Question about Unitech MSR 206-33 (msr206-33) Magnetic Card Reader
Format of file to write
What´s the format of file to write data on tracks by MSR?
    Scholar:
  • 115 Answers
Trk 1 starts with a B
Track 2 NO LETTERS
Spaces are seen as __
B1111112223333333^PUBLIC/JOHN___^9912120100000000000000000000
1111112223333333=9912120100000000
Selvol
Posted on Nov 24, 2008
I am trying to format sony vaio pcg-c1mrx in command prompt but i dont know what the command to enter. please help me how to do this. thanks!
try these
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B ' /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B ' /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B ' /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B ' /S] [/C]
here are the explanations
/V[:label]
Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C
Tests clusters that are currently marked "bad."
hope this helps.let me know
Dec 31, 2010 | Sony VAIO PCG-C1MRX PC Notebook
Cannot format octagon veridisk T118 usb
Try this
Microsoft Windows 95, 98, ME syntax
Formats a disk for use with MS-DOS.
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B | /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B | /S] [/C]
/V[:label] Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C Tests clusters that are currently marked "bad." Microsoft Windows 2000 and Windows XP syntax
Formats a disk for use with Windows 2000.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/V:label] [/Q] [/1] [/4]
FORMAT volume [/Q] [/1] [/4] [/8]
volume Specifies the drive letter (followed by a colon), mount point, or volume name. /FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS). /V:label Specifies the volume label. /Q Performs a quick format. /C Files created on the new volume will be compressed by default. /X Forces the volume to dismount first if necessary. All opened handles to the volume would no longer be valid. /A:size Overrides the default allocation unit size. Default settings are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes). Note that the FAT and FAT32 files systems impose the below restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526 FAT32: 65526 < Number of clusters < 268435446
Format will immediately stop processing if it decides that the above requirements cannot be met using the specified cluster size.
NTFS compression is not supported for allocation unit sizes above 4096.
/F:size Specifies the size of the floppy disk to format (160,
180, 320, 360, 640, 720, 1.2, 1.23, 1.44, 2.88, or 20.8). /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. Microsoft Windows 2000 and Windows XP recovery console syntax
format [drive:] [/q] [/fs:file-system]
drive: Specifies the drive to format. /q Performs a quick format. /fs:file-system Specifies the file system to use (FAT, FAT32, or NTFS) Examples
When using the format command, remember all information on the drive you wish to format will be completely erased.
format a:
Would erase all the contents off a disk. Commonly used on a diskette that has not been formatted or on a diskette you wish to erase.
format a: /q
Quickly erases all the contents of a floppy diskette. Commonly used to quickly erase all information on the diskette.
format c:
This would erase all the contents of your C: hard disk drive. In other words, unless you wish to erase all your computer's information, this command should not be done unless you're planning to start over.
Or
Right click My Computer-->Manage-->then go to Disk Management
and select the to format right-click it and click format. Thats it Your drive will format and You can also choose in which file system you want to format your drive.
For further help or to thank me mail me on my email ejaz89@live.com
Aug 06, 2010 | Computers & Internet
Err format while recording - 1 hour lost!
I have almost the exact same problem.
I did not interrupt my recording. I stopped recording, turned off the recorder, unplugged all the mics, turned on the recorder, listened to the first 10 seconds of the recorded track, turned off the recorder, plugged it into my mac, turned it on in USB mode, attempted to transfer the track file, and the track size is "zero kb." I ejected the recorder, turned it off and back on, and now the track says "err format" and skips to the next track.
This seems like a unique problem, as any "data recovery" software will search for deleted files instead of corrupted files. And even if the file is corrupted I have software that can read the raw wav data. However, the filesize is incorrect and obviously doesn't contain any wav data. Shouldn't it be the actual file size? How can I fix this???
Sep 13, 2009 | Marantz PMD660
USB stuck in Reading mode in Kenwood KDC-W5041U model
format the USB using the HP USB Disk Storage Format Tool
download to this link:
http://www.pcworld.com/downloads/file/fid,64963-order,4/reviews.html
format the USB drive and select FAT system
not FAT32 or NTFS
Mar 23, 2009 | Car Audio & Video
Unable to send data and format too
Try this,
Download and install the low level format tool using the link provided below,
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Format your Flash Drive using this tool. After this format, please make sure to format it once normally by right clicking on removable disc in My Computer and click format. Second format is neccessary since low level format will remove the File System data even and second format will again create that file system.
Also,please make sure that you select FAT32 as the file system while formatting it for the second time.
Nov 25, 2008 | Electronics - Others
File Format error when I try to write from a file
Your File Format error could be because you are using Letters on Track 2.
NO letters on track 2. Also try removing any spaces, ? # :.
Here is an example of a two track Card. Spaces are seen as__.
Nov 15, 2008 | Unitech MSR 206-33 (msr206-33) Magnetic...
What video formats can you play with slv-d360p?
Hi al - your unit can play the following formats:
DVD VIDEO
DVD -R / - RW
DVD +R / +RW
CD -R / -RW
VIDEO CD
MUSIC CD
The player can play CD-ROMs/CD-Rs/CD-RWs recorded in the following formats:
- music CD format
- video CD format
- MP3 audio tracks and JPEG image files of format conforming
to ISO 9660 * Level 1/Level 2, or its' extended format, Joliet Kodak Picture CD format.
*(A logical format of files and folders on CD-ROMs defined by ISO)
The player can play DVD-ROMs/DVD*RWs/DVD+Rs/DVD-Rs recorded in the following formats :
- MP3 audio tracks and JPEG image files of format conforming to UDF(Universal Disk Format).
In other words, just about everything. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
May 12, 2008 | Sony SLV-D360P DVD Player/VCR
Format Error
I hade just that prob. "format error" used to display. I did this:
1. dwl sonicStage (free)
2.- in the walkman went to menu/initialize/format
then displayed a confirmation screen, I confirmed
it displayed "formating...... COMPLETE"
3.- THEN plugged into the PC and transfered songs with Sonic
and it worked!
Jan 16, 2008 | Sony NW-E003F MP3 Player
"Format Error" after format with windows explorer (XP)
Hello, please check this link: http://support.sony-europe.com/DNA/WM/NW... If you need more info please advice. Arpi
Feb 01, 2007 | Sony NW-E405 MP3 Player
How can I burn mp3 CD-R ?
MP3 pro?! Have you tried using a 3rd party writer like roxio and just chose data disc option, or import them into a conversion software even import into itunes (insuring mp3 is your selected format) and write the mp3 files created.
Oct 10, 2006 | Panasonic SC-DK10 System
Unitech MSR 206-33 (msr206-33) Magnetic Card Reader Logo
158 people viewed this question
Top Unitech Televison & Video Experts
Michael Galve
Michael Galve
Are you an Unitech Televison and Video Expert? Answer questions, earn points and help others
