Question about Philips Magnavox PR1906C 19" TV
Picking up other sounds
I not sure if it"s the television, but at times I hear like my neighbors voices on my television. I know that sounds crazy, but it's becoming a problem since my girlfriend and I like to watch adult movies on television on weekends. We hear comments like "turn that off,or that's all you guys all do. I don't understand because we have the sound all the way down. i feel like my privacy is being violated. I need a solution. Thanks
  • 337 Answers
Re: Picking up other sounds
A powerfull trasmiter will interfere with the sound of your TV like a CB radio,Close the windows.It might stop.
Posted on Sep 12, 2006
0 characters
3 Points
Although the volume reaches to 100 , i can hear a so weak voice near the speakers in some channels and a better voice in other channels but anyway the volume degree is not the usual i have tried using...
Hi good_eng_ale,
This symptom needs to check with an experienced technician because the fault is either the following :
1. IF transformer - mis-aligned Sound IF transformer will produced weak sound, this will happened when the unit aged.
2. Coupling Capacitor- once dried or leaky, the same symptom will produced.
3. Faulty Sound Ouput IC.
Thanks for using Fixya.
Mar 08, 2011 | Toshiba Standard (CRT) Televisions
Screen blank can only hear voices & struggling to switch it on it gives sound like drum beats
You have some bad capacitors. Look for values at 160volts to 200volts at 1Mf,2.2Mf,3.3Mf or 4.7Mf. These are good candidates for your failing TV. Another one to look for are the 25volt to 35volt 100Mf caps. Good Luck and thanks for asking!
Jul 29, 2010 | Standard (CRT) Televisions
My TV keeps turning on and off on its own
are you lying on the remote or has your neighbor or friend got the code and is bugging you? Pull the plug out or turn it off at the wall
Please rate my help++++Thanks for using FIXYA
May 12, 2010 | RCA TruFlat 27F520T 27" TV
Black border all around picture
is there a button labeled picture? if so press it (you might have to press it twice before it steps to a new aspect ratio, then once for every different aspect ratio until you get the one you like.
Jan 15, 2009 | RCA 32F531T 32" TV
Sony Trinitron TV
You need Sony TV Remote and press Display button on remote and On-Screen Display will disappear.
Check TV remote in neighbors, friends etc to use once.
Nov 05, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
No picture or sound
Last time one of my durabrands did this I unplugged it for like 10 mins and gave it a nice kick to the side and it worked fine again. I know it sounds crazy but dont kick it too hard like dont crack plastic. I have also done this to oversurged CRT monitors
Apr 03, 2008 | Durabrand DWT1905 TV
Can't hear voice/some audio
your audio setting is set to 5.1 and your do not have enough speakers to hear all the sounds. I suggest to change the setting to 2 speakers and you will be able to hear everything. good luck
Apr 03, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Philips Magnavox S#45870337 M#25TS56C221
ok i think it might be the picture tube im not sure but if u dont trust me call the company for assisants!
Dec 11, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox PR1906C 19" TV Logo
37 people viewed this question
Top Philips Standard (CRT) Televisions Experts
Sp Gupta
Jim Evans
Are you a Philips Standard (CRT) Television Expert? Answer questions, earn points and help others
