Question about Fujitsu Siemens AMILO Pro V2000 Notebook
My laptop starts up fine but cant get past windows logo..have tried recovery disk and f12 but then only shows a blackish screen
    Sergeant:
    Champion:
  • 275 Answers
Do you have a usb printer connected?
if yes disconnect it and than start the system and also try to scan you system with malaware bytes and superantispyware available on gur.in and make sure to use malaware bytes first and than superantispyware
Posted on Oct 31, 2008
How to do a Destructive Recovery OR create Recovery Disks under Windows XP
you must HOLD the CTRL KEY + F11 OR F12, AND go to the reconvery factory setup.
God bless you
Jun 16, 2013 | HP ProBook 4510s FM849UT Notebook
"error loading operating system" message on dell inspiron 1420 laptop
only way to bypass this is use a recovery disk to boot from and then perhaps the issue will manifest itself
otherwise, it's the dreaded re format step
May 22, 2012 | Dell Computers & Internet
My dell notebook stoped working it shows only curser on the screen and there are some lines on the screen nothing wrong with the power supply
If it does boot to windows and only does not shows the icons..than you have to click right on the desktop and choose to show icons ..and will be ok ..If the screen you wrote about is just a start screen and it never started windows..than I think it is a windows fault and need to be reinstalled .Do that by entering the recovery partition and go with the total installation of the operation system ..
to do that choose the key indicated on screen and select the action ..
usually on start screen it is written to press F2 for the set-up and f12 for the boot menu and probably F11 for teh recovery ..if it is so ..just press f11 on start ..go to recovery ..choose complete recovery ..and will get it to the factory stage .
If the recovery do not work and you do have a disk for it ..insert the disk and boot from it ..try to boot to recovery with the disk on ..and see if ti works..if it dopes its ok ..if not ..restart . and press F12 to go to boot menu .and choose to boot from CD /DVD drive ..and hit enter .. this will force it to boot from disk and load the recovery .
same procedure with a boot-able disk with operation system, ..in case you do not have any recovery ..or just have recovery for drivers..and you will be forced to use a standard boot-able disk to load the operation system again
have a nice day ..and please rate my answer ..1
Dec 22, 2011 | Computers & Internet
I got a toshiba satellite pro a100 laptop (psaace- 007002en) second hand and it still has lots of the previous owners files on so I would like to restore it to factory settings but i don't have the...
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer. Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Sep 20, 2011 | Computers & Internet
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
Im trying to scrap my os and run the system back up disks. but im not sure how to start the process
if u have the cd
http://www.youtube.com/watch?v=UvTyxTxO3-s
if your computer have a recovery partition at start your laptop in logo screen press f12 or f11
if u see the command on right down corner on screen. and fellow instructions, ther are easy instructions
Dec 18, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Will not load past starting screen (HP logo)
maybe is hard disk problem, try boot from cd.(check for any errors dispayed)
Jul 15, 2010 | HP Compaq nc6220 Notebook
Cant get past the acer screen
ok,your laptop OS file could be damaged so nothing booting later.
you may do follow steps
1) try F8 or F12 into boot sequence, choose safe mode to start your windowas, it could repair your damaged SYSTEM file. if still trouble
2) you may use a OEM windows disk (match your lable type)
booting from CD drive, then choose a windows repair, it maybe recovery your syastem. if can not do so
3) booting a OEM windows disk (match your lable type) reinstall new OS system(use the CDkey on the lable). and some driver you need downloard from Acer website.
hope you fix it, any question feedback any time please.
please take a rating let me know how much helped you thanks!
May 22, 2009 | Acer Aspire 9410 Notebook
Windows dosent start
go n format it by using a recovery drive...there may be a start up errors occured in windows
Apr 26, 2009 | HP Compaq nx6310 Notebook
Recovery disks aren't Windows XP
Have you tried booting the laptop with the recovery disk already in the CD drive. If the disk doesnt register and start to spin press F12. Should give you option to boot from CD
Mar 07, 2008 | Toshiba Satellite 1135-S125 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
236 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
