Question about Whirlpool Refrigerators
Runs but doesn't cool at all and compressor gets very hot
  • 749 Answers
FREON COULD HAVE RUN OUT. have it checked and refilled!
Posted on Oct 31, 2008
I have kelvinator fridge it doesn't cool in both compartment we replaced the compressor il coold down for only 3dayes then returned back to hot state
is the condenser fan running back there?also did you clean out the condenser coil?usually when the middle strip gets hot the coil is filled with dust or the fan where the compressor is isn't running.the condenser fan keeps the compressor cool and all the heat from the machine escapes out through the condenser coil.check this,also the start device could be bad on the compressor,send model number next time you write so whoever helps you can look up your machine.hope this info helps you out.
Sep 15, 2012 | Kelvinator Refrigerators
Air compressor starts and then shuts off
Do you mean it runs for 1 or 2 seconds and stops or it runs for minutes and stops? If it never really starts (runs for a second or less) then it is probably a capacitor start motor and the capacity has gone bad.
If it runs for minutes or more and then stops and subsequently restarts when it has cooled then the thermal overload switch is turning it off when the motor overheats. If the unit is not all that old, hasn't been run particularly hard and you have this problem every time you turn it on when it is just pumping up, (which is to say, there is no good reason for the motor to be overheated) then the thermal overheat switch is probably defective.
If the compressor is being run hard when this happens, then the unit is being overheated from heavier use than for which it was designed. If the interior of the compressor motor has a coating of saw dust or dust, it acts like an insulator and results in the motor heating more quickly than it should under normal circumstances. Also, if it is being used in a hot environment it will likewise have trouble cooling.
So, if it really doesn't run at all, it is probably the motor starting capacitor. If it happens when the compressor isn't really hot, then the thermal over-temperature switch is probably defective. If it gets genuinely hot, but without being run hard, then the motor might need to be cleaned because it is not cooling properly. If it happens when it is hot and it is hot because it has been run hard, then either don't run it as hard, cool it better or get a bigger compressor. If it is clean inside, not being run hard but still overheats, then I would look at a malfunction in the compressor portion of the unit having more friction than it should (bearings lubricated?) thus requiring more horsepower to run the compressor than the motor is designed to generate and results in overheating. Low voltage can also do the same.
Aug 03, 2012 | Coleman Air Tools & Compressors
LG Fridge LSC26945TT compressor getting to hot and not cooling
if it's not cooling unplug it so you don't damage the compressor,hopefully you just have a bad overload and relay,it's plugged into the side of the compressor,with the machine unplugged remove the bottom back panel,look at the compressor,remove the cover on the side of compressor and remove the start device or ptc assy. call your local parts store and give them the model number and buy a new start device for your machine.if you can hear a clicking sound every once and a while and the compressor is hot change this out first,if it still doesn't start then you have a bad compressor and will be in the market for a new fridge if the compressor is running take everything out of the freezer,remove the back inside wall of the freezer and check the evap coil,if the coil is all iced up you have a defrost problem,if the evap coil doesn't have an even frost pattern covering the whole coil you have a freon leak.if you have a freon leak you'll have to replace the fridge..hope this helps
Jul 04, 2012 | LG Refrigerators
Hotpoint Refrigerator constantly runs and doesn't shut off normally.
Sounds like the thermostat is not working that is what tells the compressor it is cold enough shut off.
May 17, 2012 | Hotpoint Refrigerators
Doesn't cool, what could it be?
Can you access the back? If it is very hot, the compressor is working but the condenser needs a thorough clean and check if it has a fan that may have stopped working. If the condenser is cold, the compressor isn't running. Could be faulty, but could just be a thermostat gone.
May 16, 2012 | Danby Refrigerators
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
Aug 07, 2011 | Haier HRQ04WNAWW 4.2 Cu. Ft. Refrigerator
The compressor is running and the fan is running but it is not cooling. The refrigerator runs and stops like normal. Last time we had it checked the repair guy said it was the fan not spinning fast enough...
On the refrigerator and after sometime hold the condenser to see if it is hot, if it doesn't become hot then there is no refrigerant in the system there must be a leakage somewhere or it could be the compressor which is losing compression or doesn't pump well.
May 11, 2011 | Hotpoint RLA50 Refrigerator
Fridge is not cooling freezer is not freezing
Your compressor is seized and is cycling on intenal overload, you will have to get someone out to get a price at replacing the compressor for your fridge.
Apr 04, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
51 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
