Question about ASUS P4S533-VM (P4S533-VM/L) Motherboard
ASUS P4S533 Motherboard 1.77GHz CPU does not boot with 1GB DDR400 RAM
If I run 784MB then the system boots perfectly. As soon as I go beyond that the system won't boot. BIOS version ...4. Tried ....6 and ....7 but they will not install. Error on boot points directly to CMOS 1.77GHz problem. I have the option to select manual speeds but I don't know what to select.
  • Howard Lester May 11, 2010
    Are these sticks from the same manufacturer? Same size in Megabytes?If not what is the size of each stick? How many chips on each stick and are they all the same in number?
  • 40 Answers
Make sure you are using the supported memory type. Check the user guide. Also check if you have installed the latest BIOS firmware from ASUS.
Posted on Jan 12, 2009
    Problem Solver:
Hello this is the answer: You know what? we have the same motherboard type! if you want to get the specs of our board you can go to this web:'+P4S533-VM+Motherboard+&page=1&qsrc=2106&ab=2&u=
Posted on Aug 04, 2009
In you case compatibility is your problem or your memory needs a clean up. First clean up the memory's pins. Use a pencil eraser. Then try only one by one so that you will know if there is a problem in each memory. Insert one of the memory then turn on your PC. If it boot up or it is okay try the other one. Then if it is also okay, try both of it inserted and turn on your PC. If it not okay there is a compatibility problem. Make sure the brands are the same so the compatibility are never be a problem.
Mar 10, 2010 | ASUS P4S533-MX Motherboard
Do I need to buy 2 DDR2 Ram for my ASUS P5VDC-MX Motherboard?
with rams, if the memory it has is higher than that of your cpu, the pc will not boot up or if it is too low compared to your cpu again.
thus, you say it has got two slots right, remove both of the 512's and insert the 1gig only, run your computer, i am sure it will boot up nicely. switch it off. put one 512, if it does not boot then you should know that your ram has an excess of memory that your cpu could not apprehend to.
post a coment if this does not work.
Sep 18, 2009 | ASUS P5VDC-MX Motherboard
Asus k8s mx not boots but fan rotates and without
Long beeps are saying 'no RAM'. Any beeps with RAM in place? Remove BIOS battery (silver) for 10 mins to return to factory defaults.
Sep 12, 2009 | VIA Asus K8V-MX K8M800 Chipset 800MHz FSB...
System boot problem
This is possibly a bad hard drive. If you know the manufacturer of your hard drive you can download diagnostic tools from their site, burn to cd and run diagnostics to check the drive for errors or failure.
Apr 11, 2009 | ASUS A8N-SLI Premium Motherboard
Ddr ram sdr ram i am same time input that tw0 thats not show two ram capacities just show one ram'' asus p4s533 model please help me
Hi safran0785,
The Asus motherboard, P4S533-MX can run two different types of memory.
(Just not at the same time & in different slots).
You can use 2, 184-pin memory, PC2700/PC2100 MHz or PC1600 up to 2GB. (1GB DIMMs) inserted in the two memory slots closest to the CPU.
Or you can run SDR memory, 168-pin PC133 or PC100MHz DIMMs up to 1GB of memory in the last two slots farthest from the CPU.
You can not run both types of memory at the same time.
The 184-pin DDR PC2700MHz memory is much faster then SDR memory.
The maximum amount of system memory supported is 2GB.
Need more information/questions, just post here.
Good luck safran0785!
Mar 22, 2009 | ASUS P4S533-MX Motherboard
Memory Issues with P5GL - MX
Some motherboards require that you install the memory in matched pairs. That could explain why they won't work together.
When you put the 1 GB in alone, what slot did you put it in?
I would suggest the blue A1 slot (closest to the CPU).
It may be that you have a bad memory module.
You could try the Windows Memory Diagnostic:
You may also be interested in the motherboard's manual:
Feb 06, 2009 | ASUS P5GL-MX Motherboard
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
3x 1GB DDR400 Problem on booting!
the details for your case can be obtained in this site.....................
read carefully to understand the limitations that arise with your motherboard.
Jan 22, 2008 | ASUS P4S8X Motherboard
ASUS P4S533-VM (P4S533-VM/L) Motherboard Logo
430 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
