Question about HP 920 Plain Paper Fax
Printing problems - splits received pages into multiple pages
It doesn't seem to recognize the page size, 8.5 x 11 with normal margins will printout on two pages.
    Genius:
  • 2,120 Answers
Unplug the machine for 10 seconds.
Your machine must be set for AUTO REDUCTION
Posted on Oct 30, 2008
When I print a multiple page document on tear paper roll, the first page prints correctly but the pages after that start printing too near to paper tear size or up to paper tear size. What should I do
Sounds like your top margin is not either not set properly or your documents do not have page feed command at the end. Are you sure you have the correct driver installed?
Nov 23, 2014 | Epson Dot Matrix LQ-2090 Printer
P2035 incorrect margin output
The page size its correct?(paper, A4,letter....etc).
Do a test page on windows and see-it.
Check the size of paper!
Apr 10, 2012 | HP P2035N LaserJet Monochrome Printer
When printing a duplex booklet, the printout is reduced in size with larger margins than in original document. How can I get it to print regular size?
It happens when the documents is on A4 size and the printer is set to print on letter size (which is smaller in size). Hence the printer automatically resizes the prints which result in larger margins and print as compared to the actual document.
Therefore, when you print the documents (Press Ctrl+P) you have to select the paper (A4) from the print properties.
Hope it helps! Good Luck!
CreativeTECH
Mar 02, 2011 | Brother MFC-9840CDW Laser Printer
MY printer stopped working from on day to the next...the problem is when I print out a photo from IPhoto or Preview on my IMac OSX10.4.11 it starts with a large margin which doesn't allow for the complete...
Hello
Large photos are printed differently than regular photos.
Photos that have large resolutions or are best when printed in larger sizes are sometimes printed on multiple pages. Printing the photo on two or more pages requires setting up the printing options so that the printer recognizes how the photo should print and which areas to stop printing on each page.
Open the photo in iphoto
Select "File" and scroll down the list until reaching "Print". Click on "Print" and wait for the printing set up options. Some programs require selecting "Set up" or "Print set up" instead of "Print." Make sure the set up options are brought up according to the program.
Select "Time Imageable Table" or similar options in the program. If there is not an option with a similar title, look over the various titles and any pictures that come with the titles and see if the pictures show multiple pages or only a single page. Click on the options that allow printing one photo on multiple pages.
Select overlap options, which give margins so that connecting the pages forms the picture. Overlap around 1/2 inch or so.
Print the photo. The number of pages should match the set up options selected under the imageable table.
Nov 17, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
The printer will not print on the half inch left edge of the page.
go to settings and change the left margin to 0.0. if in Word, then file->page setup and set the margins to what you want, left margin to 0.0 in your case.
Sep 02, 2009 | Laser Office Equipment & Supplies
Printer reduces print size to fit 1/4 of page
You are getting your printouts because they are selected Fit to page. So you only have to search for Fit to page option in Properties or options of your printer settings and just uncheck it. You printouts won't be anymore fit to page they will be of default size. You will get other messages Print out of margin and othes. Thankyou for using fixya free utility if this does not solves your problem kindly do ask me again. Your problem will be solved quickly.
Jul 27, 2009 | Canon Pixma MP500 All-In-One InkJet...
EPSON AcuLaser C1900 paper jam when printing black or color
I have just gained a C1900 second-hand and have set it all up and got the drivers and so forth. Am having exactly this problem, right down to the folded pages, wide top margin and 'Check Paper Size' error message. Did you ever find a solution to this? Anyone else know how to fix it?
Jun 06, 2009 | Epson AcuLaser C1900 Printer
HP Deskjet 5150 print is too small
Printers try to fit web pages on a single sheet of paper. If you configure the printer, in the print dialog, not to shrink images and text to fit the paper, it will print on multiple sheets of paper, but the correct size for the images and text.
In a Word document, it depends on what font size you have selected. Most people would rather have the web page print on a single sheet, with smaller images and text than were on the monitor; than tape together multiple sheets for 100% size printout.
Jan 31, 2009 | HP DeskJet 5150 InkJet Printer
For some reason when I print from the HP Pavillion dv2000, my printer feeds a blank page through for each page I am printing.
Appears to be a relatively common problem for different reasons--sometimes system, sometimes printer. Things to check--page length settings, try reducing the printout size, margins. What's the printer and what size paper? Thanks
Oct 31, 2008 | HP Computers & Internet
How do I make the print out text larger on my HP deskjet (F2187) printer and scanner. it is sooooo small I cant read it.
dear,
did u check the setting in print page setup..
if not then try with that..
by the way, the page that u r going to print, does it seems of normal size..
select the A4 page in page setup and select proper margin and check the font size as mensioned above..
regards,
hope it will fix your problem, so dont forget to rate it
Oct 10, 2008 | HP Office Equipment & Supplies
HP 920 Plain Paper Fax Logo
Seeker5211
Seeker5211
