Ei systems 4411 wont power on mains or battery
Hi ei systems 4411 p4 laptop wont power on i press on button from mains
lead i get three green lights as i would when it boots only thing they come on for about 3 seconds then go off the cpu fan does not spin ,does same thing from battery power.. could it be i need new processor ? any help would be appreciated thanks jake
  • 3 more comments
  • jakeycakey Oct 30, 2008
    we already replaced the ram as new still same its as if nothing from cpu we reseated cpu as well the 3 lights light up for around 3 seconds does same from mains or battery there is power to the board briefly the cpu fan does not spin (checked fan working ok)
    there is power going to the board
    the motherboard was a replacement it seems as if the power gets to the cpu then nothing cpu cold
    i dont think its the board as this was new recently had little use no power surge to suggest anything
    i will replace the processor and get back to you
    with the results ok thank you jake
  • 6,487 Answers
This can already be a dead processor due to overuse and overheating , becuse first thing that you can think of here is the power supply but power is still getting to the motherboard so its not the power supply nor the motherboard, so if its possible for you to try a different processor that will be better so we can check it...
Posted on Oct 30, 2008
  • 59 Answers
If sending in for warranty do not let them know you have been inside it will void all warranty!!
Sounds like the motherboard is bad a replacment board usually runs aroun $200.00 on ebay if not under warranty. use your ram cpu etc.
  • 13,433 Answers
Is you machine covered by warranty? it would be best to take it to warranty repair, if you don't have warranty, and this seems like a major fault in the mainboard its cheaper and easyer to buy a new laptop.
  • Ekse Oct 30, 2008
    your cpu, memory and so on are most likely fine, the motherboard may have failed, would need to be tested.
  • Ekse Oct 30, 2008
    the power may go to the board, I have had many motherboard failed laptops which still have the power light come on but they don't start up, they fail in post and don't power on. but the light can still come on, no picture in screen, no fan.
  • 94 Answers
This is a typical motherboard issue.
It seems like there is a problem with the conduction to the motherboard.
I suggest sending the laptop to a lab for further testing.
  • Tamir Meiri
    Tamir Meiri Oct 30, 2008
    Certainly seems like some sort of hardware failure. better test that at a certified lab.
  • 19,396 Answers
Try pulling out and putting back in place the ram modules, the motherboard can be faulty.
  • Ginko
    Ginko Oct 30, 2008
    Try first unplugging the power cable for ten minutes, and see if restarts, this reset can often solve the problem.
    If the computer does not start there is the fault.
    If you have no power at all , then is the power supply unit
    If you have power and no screen, then the computer must be started with minimal set of devices.
    This is done by accessing the motherboard and starting it with no disks and possibly no pci devices, or the Video card only and one RAM module.
    If you have not done this before do not do it yourself, an easier test is pulling out one ram module and starting the computer with one module, but this still requires accessing the motherboard.
  • Ginko
    Ginko Oct 30, 2008
    If the fan and the fan wirings are ok and the cpu fan does not even spin, then is either a fried motherboard or a faluty cpu. Usually is the motherboard.
Ei System 4411
Here's one link for your solution:
http://www.crucial.com/upgrade/Ei+System-memory/Ei+System+-+All+Models/4411-upgrades.html
Mar 31, 2014 | Computers & Internet
Hi, the three green lights on my dell 100l flashes when ever i plug it in.when i press the switch button it stops flashing but does not come on. please help
Take the battery out, connect the power plug and see if the laptop runs without the battery connected, the main battery may need to be replaced.
Aug 28, 2010 | Dell Latitude 100L Notebook
Labtop wont start up
Hi I am a laptop technician, and it sounds like you have a power problem.
Try removing the main battery and starting the laptop on the mains cable only. If the laptop starts fine then you probably have a problem with either the battery or the power board in the laptop.
If the laptop doesn't start when doing this, remove the mains power lead from the laptop and put the main battery back on the laptop. Try starting the laptop off the main battery only and if the laptop starts normally then you most likely have a broken/loose socket that the power lead plugs into in the back of the laptop (a very common problem) or the power board in the laptop is faulty. If the laptop doesn't start or goes off very shortly after pressing the power button it could just be that the battery is flat as a broken power socket on the laptop often stops the main battery from charging.
I hope this helps.
Jan 03, 2009 | Acer Aspire 5315 Notebook
Laptop's primaryhard drive and multibay always on aftr switchoff
control panel
display
screen saver
then power
then advanced in there you can make sure your options are correct
you can check your settings in there for turning off your system
ei/ when you press power button you want it to shut off
Dec 14, 2008 | HP Compaq nc6000 Notebook
Ei systems 4411 wont power on/mains or battery power
If the fan does not spin, the unit is shutting down to protect the processor. I would have the fan replaced . Do not attempt to use the laptop, it may cause extensive damage if it overheats.
Joe
Oct 30, 2008 | Computers & Internet
The most likely cause of your ills is a failed motherboard Jake. Processors are pretty tough but unfortunately HP did a lousy job with the motherboards on the DV series and many, many of them fail and usually after the warranty is over.
Oct 30, 2008 | HP Pavilion dv6000z Notebook
EI System 4411 Laptop
go to the control panel, internet options, connections tab, then check mark "never dial a connection".
then try to connect.
Sep 27, 2008 | Computers & Internet
Ei systems 4411 Battery driver/not charging
first of all check this battary with another same configured laptop of your's.. i guess this problem should be with your battary...
thanks
Mar 31, 2008 | HP Pavilion dv6000z Notebook
Laptop battery
It does charge until the battery reaches full charge, then charger stops and laptop use adapter's power. The whole system is thought to not damage or wear the battery while in charge. Leave battery safely inside your Dell while using it with power adaptor, it should not make any difference in your battery life.
regards
Mar 21, 2008 | Dell Inspiron 6400 Notebook
Acer aspire 3634 LMi
Do you get any beeping or flashing status lights when you try to start it up?
Nov 15, 2007 | Acer Aspire 3610 Notebook
Computers & Internet Logo
David Payne
David Payne
