesn't help, might need replacement. If issue remains after printhead has been cleaned and the supply has been replaced, I suggest you contact Lexmark Technical Support for further assistance. Thanks.
Jul 11, 2010 | Lexmark C522n Laser Printer
New ink not working three different times buying it and taking back ink very light or none at all no red it shows up yellow?
Have you done the cleaning the printhead? if not please run your clean printhead, if your using 5100 printer you can only do clean printhead by launching your home center, just click the help icon(?) under that click maintenance for you to able to see clean printhead
Now if you already done with this torubleshooting and still you haved incomplete color or incorrect colors printouts it means you printhead is defective., YOu need to call kodak tech support for printhead replacement i think its free of charged 1 800 421 6699 ext 05 toll free
Nov 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Print test shows yellow block top half as a light color yellow and the bottom half as a normal darker yellow. tried cleaning a few times and no help.
There could be some paper scraps on the bottom of the printhead, take it out and blot gently on a damp paper towel, if it doesn't help, you'll need a new printhead.
Aug 14, 2009 | Canon I960 InkJet Photo Printer
HP Officejet K850 pro prints black ok, but colors are poor
I read earlier that black and magenta were printing but not cyan or yellow.....HP says to gently wipe the side of the electronic band but not the bottom, I did all of the above...and the printheads carefully, no change w/ the printout from "clean printheads"...the cyan had an occasional blue line(very fine) and there was no yellow.
So I trickled warm water over the cyan and yellow printheads....then thought what the heck, got a bowl of warm water and swished the printheads half submerged. They print perfect now I have the reds, yellows, greens and all the colors back w/ the clean printhead option and printed a coupon, it was perfect.
I hope it's not a short term fix...I developed the problem when I didn't print for a long time, hope this helps someone, Cyn
BTW, I flashed a light down in the recepticle for the cyan and yellow printheads and they were gunky w/ blue and yellow gook, so I clean that out w/ a damp lint free rag....paper towels shredded and I had to carefully remove the remnants.
Jun 17, 2009 | HP Officejet Pro K850 InkJet Printer
Help with my k5400
It's possible you have one of the following problems:
  • Printhead is faulty
  • The printhead has expired (HP printheads have an expiry date which is written into the chip)
    In both of these cases contact HP support to request a warranty replacement (but try the ideas below first obviously :))
  • The printhead hasn't been inserted properly
  • The chip contacts are dirty or soiled in some way
    For these last two, try removing the printhead, cleaning the chip carefully with a cotton bud and then replacing carefully.
It's also entirely possible that you've been sold a lemon in which case you need to call the store you bought the printer from and get them to troubleshoot the issue with you and/or replace it/refund your money.
Hope that helps.
Jun 11, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
Yellow ink is not printing properly
i think your cartige yellow ink had finished or dried up what u can do is refill yellow ink or dip cartige into hot water.... and clean it nicely it works
May 20, 2009 | Canon Pixma iP4500 InkJet Printer
HP K5400: Y and B color are failing printing
Turn Off Your Printer Remove K&Y Printhead from your printer. Put the Printhead in the bowl in the same Position As in the Printer And Pour Little hot water in the bowl till the printhead is half dipped in the Water. Leave in for 15-20 Min. after that Clean the Printhead with clean clothes.. Must Ensure that no Water is in the Circuit of Printhead. leave the printhead for 30 min. After that put Back in the Printer. You will Get the Better result than ever BUT PLease Donnot use clean Printhead Utility immediately after this process use after the Day. If it Doesnot Work Then Clean the Printhead in Hot Water Several Times.. Do not Remove Printheads Regularly From Your Printer..
I Have the Same Printer And Suffered Same Problem A Month Ago with Yellow Colour...
Apr 29, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
My color pictures are light and not colorful.
Maybe you are not using Kodak cartridges, however I know someone who has had the printhead replaced 6 times untill the problem was solved with a new printhead, I would phone Kodak and ask them to replace the whole printer in case it has a manufacturing fault, ! A brilliant printer when working but too many problems arise in use.
Dec 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP Inkjet 1200dn Printer Logo
141 people viewed this question
Ben Johnson
