Question about Proscan PS27125 27" TV
Static on screen and then turns itself off then on
My ProScan is about 8 yrs old. When I turn it on it has loud and noisy static: not full screen static, just one white line several times that pops and hisses really loudly. Then sometimes during this static it turns itself off then right back on. It doesn't matter if I'm watching TV (through satellite box) or a videotape or DVD (on Sony combo). Sometimes it turns off/on 3-4 times in half an hour. It's really annoying. Can someone please help with a solution advice? THanks.
    Sergeant:
  • 337 Answers
My first aproach will be to see if the tv reacts to tap on the sides if you see a reaccion when you do it most likely you have a loose conection and need to call someone to find it and resoldered it.Dont do it yourself if you dont know how.
Posted on Sep 12, 2006
I try to turn my proscan tv on and the the power comes on but before anything the tv blinks a d it turns off immediately, any advice?
About 51,900 results (0.55 seconds) Search Results
    My Proscan 42 tv is turning on and off by itself, changing ...
    www.shopyourway.com > Manage My Life > Questions
    Oct 16, 2012 - My Proscan 42 tv is turning on and off by itself, changing channels on it's ... that is next to the power connection plug is discolored at the board.
    Proscan/RCA 123882 Power Supply Unit (PSU) Boards ...
    ? 2:48
    https://www.youtube.com/watch?v=TC908vQ8jaw
    Jan 17, 2013 - Uploaded by ShopJimmy.com
    RCA TV Repair for Blank Screen TV Will Not Power On How to fix... I have a Proscan PLDED3273A-E. Looks like my problem is the L1 (brown spot on board) - any suggestions? ... before it turns off the audio still works and the image still comes out if I ...Recently I tried turning it on and I get no standby light.
Jan 25, 2016 | Proscan Televison & Video
Proscan 27" tv
if you want to eliminate magnetism, you have to degauss the screen, if you don't know how to do that, here is a small guide for that: http://www.wikihow.com/Degauss-a-Computer-Monitor
but that strange shutting down its the transistor... so your best choice is to send it to a repairman to change the transistor..
if you try to do that for your self, you could even get shocked with the electricity contained in the tv... even if its turned off and unplugged..
Dec 22, 2007 | Proscan PS27500 27" TV
Why do my proscan tablet keeps resetting its self
Not normal behaviour. You should take it to service
Dec 28, 2014 | Proscan 8" Tablet with 4GB Memory
Hi i have had a sanitop for about 4 yrs with no probs, today its very noisy and flushes by itself toilet bowl seems to be quite full have turned power off, is this ok and what should i do next its very...
indicates a blocked or very dirty unit. Try cleaning with a saniflo cleaner - can be intorduced via wc bowl without unit removal. if this fails then its time to remove the unit and clean / look for blockages
Mar 02, 2010 | Saniflo & Saniplus& Macerator Pump
"clunking" noise when it turns itself off
the compressor mounts are bad . or the internal insulators in the compressor are bad . . is sounds like the internal mounts . at 9 yrs . . mm hope this helped . ,mm
Feb 03, 2010 | Refrigerators
On my proscan tv, when i turn it on the sound works but nothing comes on the screen, the tv is 8 months old.
i think this is a known problem....some guy in phoenix is selling a bunch of these returned tv's from SEARS with the same problem for $150.00 try to return it.
Mar 02, 2009 | Proscan 32LA25Q 32 in. LCD TV
Loud noise when volume is turned up
OK, if it feels like it relates to the turning of the control, then the vol control may be noisy and will need a spray with contact cleaner lubricant. Do you think you can do this, I can talk you through it. If not, a repair man or someone with electronic experience could do it for you.
regards
Graeme
Apr 18, 2008 | Audio Players & Recorders
Proscan tv
enter the user menu to see if you have text or telecaption on,if not your vertical section is possible at fault if the bottom half of the screen is blacked out.
Mar 19, 2008 | Proscan PS32500 32" TV
Proscan video problem
Sound like bad tuner,or tuner circuitry.Instead of spending money,why don't you bypass the problem??
Use a / v  outputs from source box to a /v inputs on tv
let me know by rating if you need more help....T.
Oct 20, 2007 | Proscan PS36125 36" TV
Proscan 27" tv
it is due to power supply failure. 1 check for loose contact in power supply. 2 it might be due to plug or socket loose. 3 switching circuit failure in power supply. good luck.
Oct 07, 2007 | Proscan PS27500 27" TV
Open Questions:
I own a Samsung LN40C630K1FXZA TV with no picture but has audio and backlights. I need help determining what boards to replace. I tried to watch some tutorials posted on YouTube and have the following information. The TV was starting to have an issue that while watching it the picture was seeming to get a little jerky like it wasn't refreshing fast enough. It wasn't always noticeable and I initially though it may have been a signal issue with our cable. Eventually we turned on the TV one morning, the picture came on and then disappeared after 2 or 3 seconds but we still had audio. I tried to pull up the menu screen and that was not visible. I performed the flashlight test and there are images visible with the light. I removed the back cover and took pictures of the attached boards and also saw that the backlights seemed to be working but did seem like they were not quite a constant consistantly light. They never completely extinguish but do seem to fluctuate in brightness slightly. I did not see any visible issues with any if the capacitors being swollen or blown and did not see any apparent burnt components or boards. Below are the readings I got from one board but I was not sure where to get the readings on the TCON board. Main PBA readings CN201 1. 18v. Actual 13.1v 2. Sw. Power Actual 13.1v 3. 18v. Actual 13.1v 4. 5v. Actual. Falling to -1.6mv 5. 5v actual. Falling to -1.7mv 6. 5v actual 5.15v 7. 5v. Actual 5.15v 8. ground actual 13.1v 9. Ground actual 13.1v Any help would be greatly appreciated so I can buy the right parts from you. Thanks, Chris
Jan 19, 2019 | Samsung Televison & Video
See all Proscan PS27125 27" TV Questions
Televison & Video Logo
151 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
